Napisano: 25 May 2016, 09:57
Slackware 64-bit
Wed May 25 04:20:09 UTC 2016
a/aaa_elflibs-14.2-x86_64-16.txz: Rebuilt.
a/e2fsprogs-1.43-x86_64-2.txz: Rebuilt.
Do not use 64-bit by default on ext4, since some bootloaders cannot handle
it yet. But use "auto_64-bit_support = 1", which will enable 64-bit if the
number of blocks for the file system requires the feature to be enabled.
a/syslinux-4.07-x86_64-1.txz: Upgraded.
ap/cups-filters-1.8.3-x86_64-3.txz: Rebuilt.
Recompiled against poppler-0.44.0.
ap/mpg123-1.23.4-x86_64-1.txz: Upgraded.
ap/slackpkg-2.82.1-noarch-2.txz: Rebuilt.
Updated URLs for garr.it mirrors. Thanks to Andrej Sossi.
d/git-2.8.3-x86_64-1.txz: Upgraded.
kde/calligra-2.9.11-x86_64-4.txz: Rebuilt.
l/libarchive-3.1.2-x86_64-3.txz: Rebuilt.
Patched an issue with Zip archive handling that could allow an attacker
to overwrite parts of the heap in a controlled fashion and execute
arbitrary code.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1541
l/poppler-0.44.0-x86_64-1.txz: Upgraded.
n/gnutls-3.4.12-x86_64-1.txz: Upgraded.
xap/MPlayer-1.2_20160125-x86_64-3.txz: Rebuilt.
Recompiled with --disable-ossaudio.
xfce/tumbler-0.1.31-x86_64-7.txz: Rebuilt.
isolinux/initrd.img: Rebuilt.
Slackware 32-bit
a/aaa_elflibs-14.2-i586-16.txz: Rebuilt.
a/e2fsprogs-1.43-i586-2.txz: Rebuilt.
a/syslinux-4.07-i586-1.txz: Upgraded.
ap/cups-filters-1.8.3-i586-3.txz: Rebuilt.
ap/mpg123-1.23.4-i586-1.txz: Upgraded.
d/git-2.8.3-i586-1.txz: Upgraded.
kde/calligra-2.9.11-i586-4.txz: Rebuilt.
l/libarchive-3.1.2-i586-3.txz: Rebuilt.
arbitrary code.
l/poppler-0.44.0-i586-1.txz: Upgraded.
n/gnutls-3.4.12-i586-1.txz: Upgraded.
xap/MPlayer-1.2_20160125-i586-3.txz: Rebuilt.
xfce/tumbler-0.1.31-i586-7.txz: Rebuilt.
Napisano: 26 May 2016, 10:51
Slackware 64-bit
Wed May 25 23:37:36 UTC 2016
x/xf86-input-wacom-0.33.0-x86_64-1.txz: Upgraded.
In rc.dropbear, drop the option to use /etc/motd.net (this was preventing
dropbear from starting properly). Thanks to Eduard Rozenberg.
Slackware 32-bit
x/xf86-input-wacom-0.33.0-i586-1.txz: Upgraded.
Napisano: 26 May 2016, 23:08
Slackware 64-bit
Thu May 26 20:30:18 UTC 2016
ap/ghostscript-9.19-x86_64-1.txz: Upgraded.
Dumped old unmaintained bundled libraries and linked with system libraries
instead. There had been a crash previously with the GIMP plugin and
ghostscript > 9.07, but now it works as expected. Thanks to qunying.
Slackware 32-bit
ap/ghostscript-9.19-i586-1.txz: Upgraded.
Napisano: 27 May 2016, 05:44
Slackware 64-bit
Thu May 26 23:12:27 UTC 2016
a/aaa_elflibs-14.2-x86_64-17.txz: Rebuilt.
l/libpng-1.6.22-x86_64-1.txz: Upgraded.
l/libtiff-4.0.6-x86_64-1.txz: Upgraded.
n/bind-9.10.4_P1-x86_64-1.txz: Upgraded.
x/libXfixes-5.0.2-x86_64-1.txz: Upgraded.
x/xproto-7.0.29-noarch-1.txz: Upgraded.
xap/imagemagick-6.9.4_4-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_elflibs-14.2-i586-17.txz: Rebuilt.
l/libpng-1.6.22-i586-1.txz: Upgraded.
l/libtiff-4.0.6-i586-1.txz: Upgraded.
n/bind-9.10.4_P1-i586-1.txz: Upgraded.
x/libXfixes-5.0.2-i586-1.txz: Upgraded.
xap/imagemagick-6.9.4_4-i586-1.txz: Upgraded.
Napisano: 28 May 2016, 09:23
Slackware 64-bit
ri May 27 23:08:17 UTC 2016
a/sysvinit-scripts-2.0-noarch-32.txz: Rebuilt.
rc.S: Fixed cgroup, cgmanager, and cgproxy handling so that it works if /usr
is a separate partition. Thanks to Richard Cranium and Matteo Bernardini.
ap/ghostscript-9.19-x86_64-2.txz: Rebuilt.
Use the bundled version of openjpeg, which includes patches needed by
ghostscript. Thanks to qunying.
ap/lxc-2.0.1-x86_64-2.txz: Rebuilt.
Merged rc.S changes.
l/libxml2-2.9.4-x86_64-1.txz: Upgraded.
This release fixes bugs and security issues:
Heap-based buffer underreads due to xmlParseName (CVE-2016-4447).
Format string vulnerability (CVE-2016-4448).
Inappropriate fetch of entities content (CVE-2016-4449).
http://xmlsoft.org/news.html
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4447
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4448
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4449
l/libxslt-1.1.29-x86_64-1.txz: Upgraded.
This release fixes bugs and a security issue:
Fix for type confusion in preprocessing attributes (Daniel Veillard).
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7995
n/php-5.6.22-x86_64-1.txz: Upgraded.
http://php.net/ChangeLog-5.php#5.6.22
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-7456
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5093
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5094
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5096
xap/geeqie-1.3-x86_64-1.txz: Upgraded.
Make rc.dropbear executable. Thanks to Eduard Rozenberg.
Slackware 32-bit
Fri May 27 23:08:17 UTC 2016
ap/ghostscript-9.19-i586-2.txz: Rebuilt.
ap/lxc-2.0.1-i586-2.txz: Rebuilt.
l/libxml2-2.9.4-i586-1.txz: Upgraded.
l/libxslt-1.1.29-i586-1.txz: Upgraded.
n/php-5.6.22-i586-1.txz: Upgraded.
xap/geeqie-1.3-i586-1.txz: Upgraded.
Napisano: 31 May 2016, 17:03
Slackware 64-bit
Tue May 31 05:42:04 UTC 2016
a/aaa_elflibs-14.2-x86_64-18.txz: Rebuilt.
ap/tmux-2.1-x86_64-3.txz: Rebuilt.
Added /usr/share/terminfo/tmux{,-256color}. Thanks to dugan.
d/python-setuptools-21.2.2-x86_64-1.txz: Upgraded.
n/curl-7.49.1-x86_64-1.txz: Upgraded.
xap/blueman-2.0.4-x86_64-1.txz: Upgraded.
Thanks to Robby Workman.
xap/imagemagick-6.9.4_5-x86_64-1.txz: Upgraded.
Removed popen() support to prevent another shell vulnerability. This
issue was discovered by Bob Friesenhahn, of the GraphicsMagick project.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5118
xap/mozilla-thunderbird-45.1.1-x86_64-1.txz: Upgraded.
xap/xscreensaver-5.35-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_elflibs-14.2-i586-18.txz: Rebuilt.
ap/tmux-2.1-i586-3.txz: Rebuilt.
d/python-setuptools-21.2.2-i586-1.txz: Upgraded.
n/curl-7.49.1-i586-1.txz: Upgraded.
xap/blueman-2.0.4-i586-1.txz: Upgraded.
xap/imagemagick-6.9.4_5-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-45.1.1-i586-1.txz: Upgraded.
xap/xscreensaver-5.35-i586-1.txz: Upgraded.
Napisano: 31 May 2016, 22:24
Slackware 64-bit
Tue May 31 20:05:12 UTC 2016
ap/cdrtools-3.01-x86_64-3.txz: Rebuilt.
Applied cdrtools-3.01-fix-20151126-mkisofs-isoinfo.patch. Thanks to gmgf.
ap/hplip-3.16.5-x86_64-2.txz: Rebuilt.
Recompiled with these changed paths:
--with-hpppddir=/usr/share/ppd/HP
--with-drvdir=/usr/share/cups/drv/HP
This matches what is expected for Slackware in the distros.dat file and is
hardcoded in core_install.py. Thanks to kjhambrick.
l/LibRaw-0.17.2-x86_64-1.txz: Upgraded.
l/lcms2-2.7-x86_64-2.txz: Rebuilt.
Don't package PDF/RTF docs.
n/bluez-5.40-x86_64-1.txz: Upgraded.
extra/bash-completion/bash-completion-2.2-noarch-3.txz: Rebuilt.
Removed mpv -> mplayer symlink. Thanks to Robby Workman.
Slackware 32-bit
ap/cdrtools-3.01-i586-3.txz: Rebuilt.
ap/hplip-3.16.5-i586-2.txz: Rebuilt.
l/LibRaw-0.17.2-i586-1.txz: Upgraded.
l/lcms2-2.7-i586-2.txz: Rebuilt.
n/bluez-5.40-i586-1.txz: Upgraded.
Napisano: 02 Jun 2016, 22:55
Slackware 64-bit
Thu Jun 2 19:08:13 UTC 2016
This could be the last batch of updates before 14.2 stable, so please test!
a/kernel-firmware-20160601git-noarch-1.txz: Upgraded.
a/kernel-generic-4.4.12-x86_64-1.txz: Upgraded.
a/kernel-huge-4.4.12-x86_64-1.txz: Upgraded.
a/kernel-modules-4.4.12-x86_64-1.txz: Upgraded.
ap/hplip-3.16.5-x86_64-3.txz: Rebuilt.
Patched setup.py to set LC_ALL=C, which should fix parsing CUPS output.
d/gdb-7.11.1-x86_64-1.txz: Upgraded.
d/kernel-headers-4.4.12-x86-1.txz: Upgraded.
k/kernel-source-4.4.12-noarch-1.txz: Upgraded.
l/harfbuzz-1.2.7-x86_64-1.txz: Upgraded.
n/libnftnl-1.0.6-x86_64-1.txz: Upgraded.
xap/imagemagick-6.9.4_6-x86_64-1.txz: Upgraded.
xap/xscreensaver-5.35-x86_64-2.txz: Rebuilt.
Fixed missing '\' in the build script which caused a few configure options
to be skipped. Thanks to Stuart Winter.
kernels/*: Upgraded.
Slackware 32-bit
a/kernel-generic-4.4.12-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.4.12_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.4.12-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.4.12_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.4.12-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.4.12_smp-i686-1.txz: Upgraded.
ap/hplip-3.16.5-i586-3.txz: Rebuilt.
d/gdb-7.11.1-i586-1.txz: Upgraded.
d/kernel-headers-4.4.12_smp-x86-1.txz: Upgraded.
k/kernel-source-4.4.12_smp-noarch-1.txz: Upgraded.
l/harfbuzz-1.2.7-i586-1.txz: Upgraded.
n/libnftnl-1.0.6-i586-1.txz: Upgraded.
xap/imagemagick-6.9.4_6-i586-1.txz: Upgraded.
xap/xscreensaver-5.35-i586-2.txz: Rebuilt.
extra/linux-4.4.12-nosmp-sdk/*: Upgraded.
Napisano: 04 Jun 2016, 08:28
Slackware 64-bit
Fri Jun 3 23:36:07 UTC 2016
ap/lxc-2.0.1-x86_64-3.txz: Rebuilt.
In /etc/inittab, use "shutdown -h now" for powerfail. Without this, lxc-stop
will send SIGPWR to attempt to stop the container, and will then force stop
it after a one minute timeout. Thanks to Andreas Vögele.
In the init scripts, wrap $container in double quotes to prevent syntax
errors if the variable is unset. Thanks to Jakub 'shasta' Jankowski.
l/libxml2-2.9.4-x86_64-2.txz: Rebuilt.
Fix attribute decoding during XML schema validation.
n/net-snmp-5.7.3-x86_64-3.txz: Rebuilt.
Include support for the ucd-snmp/diskio module.
n/ntp-4.2.8p8-x86_64-1.txz: Upgraded.
This release patches one high and four low severity security issues:
CVE-2016-4957: Crypto-NAK crash
CVE-2016-4953: Bad authentication demobilizes ephemeral associations
CVE-2016-4954: Processing spoofed server packets
CVE-2016-4955: Autokey association reset
CVE-2016-4956: Broadcast interleave
http://support.ntp.org/bin/view/Main/SecurityNotice#Recent_Vulnerabilities
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4957
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4953
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4954
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4955
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4956
xap/imagemagick-6.9.4_7-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-4.12.0-x86_64-3.txz: Rebuilt.
Blink taskbar buttons for notification 4 times, not G_MAXUINT times.
Thanks to Andrzej Telszewski.
Slackware 32-bit
ap/lxc-2.0.1-i586-3.txz: Rebuilt.
l/libxml2-2.9.4-i586-2.txz: Rebuilt.
n/net-snmp-5.7.3-i586-3.txz: Rebuilt.
n/ntp-4.2.8p8-i586-1.txz: Upgraded.
xap/imagemagick-6.9.4_7-i586-1.txz: Upgraded.
xfce/xfce4-panel-4.12.0-i586-3.txz: Rebuilt.
Napisano: 05 Jun 2016, 14:04
Slackware 64-bit
Sat Jun 4 20:56:31 UTC 2016
d/pkg-config-0.29.1-x86_64-2.txz: Rebuilt.
Added /usr/local/share/pkgconfig to $PKG_CONFIG_PATH.
Thanks to bassmadrigal.
n/nftables-0.6-x86_64-1.txz: Upgraded.
n/samba-4.4.3-x86_64-2.txz: Rebuilt.
Moved /etc/samba/private/ to /var/lib/samba/private/.
Thanks to Pierre ANDREENKO.
x/xf86-input-evdev-2.10.3-x86_64-1.txz: Upgraded.
Slackware 32-bit
d/pkg-config-0.29.1-i586-2.txz: Rebuilt.
n/nftables-0.6-i586-1.txz: Upgraded.
n/samba-4.4.3-i586-2.txz: Rebuilt.
x/xf86-input-evdev-2.10.3-i586-1.txz: Upgraded.
Users browsing this forum: No registered users and 56 guests
