Novosti u *current* -u
Post Napisano: 03 Dec 2015, 19:53
03.12.2015.
Slackware 64bit:
Thu Dec 3 07:28:30 UTC 2015
a/cpio-2.12-x86_64-1.txz: Upgraded.
a/dbus-1.10.6-x86_64-1.txz: Upgraded.
a/eudev-3.1.5-x86_64-7.txz: Rebuilt.
       In rc.udev, create static nodes with better initial permissions.
a/lvm2-2.02.136-x86_64-1.txz: Upgraded.
a/openssl-solibs-1.0.2d-x86_64-1.txz: Upgraded.
a/pkgtools-14.2-noarch-5.txz: Rebuilt.
       Set LANG=C in pkgtool.
a/tar-1.28-x86_64-1.txz: Upgraded.
ap/cups-2.1.0-x86_64-1.txz: Upgraded.
kde/kio-mtp-2063e75_20131020git-x86_64-3.txz: Rebuilt.
       Fix invalid UTF-8 sequence in slack-desc. Thanks to turtleli.
l/eigen3-3.2.7-x86_64-2.txz: Rebuilt.
       Fixed eigen3.pc include directory. Thanks to comet.berkeley.
l/freetype-2.6.2-x86_64-1.txz: Upgraded.
l/glib2-2.46.2-x86_64-2.txz: Rebuilt.
       Applied upstream patch to fix a memory leak.
l/gmp-6.1.0-x86_64-1.txz: Upgraded.
l/harfbuzz-1.1.2-x86_64-1.txz: Upgraded.
l/libmtp-1.1.10-x86_64-2.txz: Rebuilt.
       Put the udev stuff in the right directory. Thanks to yars.
l/libpng-1.6.19-x86_64-1.txz: Upgraded.
       Fixed buffer overflows in the png_set_PLTE(), png_get_PLTE(),
       png_set_tIME(), and png_convert_to_rfc1123() functions that allow
       attackers to cause a denial of service (application crash) or
       possibly have unspecified other impact via a small bit-depth value
       in an IHDR (aka image header) chunk in a PNG image.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7981
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8126.
l/librsvg-2.40.12-x86_64-1.txz: Upgraded.
n/openssl-1.0.2d-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-38.4.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/cpio-2.12-i586-1.txz: Upgraded.
a/dbus-1.10.6-i586-1.txz: Upgraded.
a/eudev-3.1.5-i586-7.txz: Rebuilt.
a/lvm2-2.02.136-i586-1.txz: Upgraded.
a/openssl-solibs-1.0.2d-i586-1.txz: Upgraded.
a/tar-1.28-i586-1.txz: Upgraded.
ap/cups-2.1.0-i586-1.txz: Upgraded.
kde/kio-mtp-2063e75_20131020git-i586-3.txz: Rebuilt.
l/eigen3-3.2.7-i586-2.txz: Rebuilt.
l/freetype-2.6.2-i586-1.txz: Upgraded.
l/glib2-2.46.2-i586-2.txz: Rebuilt.
l/gmp-6.1.0-i586-1.txz: Upgraded.
l/harfbuzz-1.1.2-i586-1.txz: Upgraded.
l/libmtp-1.1.10-i586-2.txz: Rebuilt.
l/libpng-1.6.19-i586-1.txz: Upgraded.
l/librsvg-2.40.12-i586-1.txz: Upgraded.
n/openssl-1.0.2d-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-38.4.0-i586-1.txz: Upgraded.
Post Napisano: 14 Jan 2016, 09:16
Novi update u -currentu. Najviše nas veseli ova rečenica iz ChangeLoga:
Also, enjoy a shiny new LTS 4.4.0 kernel and consider this 14.2 beta 1.
Slackware 64 bit:
Wed Jan 13 00:01:23 UTC 2016
Hey folks, happy new year!
After upgrading to BlueZ 5 recently, everything seemed to be working great,
but then it was pointed out that Bluetooth audio was no longer working.
The reason was that the newer BlueZ branch had dropped ALSA support and now
required PulseAudio. So with some trepidation, we began investigating adding
PulseAudio to Slackware. Going back to BlueZ 4 wasn't an option with various
dependent projects either having dropped support for it, or considering doing
so. After several iterations here refining the foundation packages and
recompiling and tweaking other packages to use PulseAudio, it's working well
and you'll likely not notice much of a change. But if you're using Bluetooth
audio, or needing to direct audio through HDMI, you'll probably find it a lot
easier to accomplish that.
Best of all, we're finally a modern, relevant Linux distro! ;-)
Thanks to Mario Preksavec, Heinz Wiesinger, and Robby Workman for a lot of
help and testing. Bug reports, complaints, and threats can go to me.
a/apmd-3.2.2-x86_64-3.txz: Removed.
       APM is no longer used in the shipped kernels, xapm was broken, and
       it no longer compiles. It's time to remove it.
a/etc-14.2-x86_64-5.txz: Rebuilt.
       Added user (pulse) and group (pulse) for PulseAudio.
       Added pulse user to the audio group.
a/eudev-3.1.5-x86_64-8.txz: Rebuilt.
       Blacklisted new watchdog modules (bcm7038_wdt, max63xx_wdt).
a/kernel-generic-4.4-x86_64-1.txz: Upgraded.
a/kernel-huge-4.4-x86_64-1.txz: Upgraded.
a/kernel-modules-4.4-x86_64-1.txz: Upgraded.
a/sysvinit-scripts-2.0-noarch-26.txz: Rebuilt.
       rc.M: Don't try to start apmd.
ap/alsa-utils-1.1.0-x86_64-2.txz: Rebuilt.
       Change perms on /etc/rc.d/rc.alsa to 644.
ap/ghostscript-9.18-x86_64-2.txz: Rebuilt.
       Applied upstream patch to fix missing gerrors.h.
ap/mpg123-1.22.4-x86_64-2.txz: Rebuilt.
       Add support for PulseAudio and use it for output by default.
ap/pamixer-1.3.1-x86_64-1.txz: Added.
       A command-line mixer for PulseAudio.
ap/sox-14.4.2-x86_64-2.txz: Rebuilt.
d/kernel-headers-4.4-x86-1.txz: Upgraded.
d/perl-5.22.0-x86_64-2.txz: Rebuilt.
       Added TermReadKey for MariaDB's mytop. Thanks to Larry Hajali.
       Removed dangling s2p symlinks. Thanks to DarkVision.
k/kernel-source-4.4-noarch-1.txz: Upgraded.
kde/kde-runtime-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmix-4.14.3-x86_64-3.txz: Rebuilt.
l/alsa-lib-1.1.0-x86_64-2.txz: Rebuilt.
       Added a default /etc/asound.conf redirecting ALSA output to PulseAudio.
l/alsa-plugins-1.1.0-x86_64-1.txz: Added.
       This provides a plugin to redirect ALSA output to PulseAudio.
l/atkmm-2.24.2-x86_64-1.txz: Added.
l/cairomm-1.12.0-x86_64-1.txz: Added.
l/glibmm-2.46.3-x86_64-1.txz: Added.
l/gst-plugins-good-1.6.2-x86_64-2.txz: Rebuilt.
l/gst-plugins-good0-0.10.31-x86_64-2.txz: Rebuilt.
l/gtkmm3-3.18.0-x86_64-1.txz: Added.
l/json-c-0.12-x86_64-1.txz: Added.
       This is needed by PulseAudio.
l/keybinder-0.3.1-x86_64-1.txz: Upgraded.
       Add support for GTK+3, which is needed by xfce4-pulseaudio-plugin to grab
       multimedia keys.
l/libao-1.2.0-x86_64-2.txz: Rebuilt.
l/libasyncns-0.8-x86_64-1.txz: Added.
l/libcanberra-0.30-x86_64-4.txz: Rebuilt.
l/libsigc++-2.6.2-x86_64-1.txz: Added.
l/pangomm-2.38.1-x86_64-1.txz: Added.
l/phonon-4.8.3-x86_64-2.txz: Rebuilt.
l/pulseaudio-7.1-x86_64-1.txz: Added.
l/qt-4.8.7-x86_64-3.txz: Rebuilt.
       Make sure that .pc and .la files use $LIBDIRSUFFIX in the X11 library path.
       Thanks to Dhaby Xiloj.
l/sdl-1.2.15-x86_64-3.txz: Rebuilt.
l/seamonkey-solibs-2.39-x86_64-2.txz: Rebuilt.
l/speexdsp-1.2rc3-x86_64-1.txz: Added.
l/xapian-core-1.2.22-x86_64-1.txz: Upgraded.
n/NetworkManager-1.0.10-x86_64-2.txz: Rebuilt.
       Added patches from the upstream stable git branch.
       Added back the pm-utils hook.
       Thanks to Robby Workman.
n/bluez-5.37-x86_64-1.txz: Upgraded.
n/dhcp-4.3.3_P1-x86_64-1.txz: Upgraded.
       This update fixes a denial-of-service vulnerability.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8605
n/dirmngr-1.1.1-x86_64-3.txz: Rebuilt.
       Patched to fix problems when using libgcrypt-1.6.x. Thanks to xflow7.
n/inetd-1.79s-x86_64-9.txz: Rebuilt.
       Patched segfault of daytime. Thanks to tfonz.
x/libdrm-2.4.66-x86_64-1.txz: Upgraded.
x/xf86-input-evdev-2.10.1-x86_64-1.txz: Upgraded.
x/xf86-video-amdgpu-1.0.0-x86_64-1.txz: Added.
x/xf86-video-modesetting-0.9.0-x86_64-5.txz: Removed.
       This driver has been incorporated into the xorg-server package.
       Thanks to ReaperX.
x/xorg-cf-files-1.0.6-x86_64-2.txz: Rebuilt.
       Don't use noarch. Thanks to DarkVision.
xap/MPlayer-20150721-x86_64-4.txz: Rebuilt.
xap/audacious-3.7.1-x86_64-1.txz: Upgraded.
xap/audacious-plugins-3.7.1-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-43.0.4-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-38.5.1-x86_64-1.txz: Upgraded.
xap/pavucontrol-3.0-x86_64-1.txz: Added.
       A mixer for PulseAudio. Requires the GTKmm stack.
xap/seamonkey-2.39-x86_64-2.txz: Rebuilt.
xap/xine-lib-1.2.6-x86_64-6.txz: Rebuilt.
xfce/Thunar-1.6.10-x86_64-3.txz: Rebuilt.
       Fix some crashes that occur with file moves.
       Thanks to Jean-Philippe Guillemin.
xfce/xfce4-mixer-4.10.0-x86_64-2.txz: Removed.
       Replaced by xfce4-pulseaudio-plugin.
xfce/xfce4-power-manager-1.4.4-x86_64-3.txz: Rebuilt.
       Don't include NetworkManager; let pm-utils handle it.
xfce/xfce4-pulseaudio-plugin-0.2.4-x86_64-1.txz: Added.
       This replaces xfce4-mixer and xfce4-volumed.
xfce/xfce4-volumed-0.1.13-x86_64-3.txz: Removed.
extra/bash-completion/bash-completion-2.1-noarch-4.txz: Rebuilt.
       Corrected information in slack-desc. Thanks to Arkadiusz Drabczyk.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
pasture/apmd-3.2.2-x86_64-3.txz: Moved to /pasture.
Slackware 32 bit:
a/apmd-3.2.2-i486-3.txz: Removed.
a/etc-14.2-i586-5.txz: Rebuilt.
a/eudev-3.1.5-i586-8.txz: Rebuilt.
a/kernel-generic-4.4-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.4_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.4-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.4_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.4-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.4_smp-i686-1.txz: Upgraded.
ap/alsa-utils-1.1.0-i586-2.txz: Rebuilt.
ap/ghostscript-9.18-i586-2.txz: Rebuilt.
ap/mpg123-1.22.4-i586-2.txz: Rebuilt.
ap/pamixer-1.3.1-i586-1.txz: Added.
ap/sox-14.4.2-i586-2.txz: Rebuilt.
d/kernel-headers-4.4_smp-x86-1.txz: Upgraded.
d/perl-5.22.0-i586-2.txz: Rebuilt.
k/kernel-source-4.4_smp-noarch-1.txz: Upgraded.
kde/kde-runtime-4.14.3-i586-3.txz: Rebuilt.
kde/kmix-4.14.3-i586-3.txz: Rebuilt.
l/alsa-lib-1.1.0-i586-2.txz: Rebuilt.
l/alsa-plugins-1.1.0-i586-1.txz: Added.
l/atkmm-2.24.2-i586-1.txz: Added.
l/cairomm-1.12.0-i586-1.txz: Added.
l/glibmm-2.46.3-i586-1.txz: Added.
l/gst-plugins-good-1.6.2-i586-2.txz: Rebuilt.
l/gst-plugins-good0-0.10.31-i586-2.txz: Rebuilt.
l/gtkmm3-3.18.0-i586-1.txz: Added.
l/json-c-0.12-i586-1.txz: Added.
l/keybinder-0.3.1-i586-1.txz: Upgraded.
       multimedia keys.
l/libao-1.2.0-i586-2.txz: Rebuilt.
l/libasyncns-0.8-i586-1.txz: Added.
l/libcanberra-0.30-i586-4.txz: Rebuilt.
l/libsigc++-2.6.2-i586-1.txz: Added.
l/pangomm-2.38.1-i586-1.txz: Added.
l/phonon-4.8.3-i586-2.txz: Rebuilt.
l/pulseaudio-7.1-i586-1.txz: Added.
l/qt-4.8.7-i586-3.txz: Rebuilt.
l/sdl-1.2.15-i586-3.txz: Rebuilt.
l/seamonkey-solibs-2.39-i586-2.txz: Rebuilt.
l/speexdsp-1.2rc3-i586-1.txz: Added.
l/xapian-core-1.2.22-i586-1.txz: Upgraded.
n/NetworkManager-1.0.10-i586-2.txz: Rebuilt.
n/bluez-5.37-i586-1.txz: Upgraded.
n/dhcp-4.3.3_P1-i586-1.txz: Upgraded.
n/dirmngr-1.1.1-i586-3.txz: Rebuilt.
n/inetd-1.79s-i586-9.txz: Rebuilt.
x/libdrm-2.4.66-i586-1.txz: Upgraded.
x/xf86-input-evdev-2.10.1-i586-1.txz: Upgraded.
x/xf86-video-amdgpu-1.0.0-i586-1.txz: Added.
x/xf86-video-modesetting-0.9.0-i586-5.txz: Removed.
       Thanks to ReaperX.
x/xorg-cf-files-1.0.6-i586-2.txz: Rebuilt.
xap/MPlayer-20150721-i586-4.txz: Rebuilt.
xap/audacious-3.7.1-i586-1.txz: Upgraded.
xap/audacious-plugins-3.7.1-i586-1.txz: Upgraded.
xap/mozilla-firefox-43.0.4-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-38.5.1-i586-1.txz: Upgraded.
xap/pavucontrol-3.0-i586-1.txz: Added.
xap/seamonkey-2.39-i586-2.txz: Rebuilt.
xap/xine-lib-1.2.6-i586-6.txz: Rebuilt.
xfce/Thunar-1.6.10-i586-3.txz: Rebuilt.
xfce/xfce4-mixer-4.10.0-i586-2.txz: Removed.
xfce/xfce4-power-manager-1.4.4-i586-3.txz: Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.2.4-i586-1.txz: Added.
xfce/xfce4-volumed-0.1.13-i586-3.txz: Removed.
extra/linux-4.4-nosmp-sdk/*: Upgraded.
pasture/apmd-3.2.2-i486-3.txz: Moved to /pasture.
Post Napisano: 15 Jan 2016, 09:25
Slackware 64 bit:
Fri Jan 15 02:29:54 UTC 2016
l/gtkmm2-2.24.4-x86_64-1.txz: Added.
n/openssh-7.1p2-x86_64-1.txz: Upgraded.
       This update fixes an information leak and a buffer overflow. In particular,
       the information leak allows a malicious SSH server to steal the client's
       private keys. Thanks to Qualys for reporting this issue.
       https://www.qualys.com/2016/01/14/cve-2016-0777-cve-2016-0778/openssh-cve-2016-0777-cve-2016-0778.txt
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0777
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0778
Slackware 32 bit:
l/gtkmm2-2.24.4-i586-1.txz: Added.
n/openssh-7.1p2-i586-1.txz: Upgraded.
Post Napisano: 18 Jan 2016, 00:48
Slackware 64 bit
Sun Jan 17 07:24:08 UTC 2016
a/sysvinit-scripts-2.0-noarch-27.txz: Upgraded.
       rc.M: If rc.pulseaudio is executable, run it (not recommended though).
ap/alsa-utils-1.1.0-x86_64-3.txz: Rebuilt.
       On a fresh system, install rc.alsa as executable. It's apparently still
       useful for loading some mixer defaults even when PulseAudio is used.
ap/cups-filters-1.6.0-x86_64-1.txz: Upgraded.
ap/gutenprint-5.2.11-x86_64-1.txz: Upgraded.
ap/lxc-1.1.5-x86_64-2.txz: Rebuilt.
       Fixed failed rc.M patch with lxc-create, and rebased against recent scripts.
       Thanks to Jakub Jankowski.
ap/mpg123-1.22.4-x86_64-3.txz: Rebuilt.
       Don't depend on libpulsecommon-7.1.
ap/sox-14.4.2-x86_64-3.txz: Rebuilt.
d/llvm-3.7.1-x86_64-1.txz: Upgraded.
kde/calligra-2.9.10-x86_64-1.txz: Upgraded.
kdei/calligra-l10n-bs-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-ca-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-ca@valencia-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-cs-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-da-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-de-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-el-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-en_GB-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-es-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-et-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-fi-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-fr-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-gl-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-hu-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-it-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-ja-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-kk-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-nb-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-nl-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-pl-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-pt-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-pt_BR-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-ru-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-sk-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-sv-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-tr-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-uk-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-zh_CN-2.9.10-noarch-1.txz: Upgraded.
kdei/calligra-l10n-zh_TW-2.9.10-noarch-1.txz: Upgraded.
l/a52dec-0.7.4-x86_64-2.txz: Rebuilt.
       Include a52_internal.h header. Thanks to Johannes Schöpfer.
l/alsa-plugins-1.1.0-x86_64-2.txz: Rebuilt.
l/libao-1.2.0-x86_64-3.txz: Rebuilt.
l/libcanberra-0.30-x86_64-5.txz: Rebuilt.
l/poppler-0.40.0-x86_64-1.txz: Upgraded.
l/pulseaudio-7.1-x86_64-2.txz: Rebuilt.
       Removed .la files to avoid linking things to libpulsecommon-7.1.
       Thanks to chrisVV.
       If autospawn is off, start the daemon manually in start-pulseaudio-x11.
       And yes, if you're allergic to PulseAudio that means you might also need to
       disable /etc/xdg/autostart/pulseaudio.desktop...
n/NetworkManager-1.0.10-x86_64-3.txz: Rebuilt.
       Fixed build script to properly apply the patches.
       Thanks to K4rolis and rworkman.
n/bluez-hcidump-2.5-x86_64-1.txz: Removed.
       hcidump is included in the main bluez package.
       Thanks to Audrius Kazukauskas.
x/mesa-11.1.1-x86_64-1.txz: Upgraded.
x/xf86-input-vmmouse-13.1.0-x86_64-4.txz: Rebuilt.
       Put udev rules in correct directory. Thanks to chrisVV.
x/xf86-video-vmware-13.1.0-x86_64-6.txz: Rebuilt.
xfce/tumbler-0.1.31-x86_64-4.txz: Rebuilt.
Slackware 32 bit
ap/alsa-utils-1.1.0-i586-3.txz: Rebuilt.
ap/cups-filters-1.6.0-i586-1.txz: Upgraded.
ap/gutenprint-5.2.11-i586-1.txz: Upgraded.
ap/lxc-1.1.5-i586-2.txz: Rebuilt.
ap/mpg123-1.22.4-i586-3.txz: Rebuilt.
ap/sox-14.4.2-i586-3.txz: Rebuilt.
d/llvm-3.7.1-i586-1.txz: Upgraded.
kde/calligra-2.9.10-i586-1.txz: Upgraded.
l/a52dec-0.7.4-i586-2.txz: Rebuilt.
l/alsa-plugins-1.1.0-i586-2.txz: Rebuilt.
l/libao-1.2.0-i586-3.txz: Rebuilt.
l/libcanberra-0.30-i586-5.txz: Rebuilt.
l/poppler-0.40.0-i586-1.txz: Upgraded.
l/pulseaudio-7.1-i586-2.txz: Rebuilt.
       Thanks to chrisVV.
n/NetworkManager-1.0.10-i586-3.txz: Rebuilt.
n/bluez-hcidump-2.5-i486-1.txz: Removed.
x/mesa-11.1.1-i586-1.txz: Upgraded.
x/xf86-input-vmmouse-13.1.0-i586-4.txz: Rebuilt.
x/xf86-video-vmware-13.1.0-i586-6.txz: Rebuilt.
xfce/tumbler-0.1.31-i586-4.txz: Rebuilt.
Post Napisano: 04 Feb 2016, 07:33
03.02.2016.
Slackware 14.2 Beta 2 :)
64bit:
Wed Feb 3 22:39:25 UTC 2016
Welcome to Slackware 14.2 beta 2. Getting closer. :-)
a/coreutils-8.25-x86_64-1.txz: Upgraded.
a/glibc-zoneinfo-2016a-noarch-1.txz: Upgraded.
a/kernel-firmware-20160201git-noarch-1.txz: Upgraded.
a/kernel-generic-4.4.1-x86_64-1.txz: Upgraded.
a/kernel-huge-4.4.1-x86_64-1.txz: Upgraded.
a/kernel-modules-4.4.1-x86_64-1.txz: Upgraded.
a/lvm2-2.02.141-x86_64-1.txz: Upgraded.
a/openssl-solibs-1.0.2f-x86_64-1.txz: Upgraded.
a/sysvinit-scripts-2.0-noarch-28.txz: Rebuilt.
       rc.6: Change command variable to shutdown_command to avoid conflicting with
       a same-named variable in rc.networkmanager. Thanks to Antonio Maretzek.
       Added new script rc.cpufreq to set CPU frequency scaling.
       If executable, it will be run from rc.M.
ap/cups-filters-1.8.1-x86_64-1.txz: Upgraded.
ap/dmidecode-3.0-x86_64-1.txz: Upgraded.
ap/gutenprint-5.2.11-x86_64-2.txz: Rebuilt.
       Run cups-genppdupdate after installing. Thanks to Lukasz Wieczorek.
ap/soma-2.10.4-noarch-1.txz: Upgraded.
d/binutils-2.26-x86_64-1.txz: Upgraded.
d/cmake-3.4.3-x86_64-1.txz: Upgraded.
d/kernel-headers-4.4.1-x86-1.txz: Upgraded.
d/mercurial-3.6.3-x86_64-1.txz: Upgraded.
d/oprofile-1.1.0-x86_64-1.txz: Upgraded.
d/python-setuptools-19.6-x86_64-1.txz: Upgraded.
k/kernel-source-4.4.1-noarch-1.txz: Upgraded.
       CPU_FREQ_DEFAULT_GOV_ONDEMAND n -> y
       CPU_FREQ_DEFAULT_GOV_USERSPACE y -> n
       CPU_FREQ_GOV_CONSERVATIVE m -> y
       CPU_FREQ_GOV_ONDEMAND m -> y
       CPU_FREQ_GOV_PERFORMANCE m -> y
       CPU_FREQ_GOV_POWERSAVE m -> y
l/gst-plugins-base-1.6.3-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.6.3-x86_64-1.txz: Upgraded.
l/gstreamer-1.6.3-x86_64-1.txz: Upgraded.
l/gtk+2-2.24.29-x86_64-2.txz: Rebuilt.
       In /usr/share/gtk-2.0/gtkrc, specify Adwaita as the icon theme, and Tango as
       a fallback. This fixes icon issues when using fluxbox and other more basic
       window managers. Thanks to schmatzler and dTd.
l/gtk+3-3.18.7-x86_64-1.txz: Upgraded.
l/harfbuzz-1.1.3-x86_64-1.txz: Upgraded.
l/librsvg-2.40.13-x86_64-1.txz: Upgraded.
l/pulseaudio-8.0-x86_64-1.txz: Upgraded.
       Set "flat-volumes = no" in daemon.conf.new by default.
l/seamonkey-solibs-2.39-x86_64-3.txz: Rebuilt.
n/openssl-1.0.2f-x86_64-1.txz: Upgraded.
       This update fixes the following security issues:
       DH small subgroups (CVE-2016-0701).
       SSLv2 doesn't block disabled ciphers (CVE-2015-3197).
       https://openssl.org/news/secadv/20160128.txt
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-3197
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0701
n/php-5.6.17-x86_64-1.txz: Upgraded.
       This release fixes security issues.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1903
n/proftpd-1.3.5a-x86_64-1.txz: Upgraded.
n/traceroute-2.0.21-x86_64-1.txz: Upgraded.
x/xterm-322-x86_64-1.txz: Upgraded.
xap/MPlayer-1.2_20160125-x86_64-1.txz: Upgraded.
       This is the latest MPlayer-1.2 branch, identical to the 1.2.1 stable release.
       The bundled ffmpeg has been upgraded to 2.8.5, which fixes two security
       issues by which a remote attacker may conduct a cross-origin attack and read
       arbitrary files on the system.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1897
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1898
xap/gparted-0.25.0-x86_64-1.txz: Added.
       Thanks to Erik W. Hanson.
xap/hexchat-2.10.2-x86_64-1.txz: Added.
       This package replaces xchat.
xap/mozilla-firefox-44.0-x86_64-1.txz: Upgraded.
       This compiles properly with -O2 optimization again.
xap/pidgin-2.10.12-x86_64-1.txz: Upgraded.
xap/seamonkey-2.39-x86_64-3.txz: Rebuilt.
       Recompiled with -Os optimization to fix random crashes.
xap/xchat-2.8.8-x86_64-11.txz: Removed.
xap/xine-lib-1.2.6-x86_64-7.txz: Rebuilt.
       Rebuilt against ffmpeg-2.8.5, which fixes two security issues by which a
       remote attacker may conduct a cross-origin attack and read arbitrary files
       on the system.
32bit:
a/coreutils-8.25-i586-1.txz: Upgraded.
a/kernel-generic-4.4.1-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.4.1_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.4.1-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.4.1_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.4.1-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.4.1_smp-i686-1.txz: Upgraded.
a/lvm2-2.02.141-i586-1.txz: Upgraded.
a/openssl-solibs-1.0.2f-i586-1.txz: Upgraded.
       Added new script rc.cpufreq to enable CPU frequency scaling.
ap/cups-filters-1.8.1-i586-1.txz: Upgraded.
ap/dmidecode-3.0-i586-1.txz: Upgraded.
ap/gutenprint-5.2.11-i586-2.txz: Rebuilt.
d/binutils-2.26-i586-1.txz: Upgraded.
d/cmake-3.4.3-i586-1.txz: Upgraded.
d/kernel-headers-4.4.1_smp-x86-1.txz: Upgraded.
d/mercurial-3.6.3-i586-1.txz: Upgraded.
d/oprofile-1.1.0-i586-1.txz: Upgraded.
d/python-setuptools-19.6-i586-1.txz: Upgraded.
k/kernel-source-4.4.1_smp-noarch-1.txz: Upgraded.
l/gst-plugins-base-1.6.3-i586-1.txz: Upgraded.
l/gst-plugins-good-1.6.3-i586-1.txz: Upgraded.
l/gstreamer-1.6.3-i586-1.txz: Upgraded.
l/gtk+2-2.24.29-i586-2.txz: Rebuilt.
l/gtk+3-3.18.7-i586-1.txz: Upgraded.
l/harfbuzz-1.1.3-i586-1.txz: Upgraded.
l/librsvg-2.40.13-i586-1.txz: Upgraded.
l/pulseaudio-8.0-i586-1.txz: Upgraded.
l/seamonkey-solibs-2.39-i586-3.txz: Rebuilt.
n/openssl-1.0.2f-i586-1.txz: Upgraded.
n/php-5.6.17-i586-1.txz: Upgraded.
n/proftpd-1.3.5a-i586-1.txz: Upgraded.
n/traceroute-2.0.21-i586-1.txz: Upgraded.
x/xterm-322-i586-1.txz: Upgraded.
xap/MPlayer-1.2_20160125-i586-1.txz: Upgraded.
xap/gparted-0.25.0-i586-1.txz: Added.
xap/hexchat-2.10.2-i586-1.txz: Added.
xap/mozilla-firefox-44.0-i586-1.txz: Upgraded.
xap/pidgin-2.10.12-i586-1.txz: Upgraded.
xap/seamonkey-2.39-i586-3.txz: Rebuilt.
xap/xchat-2.8.8-i586-11.txz: Removed.
xap/xine-lib-1.2.6-i586-7.txz: Rebuilt.
       on the system.
extra/linux-4.4.1-nosmp-sdk/*: Upgraded.
Post Napisano: 09 Feb 2016, 19:18
08.02.2016.
Slackware 64bit:
Mon Feb 8 22:08:35 UTC 2016
a/mkinitrd-1.4.8-x86_64-5.txz: Rebuilt.
       Blacklisted rules.d/60-openobex.rules to prevent error messages at boot.
       Thanks to Eric Hameleers.
ap/cups-2.1.3-x86_64-1.txz: Upgraded.
ap/ghostscript-9.07-x86_64-3.txz: Rebuilt.
       Reverted back to ghostscript-9.07, since any newer version causes the GIMP
       ps plugin to crash when attempting to import a .ps or .eps file. Whatever
       is causing the problem happened between gs-9.07 and gs-9.09, and is probably
       also dependent on the libraries in use and perhaps the compiler, since some
       other distributions appear to be using the latest ghostscript without issues.
       If anyone can figure it out, hints are welcome. Meanwhile this gets
       everything working again.
d/gcc-5.3.0-x86_64-2.txz: Rebuilt.
       Patched to fix internal compiler error building Wine.
       Thanks to Kirill Smirnov.
d/gcc-g++-5.3.0-x86_64-2.txz: Rebuilt.
d/gcc-gfortran-5.3.0-x86_64-2.txz: Rebuilt.
d/gcc-gnat-5.3.0-x86_64-2.txz: Rebuilt.
d/gcc-go-5.3.0-x86_64-2.txz: Rebuilt.
d/gcc-java-5.3.0-x86_64-2.txz: Rebuilt.
d/gcc-objc-5.3.0-x86_64-2.txz: Rebuilt.
l/libsndfile-1.0.26-x86_64-1.txz: Upgraded.
       This release fixes security issues which may allow attackers to cause
       a denial of service, or possibly execute arbitrary code.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-9496
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-9756
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7805
l/loudmouth-1.5.2-x86_64-1.txz: Upgraded.
n/curl-7.47.1-x86_64-1.txz: Upgraded.
       This update fixes a security issue where NTLM credentials are not checked
       for proxy connection reuse. The effects of this flaw is that the application
       could be reusing a proxy connection using the previously used credentials
       and thus it could be given to or prevented access from resources that it
       wasn't intended to. Thanks to Isaac Boukris.
       https://curl.haxx.se/docs/adv_20160127A.html
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0755
n/mcabber-1.0.1-x86_64-1.txz: Upgraded.
n/stunnel-5.30-x86_64-1.txz: Upgraded.
x/xf86-video-intel-git_20160208_8b8c9a3-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-44.0.1-x86_64-1.txz: Upgraded.
extra/wicd/wicd-1.7.4-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/mkinitrd-1.4.8-i486-5.txz: Rebuilt.
ap/cups-2.1.3-i586-1.txz: Upgraded.
ap/ghostscript-9.07-i586-3.txz: Rebuilt.
d/gcc-5.3.0-i586-2.txz: Rebuilt.
d/gcc-g++-5.3.0-i586-2.txz: Rebuilt.
d/gcc-gfortran-5.3.0-i586-2.txz: Rebuilt.
d/gcc-gnat-5.3.0-i586-2.txz: Rebuilt.
d/gcc-go-5.3.0-i586-2.txz: Rebuilt.
d/gcc-java-5.3.0-i586-2.txz: Rebuilt.
d/gcc-objc-5.3.0-i586-2.txz: Rebuilt.
l/libsndfile-1.0.26-i586-1.txz: Upgraded.
l/loudmouth-1.5.2-i586-1.txz: Upgraded.
n/curl-7.47.1-i586-1.txz: Upgraded.
n/mcabber-1.0.1-i586-1.txz: Upgraded.
n/stunnel-5.30-i586-1.txz: Upgraded.
x/xf86-video-intel-git_20160208_8b8c9a3-i586-1.txz: Upgraded.
xap/mozilla-firefox-44.0.1-i586-1.txz: Upgraded.
extra/wicd/wicd-1.7.4-i586-1.txz: Upgraded.
Post Napisano: 12 Feb 2016, 20:34
11.02.2016.
Slackware 64bit:
Thu Feb 11 21:56:21 UTC 2016
a/sysvinit-scripts-2.0-noarch-29.txz: Rebuilt.
       rc.S: Avoid mounting /dev/shm twice.
       Thanks to Andrzej Telszewski and GazL.
       rc.6, rc.K: Match 'type nfs ' rather than 'type nfs' to avoid false hits
       (and error messages) from matching nfsd pseudo-filesystems.
       Thanks to Jonathan Woithe.
ap/hplip-3.16.2-x86_64-1.txz: Upgraded.
ap/htop-2.0.0-x86_64-1.txz: Upgraded.
l/freetype-2.6.3-x86_64-1.txz: Upgraded.
l/libcap-ng-0.7.7-x86_64-1.txz: Added.
       This is needed by mount.cifs in order to support making it setuid so that
       normal users can mount remote CIFS partitions. And it is expected that
       other programs will begin to use it in preference to the older libcap.
n/cifs-utils-6.4-x86_64-2.txz: Rebuilt.
       Recompiled against libcap-ng. Now mount.cifs will work for normal users
       if setuid root. By default, mount.cifs remains NOT setuid root, though.
x/pixman-0.34.0-x86_64-1.txz: Upgraded.
x/xf86-video-r128-6.10.1-x86_64-1.txz: Upgraded.
x/xorg-server-1.18.1-x86_64-1.txz: Upgraded.
x/xorg-server-xephyr-1.18.1-x86_64-1.txz: Upgraded.
x/xorg-server-xnest-1.18.1-x86_64-1.txz: Upgraded.
x/xorg-server-xvfb-1.18.1-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-44.0.2-x86_64-1.txz: Upgraded.
Slackware 32bit:
ap/hplip-3.16.2-i586-1.txz: Upgraded.
ap/htop-2.0.0-i586-1.txz: Upgraded.
l/freetype-2.6.3-i586-1.txz: Upgraded.
l/libcap-ng-0.7.7-i586-1.txz: Added.
n/cifs-utils-6.4-i586-2.txz: Rebuilt.
x/pixman-0.34.0-i586-1.txz: Upgraded.
x/xf86-video-geode-2.11.18-i586-1.txz: Upgraded.
x/xf86-video-r128-6.10.1-i586-1.txz: Upgraded.
x/xorg-server-1.18.1-i586-1.txz: Upgraded.
x/xorg-server-xephyr-1.18.1-i586-1.txz: Upgraded.
x/xorg-server-xnest-1.18.1-i586-1.txz: Upgraded.
x/xorg-server-xvfb-1.18.1-i586-1.txz: Upgraded.
xap/mozilla-firefox-44.0.2-i586-1.txz: Upgraded.
Post Napisano: 17 Feb 2016, 15:36
14.02.2016.
Slackware 64bit:
Sun Feb 14 19:40:04 UTC 2016
xap/mozilla-thunderbird-38.6.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
xap/mozilla-thunderbird-38.6.0-i586-1.txz: Upgraded.
Post Napisano: 24 Feb 2016, 17:56
23.02.2016.
Slackware 64bit:
Tue Feb 23 19:31:59 UTC 2016
a/glibc-solibs-2.23-x86_64-1.txz: Upgraded.
a/kernel-generic-4.4.2-x86_64-1.txz: Upgraded.
a/kernel-huge-4.4.2-x86_64-1.txz: Upgraded.
a/kernel-modules-4.4.2-x86_64-1.txz: Upgraded.
a/procps-ng-3.3.10-x86_64-5.txz: Rebuilt.
       Restored FROM field in w. Thanks to Stuart Winter.
ap/cups-2.1.3-x86_64-2.txz: Rebuilt.
       Corrected CXXFLAGS to fix build for older CPUs. Thanks to ecd102.
ap/mc-4.8.15-x86_64-2.txz: Rebuilt.
       Patched to fix displaying man pages. Thanks to DarkVision.
d/kernel-headers-4.4.2-x86-1.txz: Upgraded.
k/kernel-source-4.4.2-noarch-1.txz: Upgraded.
       Key .config changes for this kernel update:
       CHECKPOINT_RESTORE n -> y
       DEBUG_KERNEL n -> y
       EXPERT n -> y
       NR_CPUS 128 -> 256
       KALLSYMS_ALL y
       LIVEPATCH y
l/GConf-3.2.6-x86_64-3.txz: Rebuilt.
       Patched "GConf-WARNING **: Client failed to connect to the D-BUS daemon:"
       and added a couple other patches from git. Thanks to Robby Workman.
l/alsa-lib-1.1.0-x86_64-3.txz: Rebuilt.
       Changed the default /etc/asound.conf.new to use a different configuration
       for PulseAudio that is less likely to cause issues than the previous one,
       especially on machines where the analog output is not recognized as card 0
       by the BIOS. Thanks to Ryan P.C. McQuen who went above and beyond on this
       bug report by convincing upstream to recommend this on their website in
       order to convince me to make the change. :-)
l/glibc-2.23-x86_64-1.txz: Upgraded.
       Of the security fixes, the most important and well-publicized is the
       stack-based buffer overflow in libresolv that could allow specially
       crafted DNS responses to seize control of execution flow in the DNS
       client (CVE-2015-7547). However, due to a patch applied to Slackware's
       glibc back in 2009 (don't use the gethostbyname4() lookup method as it
       was causing some cheap routers to misbehave), we were not vulnerable to
       that issue. The rest of the fixed security issues are less critical.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8776
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8777
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8778
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8779
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-9761
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7547
l/glibc-i18n-2.23-x86_64-1.txz: Upgraded.
l/glibc-profile-2.23-x86_64-1.txz: Upgraded.
l/libproxy-0.4.12-x86_64-1.txz: Upgraded.
n/bind-9.10.3_P3-x86_64-1.txz: Upgraded.
       This release fixes two possible denial-of-service issues:
       render_ecs errors were mishandled when printing out a OPT record resulting
       in a assertion failure. (CVE-2015-8705) [RT #41397]
       Specific APL data could trigger a INSIST. (CVE-2015-8704) [RT #41396]
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8704
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8705
n/libgcrypt-1.6.5-x86_64-1.txz: Upgraded.
       Mitigate side-channel attack on ECDH with Weierstrass curves.
       http://www.cs.tau.ac.IL/~tromer/ecdh/
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7511
n/nmap-7.01-x86_64-1.txz: Upgraded.
n/ntp-4.2.8p6-x86_64-1.txz: Upgraded.
       In addition to bug fixes and enhancements, this release fixes
       several low and medium severity vulnerabilities.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5300
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7973
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7974
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7975
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7976
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7977
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7978
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7979
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8138
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8158
x/xf86-video-amdgpu-1.0.1-x86_64-1.txz: Upgraded.
xap/blueman-2.0.3-x86_64-2.txz: Rebuilt.
       Rewrite launcher scripts to use #!/usr/bin/python2.7 rather than
       #!/usr/bin/env python.
       For details, see: https://github.com/blueman-project/blueman/issues/435
       Thanks to zakame and Robby Workman.
extra/tigervnc/tigervnc-1.6.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/glibc-solibs-2.23-i586-1.txz: Upgraded.
a/kernel-generic-4.4.2-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.4.2_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.4.2-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.4.2_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.4.2-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.4.2_smp-i686-1.txz: Upgraded.
a/procps-ng-3.3.10-i586-5.txz: Rebuilt.
ap/cups-2.1.3-i586-2.txz: Rebuilt.
ap/mc-4.8.15-i586-2.txz: Rebuilt.
d/kernel-headers-4.4.2_smp-x86-1.txz: Upgraded.
k/kernel-source-4.4.2_smp-noarch-1.txz: Upgraded.
       DEBUG_KERNEL n -> y
       EXPERT n -> y
       KALLSYMS_ALL y
l/GConf-3.2.6-i586-3.txz: Rebuilt.
l/alsa-lib-1.1.0-i586-3.txz: Rebuilt.
l/glibc-2.23-i586-1.txz: Upgraded.
l/glibc-i18n-2.23-i586-1.txz: Upgraded.
l/glibc-profile-2.23-i586-1.txz: Upgraded.
l/libproxy-0.4.12-i586-1.txz: Upgraded.
n/bind-9.10.3_P3-i586-1.txz: Upgraded.
n/libgcrypt-1.6.5-i586-1.txz: Upgraded.
n/nmap-7.01-i586-1.txz: Upgraded.
n/ntp-4.2.8p6-i586-1.txz: Upgraded.
x/xf86-video-amdgpu-1.0.1-i586-1.txz: Upgraded.
xap/blueman-2.0.3-i586-2.txz: Rebuilt.
extra/linux-4.4.2-nosmp-sdk/*: Upgraded.
extra/tigervnc/tigervnc-1.6.0-i586-1.txz: Upgraded.
Post Napisano: 27 Feb 2016, 13:01
26.02.2016.
Slackware 64bit:
Fri Feb 26 22:54:05 UTC 2016
a/btrfs-progs-v4.4.1-x86_64-1.txz: Upgraded.
a/kernel-generic-4.4.3-x86_64-1.txz: Upgraded.
a/kernel-huge-4.4.3-x86_64-1.txz: Upgraded.
a/kernel-modules-4.4.3-x86_64-1.txz: Upgraded.
a/sdparm-1.10-x86_64-1.txz: Upgraded.
ap/mariadb-10.0.24-x86_64-1.txz: Upgraded.
d/gdb-7.11-x86_64-1.txz: Upgraded.
d/kernel-headers-4.4.3-x86-1.txz: Upgraded.
k/kernel-source-4.4.3-noarch-1.txz: Upgraded.
kde/kdepimlibs-4.14.10-x86_64-2.txz: Rebuilt.
       Recompiled against libical-2.0.0.
l/gtk+3-3.18.8-x86_64-1.txz: Upgraded.
l/libical-2.0.0-x86_64-1.txz: Upgraded.
l/libssh-0.7.3-x86_64-1.txz: Upgraded.
       Fixed weak key generation. Due to a bug in the ephemeral secret key
       generation for the diffie-hellman-group1 and diffie-hellman-group14
       methods, ephemeral secret keys of size 128 bits are generated, instead
       of the recommended sizes of 1024 and 2048 bits, giving a practical
       security of 63 bits.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0739
l/sg3_utils-1.42-x86_64-1.txz: Upgraded.
n/bluez-5.37-x86_64-2.txz: Rebuilt.
n/libssh2-1.7.0-x86_64-1.txz: Upgraded.
       Fixed weak key generation. During the SSHv2 handshake when libssh2 is to
       get a suitable value for 'group order' in the Diffle Hellman negotiation,
       it would pass in number of bytes to a function that expected number of bits.
       This would result in the library generating numbers using only an 8th the
       number of random bits than what were intended: 128 or 256 bits instead of
       1023 or 2047. Using such drastically reduced amount of random bits for
       Diffie Hellman weakended the handshake security significantly.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0787
x/mesa-11.1.2-x86_64-1.txz: Upgraded.
xfce/orage-4.12.1-x86_64-3.txz: Rebuilt.
Slackware 32bit:
a/btrfs-progs-v4.4.1-i586-1.txz: Upgraded.
a/kernel-generic-4.4.3-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.4.3_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.4.3-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.4.3_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.4.3-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.4.3_smp-i686-1.txz: Upgraded.
a/sdparm-1.10-i586-1.txz: Upgraded.
ap/mariadb-10.0.24-i586-1.txz: Upgraded.
d/gdb-7.11-i586-1.txz: Upgraded.
d/kernel-headers-4.4.3_smp-x86-1.txz: Upgraded.
k/kernel-source-4.4.3_smp-noarch-1.txz: Upgraded.
kde/kdepimlibs-4.14.10-i586-2.txz: Rebuilt.
l/gtk+3-3.18.8-i586-1.txz: Upgraded.
l/libical-2.0.0-i586-1.txz: Upgraded.
l/libssh-0.7.3-i586-1.txz: Upgraded.
l/sg3_utils-1.42-i586-1.txz: Upgraded.
n/bluez-5.37-i586-2.txz: Rebuilt.
n/libssh2-1.7.0-i586-1.txz: Upgraded.
x/mesa-11.1.2-i586-1.txz: Upgraded.
xfce/orage-4.12.1-i586-3.txz: Rebuilt.
extra/linux-4.4.3-nosmp-sdk/*: Upgraded.
Users browsing this forum: No registered users and 69 guests
