Slackware 64bit:
Thu Mar 6 04:14:23 UTC 2014
ap/sudo-1.8.9p5-x86_64-1.txz: Upgraded.
ap/sudo-1.8.9p5-i486-1.txz: Upgraded.
Tue Mar 11 07:06:18 UTC 2014
a/udisks-1.0.5-x86_64-1.txz: Upgraded.
This update fixes a stack-based buffer overflow when handling long path
names. A malicious, local user could use this flaw to create a
specially-crafted directory structure that could lead to arbitrary code
execution with the privileges of the udisks daemon (root).
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0004
a/udisks2-2.1.3-x86_64-1.txz: Upgraded.
a/udisks-1.0.5-i486-1.txz: Upgraded.
a/udisks2-2.1.3-i486-1.txz: Upgraded.
Thu Mar 13 03:32:38 UTC 2014
n/mutt-1.5.23-x86_64-1.txz: Upgraded.
This update fixes a buffer overflow where malformed RFC2047 header
lines could result in denial of service or potentially the execution
of arbitrary code as the user running mutt.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0467
n/mutt-1.5.23-i486-1.txz: Upgraded.
Fri Mar 14 00:44:48 UTC 2014
n/samba-4.1.6-x86_64-1.txz: Upgraded.
CVE-2013-4496:
Samba versions 3.4.0 and above allow the administrator to implement
locking out Samba accounts after a number of bad password attempts.
However, all released versions of Samba did not implement this check for
password changes, such as are available over multiple SAMR and RAP
interfaces, allowing password guessing attacks.
CVE-2013-6442:
Samba versions 4.0.0 and above have a flaw in the smbcacls command. If
smbcacls is used with the "-C|--chown name" or "-G|--chgrp name"
command options it will remove the existing ACL on the object being
modified, leaving the file or directory unprotected.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4496
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6442
n/samba-4.1.6-i486-1.txz: Upgraded.
CVE-2013-4496:
CVE-2013-6442:
Sun Mar 16 02:52:28 UTC 2014
n/php-5.4.26-x86_64-1.txz: Upgraded.
This update fixes a flaw where a specially crafted data file may cause a
segfault or 100% CPU consumption when a web page uses fileinfo() on it.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1943
n/php-5.4.26-i486-1.txz: Upgraded.
Fri Mar 28 03:43:11 UTC 2014
l/mozilla-nss-3.16-x86_64-1.txz: Upgraded.
The cert_TestHostName function in lib/certdb/certdb.c in the
certificate-checking implementation in Mozilla Network Security Services
(NSS) before 3.16 accepts a wildcard character that is embedded in an
internationalized domain name's U-label, which might allow man-in-the-middle
attackers to spoof SSL servers via a crafted certificate.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1492
l/seamonkey-solibs-2.25-x86_64-1.txz: Upgraded.
n/curl-7.36.0-x86_64-1.txz: Upgraded.
This update fixes four security issues.
http://curl.haxx.se/docs/adv_20140326A.html
http://curl.haxx.se/docs/adv_20140326B.html
http://curl.haxx.se/docs/adv_20140326C.html
http://curl.haxx.se/docs/adv_20140326D.html
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0138
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0139
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-1263
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2522
n/httpd-2.4.9-x86_64-1.txz: Upgraded.
This update addresses two security issues.
Segfaults with truncated cookie logging. mod_log_config: Prevent segfaults
when logging truncated cookies. Clean up the cookie logging parser to
recognize only the cookie=value pairs, not valueless cookies.
mod_dav: Keep track of length of cdata properly when removing leading
spaces. Eliminates a potential denial of service from specifically crafted
DAV WRITE requests.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0098
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6438
n/openssh-6.6p1-x86_64-1.txz: Upgraded.
This update fixes a security issue when using environment passing with
a sshd_config(5) AcceptEnv pattern with a wildcard. OpenSSH could be
tricked into accepting any environment variable that contains the
characters before the wildcard character.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2532
n/tin-2.2.0-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-28.0-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-24.4.0-x86_64-1.txz: Upgraded.
xap/seamonkey-2.25-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.16-i486-1.txz: Upgraded.
l/seamonkey-solibs-2.25-i486-1.txz: Upgraded.
n/curl-7.36.0-i486-1.txz: Upgraded.
n/httpd-2.4.9-i486-1.txz: Upgraded.
DAV WRITE requests.
n/openssh-6.6p1-i486-1.txz: Upgraded.
n/tin-2.2.0-i486-1.txz: Upgraded.
xap/mozilla-firefox-28.0-i486-1.txz: Upgraded.
xap/mozilla-thunderbird-24.4.0-i486-1.txz: Upgraded.
xap/seamonkey-2.25-i486-1.txz: Upgraded.
Mon Mar 31 20:30:28 UTC 2014
l/apr-1.5.0-x86_64-1.txz: Upgraded.
l/apr-util-1.5.3-x86_64-1.txz: Upgraded.
n/httpd-2.4.9-x86_64-2.txz: Rebuilt.
Recompiled against new apr/apr-util to restore missing mod_mpm_event.so.
l/apr-1.5.0-i486-1.txz: Upgraded.
l/apr-util-1.5.3-i486-1.txz: Upgraded.
n/httpd-2.4.9-i486-2.txz: Rebuilt.
Tue Apr 8 14:19:51 UTC 2014
a/openssl-solibs-1.0.1g-x86_64-1.txz: Upgraded.
n/openssl-1.0.1g-x86_64-1.txz: Upgraded.
A missing bounds check in the handling of the TLS heartbeat extension
can be used to reveal up to 64k of memory to a connected client or server.
Thanks for Neel Mehta of Google Security for discovering this bug and to
Adam Langley <agl@chromium.org> and Bodo Moeller <bmoeller@acm.org> for
preparing the fix.
Fix for the attack described in the paper "Recovering OpenSSL
ECDSA Nonces Using the FLUSH+RELOAD Cache Side-channel Attack"
by Yuval Yarom and Naomi Benger. Details can be obtained from:
http://eprint.iacr.org/2014/140
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0160
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0076
a/openssl-solibs-1.0.1g-i486-1.txz: Upgraded.
n/openssl-1.0.1g-i486-1.txz: Upgraded.
preparing the fix.
Mon Apr 21 20:09:48 UTC 2014
l/libyaml-0.1.6-x86_64-1.txz: Upgraded.
This update fixes a heap overflow in URI escape parsing of YAML in Ruby,
where a specially crafted string could cause a heap overflow leading to
arbitrary code execution.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2525
https://www.ruby-lang.org/en/news/2014/03/29/heap-overflow-in-yaml-uri-escape-parsing-cve-2014-2525/
n/php-5.4.27-x86_64-1.txz: Upgraded.
This update fixes a security issue in the in the awk script detector
which allows context-dependent attackers to cause a denial of service
(CPU consumption) via a crafted ASCII file that triggers a large amount
of backtracking.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-7345
l/libyaml-0.1.6-i486-1.txz: Upgraded.
n/php-5.4.27-i486-1.txz: Upgraded.
of backtracking.
Tue Apr 22 17:31:48 UTC 2014
a/bash-4.3.011-x86_64-1.txz: Upgraded.
a/gawk-4.1.1-x86_64-1.txz: Upgraded.
a/grep-2.18-x86_64-1.txz: Upgraded.
ap/vim-7.4.258-x86_64-1.txz: Upgraded.
n/openssh-6.6p1-x86_64-2.txz: Rebuilt.
Fixed a bug with curve25519-sha256 that caused a key exchange failure in
about 1 in 512 connection attempts.
xap/vim-gvim-7.4.258-x86_64-1.txz: Upgraded.
a/bash-4.3.011-i486-1.txz: Upgraded.
a/gawk-4.1.1-i486-1.txz: Upgraded.
a/grep-2.18-i486-1.txz: Upgraded.
ap/vim-7.4.258-i486-1.txz: Upgraded.
n/openssh-6.6p1-i486-2.txz: Rebuilt.
xap/vim-gvim-7.4.258-i486-1.txz: Upgraded.
Users browsing this forum: No registered users and 79 guests
