Napisano: 05 Oct 2014, 09:26
05.10.2014.
Slackware 64bit:
Sun Oct 5 00:38:31 UTC 2014
a/elilo-3.16-x86_64-1.txz: Upgraded.
Thanks to fsLeg for the extra bit of sed that was needed to build the
latest version.
Slackware 32bit:
a/elilo-3.16-i486-1.txz: Upgraded.
latest version.
xap/mozilla-firefox-32.0.3-i486-2.txz: Rebuilt.
Recompiled with -O2 optimization to fix sluggishness on the 32-bit build.
Napisano: 15 Oct 2014, 10:13
14.10.2014.
Slackware 64bit:
Tue Oct 14 23:45:01 UTC 2014
xap/mozilla-firefox-33.0-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-31.2.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
xap/mozilla-firefox-33.0-i486-1.txz: Upgraded.
xap/mozilla-thunderbird-31.2.0-i486-1.txz: Upgraded.
Napisano: 15 Oct 2014, 20:01
15.10.2014.
Slackware 64bit:
Wed Oct 15 17:28:59 UTC 2014
a/openssl-solibs-1.0.1j-x86_64-1.txz: Upgraded.
n/openssl-1.0.1j-x86_64-1.tx: Upgraded.
This update fixes several security issues:
SRTP Memory Leak (CVE-2014-3513):
A flaw in the DTLS SRTP extension parsing code allows an attacker, who
sends a carefully crafted handshake message, to cause OpenSSL to fail
to free up to 64k of memory causing a memory leak. This could be
exploited in a Denial Of Service attack.
Session Ticket Memory Leak (CVE-2014-3567):
When an OpenSSL SSL/TLS/DTLS server receives a session ticket the
integrity of that ticket is first verified. In the event of a session
ticket integrity check failing, OpenSSL will fail to free memory
causing a memory leak. By sending a large number of invalid session
tickets an attacker could exploit this issue in a Denial Of Service
attack.
SSL 3.0 Fallback protection:
OpenSSL has added support for TLS_FALLBACK_SCSV to allow applications
to block the ability for a MITM attacker to force a protocol
downgrade.
Some client applications (such as browsers) will reconnect using a
downgraded protocol to work around interoperability bugs in older
servers. This could be exploited by an active man-in-the-middle to
downgrade connections to SSL 3.0 even if both sides of the connection
support higher protocols. SSL 3.0 contains a number of weaknesses
including POODLE (CVE-2014-3566).
Build option no-ssl3 is incomplete (CVE-2014-3568):
When OpenSSL is configured with "no-ssl3" as a build option, servers
could accept and complete a SSL 3.0 handshake, and clients could be
configured to send them.
https://www.openssl.org/news/secadv_20141015.txt
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3513
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3566
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3567
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3568
Slackware 32bit:
a/openssl-solibs-1.0.1j-i486-1.txz: Upgraded.
n/openssl-1.0.1j-i486-1.txz: Upgraded.
attack.
downgrade.
Napisano: 21 Oct 2014, 09:37
20.10.2014. i
21.10.2014.
Slackware 64bit:
Tue Oct 21 02:10:33 UTC 2014
e/emacs-24.4-x86_64-1.txz: Upgraded.
Mon Oct 20 22:21:45 UTC 2014
n/openssh-6.7p1-x86_64-1.txz: Upgraded.
This update fixes a security issue that allows remote servers to trigger
the skipping of SSHFP DNS RR checking by presenting an unacceptable
HostCertificate.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-2653
Slackware 32bit:
e/emacs-24.4-i486-1.txz: Upgraded.
n/openssh-6.7p1-i486-1.txz: Upgraded.
HostCertificate.
Napisano: 24 Oct 2014, 08:58
24.10.2014.
Slackware 64bit:
Fri Oct 24 04:55:44 UTC 2014
a/glibc-solibs-2.20-x86_64-1.txz: Upgraded.
a/glibc-zoneinfo-2014i-noarch-1.txz: Upgraded.
Upgraded to tzcode2014i and tzdata2014i.
l/glibc-2.20-x86_64-1.txz: Upgraded.
This update fixes several security issues, and adds an extra security
hardening patch from Florian Weimer. Thanks to mancha for help with
tracking and backporting patches.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4424
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4412
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4237
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4788
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4458
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-4043
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0475
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-5119
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6040
l/glibc-i18n-2.20-x86_64-1.txz: Upgraded.
l/glibc-profile-2.20-x86_64-1.txz: Upgraded.
xap/pidgin-2.10.10-x86_64-1.txz: Upgraded.
Insufficient SSL certificate validation (CVE-2014-3694)
Remote crash parsing malformed MXit emoticon (CVE-2014-3695)
Remote crash parsing malformed Groupwise message (CVE-2014-3696)
Malicious smiley themes could alter arbitrary files (CVE-2014-3697)
Potential information leak from XMPP (CVE-2014-3698)
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3694
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3695
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3696
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3697
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3698
Slackware 32bit:
a/glibc-solibs-2.20-i486-1.txz: Upgraded.
l/glibc-2.20-i486-1.txz: Upgraded.
l/glibc-i18n-2.20-i486-1.txz: Upgraded.
l/glibc-profile-2.20-i486-1.txz: Upgraded.
xap/pidgin-2.10.10-i486-1.txz: Upgraded.
Napisano: 25 Oct 2014, 03:35
24.10.2014.
Slackware 64bit:
Fri Oct 24 21:11:15 UTC 2014
a/glibc-solibs-2.20-x86_64-2.txz: Rebuilt.
d/gcc-4.8.3-x86_64-2.txz: Rebuilt.
Patched bug pr61801, which caused some failures with glibc-2.20.
d/gcc-g++-4.8.3-x86_64-2.txz: Rebuilt.
d/gcc-gfortran-4.8.3-x86_64-2.txz: Rebuilt.
d/gcc-gnat-4.8.3-x86_64-2.txz: Rebuilt.
d/gcc-go-4.8.3-x86_64-2.txz: Rebuilt.
d/gcc-java-4.8.3-x86_64-2.txz: Rebuilt.
d/gcc-objc-4.8.3-x86_64-2.txz: Rebuilt.
l/glibc-2.20-x86_64-2.txz: Rebuilt.
Recompiled with patched gcc.
l/glibc-i18n-2.20-x86_64-2.txz: Rebuilt.
l/glibc-profile-2.20-x86_64-2.txz: Rebuilt.
Slackware 32bit:
Napisano: 25 Oct 2014, 10:42
25.10.2014.
Slackware 64bit:
Sat Oct 25 04:30:31 UTC 2014
xap/gimp-2.8.14-x86_64-1.txz: Upgraded.
Slackware 32bit:
xap/gimp-2.8.14-i486-1.txz: Upgraded.
Napisano: 29 Oct 2014, 22:52
29.10.2014.
Slackware 64bit:
Wed Oct 29 18:21:12 UTC 2014
ap/moc-2.5.0-x86_64-1.txz: Upgraded.
n/wget-1.16-x86_64-1.txz: Upgraded.
This update fixes a symlink vulnerability that could allow an attacker
to write outside of the expected directory.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-4877
Slacware 32bit:
ap/moc-2.5.0-i486-1.txz: Upgraded.
n/wget-1.16-i486-1.txz: Upgraded.
Napisano: 04 Nov 2014, 03:19
04.11.2014.
Slackware 64bit:
Tue Nov 4 00:05:23 UTC 2014
ap/mariadb-5.5.40-x86_64-1.txz: Upgraded.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6507
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6491
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6500
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6469
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6555
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6559
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6494
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6496
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-6464
l/seamonkey-solibs-2.30-x86_64-1.txz: Upgraded.
n/php-5.4.34-x86_64-1.txz: Upgraded.
#68044 (Integer overflow in unserialize() (32-bits only)). (CVE-2014-3669)
#68113 (Heap corruption in exif_thumbnail()). (CVE-2014-3670)
#68027 (Global buffer overflow in mkgmtime() function). (CVE-2014-3668)
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3669
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3670
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3668
xap/mozilla-firefox-33.0.2-x86_64-1.txz: Upgraded.
xap/seamonkey-2.30-x86_64-1.txz: Upgraded.
Slackware 32bit:
ap/mariadb-5.5.40-i486-1.txz: Upgraded.
l/seamonkey-solibs-2.30-i486-1.txz: Upgraded.
n/php-5.4.34-i486-1.txz: Upgraded.
xap/mozilla-firefox-33.0.2-i486-1.txz: Upgraded.
xap/seamonkey-2.30-i486-1.txz: Upgraded.
Napisano: 08 Nov 2014, 01:39
07.11.2014.
Bash, kernel i još ponešto.
Slackware 64bit:
Fri Nov 7 21:02:55 UTC 2014
a/bash-4.3.030-x86_64-1.txz: Upgraded.
Applied all upstream patches. The previously applied patch requiring
a specific prefix/suffix in order to parse variables for functions
closed all of the known vulnerabilities anyway, but it's clear that
until all the patches were applied that the "is this still vulnerable"
questions were not going to end...
a/btrfs-progs-20141107-x86_64-1.txz: Upgraded.
Added the header files to the package. Thanks to Vincent Batts.
a/kernel-firmware-20141106git-noarch-1.txz: Upgraded.
a/kernel-generic-3.14.23-x86_64-1.txz: Upgraded.
a/kernel-huge-3.14.23-x86_64-1.txz: Upgraded.
a/kernel-modules-3.14.23-x86_64-1.txz: Upgraded.
ap/mpg123-1.21.0-x86_64-1.txz: Upgraded.
d/kernel-headers-3.14.23-x86-1.txz: Upgraded.
k/kernel-source-3.14.23-noarch-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.8.4-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32bit:
a/bash-4.3.030-i486-1.txz: Upgraded.
a/btrfs-progs-20141107-i486-1.txz: Upgraded.
a/kernel-generic-3.14.23-i486-1.txz: Upgraded.
a/kernel-generic-smp-3.14.23_smp-i686-1.txz: Upgraded.
a/kernel-huge-3.14.23-i486-1.txz: Upgraded.
a/kernel-huge-smp-3.14.23_smp-i686-1.txz: Upgraded.
a/kernel-modules-3.14.23-i486-1.txz: Upgraded.
a/kernel-modules-smp-3.14.23_smp-i686-1.txz: Upgraded.
ap/mpg123-1.21.0-i486-1.txz: Upgraded.
d/kernel-headers-3.14.23_smp-x86-1.txz: Upgraded.
k/kernel-source-3.14.23_smp-noarch-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.8.4-i486-1.txz: Upgraded.
extra/linux-3.14.23-nosmp-sdk/*: Upgraded.
Users browsing this forum: No registered users and 21 guests
