Napisano: 22 Sep 2012, 08:27
22.09.2012.
Slackware 32bit
Sat Sep 22 00:34:26 UTC 2012
I'll go along with the last minute request to provide the released stable
version of xf86-video-nouveau. The reason that we hadn't done this is that
the stable version of Mesa won't compile with this version of libdrm. But,
since xf86-video-nouveau compiles fine with this libdrm and the Mesa we're
already shipping, it seems reasonable to provide them here in /testing.
Thanks to Didier Spaier.
testing/packages/libdrm-2.4.39-i486-1.txz: Added.
testing/packages/xf86-video-nouveau-1.0.2-i486-1.txz: Added.
Slackware 64bit
testing/packages/libdrm-2.4.39-x86_64-1.txz: Added.
testing/packages/xf86-video-nouveau-1.0.2-x86_64-1.txz: Added.
Napisano: 25 Sep 2012, 03:30
Sinoć je stiglo nešto sitnih zakrpa a koliko sam video i novi drajveri za ati i intel. Nisam siguran zašto piše ati (od serije HD6xxx je zvanično samo AMD) i za koje je to serije. Inače se ovi drajveri nalaze u /testing tako da ne utiče na update.
Dakle, 24.09.2012.
Slackware 32bit:
Mon Sep 24 20:25:12 UTC 2012
Here are a few minor bugfixes as well as a couple more test drivers for X:
a/e2fsprogs-1.42.6-i486-1.txz: Upgraded.
This is a bugfix release.
a/sysvinit-scripts-2.0-noarch-12.txz: Rebuilt.
In rc.M, don't run rc.wicd if /usr/sbin/wicd does not exist. This change
prevents a leftover rc.wicd from blocking NetworkManager startup.
l/gamin-0.1.10-i486-5.txz: Rebuilt.
Patched to fix a deadlock bug, and to fix building against recent libraries.
Thanks to sberthelot, sombragris, and ponce on LQ.
l/mozilla-nss-3.13.5-i486-3.txz: Rebuilt.
Added libcrmf.a to the package, needed to compile xulrunner.
Thanks to Robby Workman.
isolinux/initrd.img: Rebuilt.
Upgraded to e2fsprogs-1.42.6.
testing/packages/xf86-video-ati-6.14.6-i486-1.txz: Added.
This driver requires the libdrm in /testing.
testing/packages/xf86-video-intel-2.20.8-i486-1.txz: Added.
testing/source/config-testing-3.*: Rebuilt.
Changed CONFIG_GFS2_FS in huge kernels from y -> m to fix the compile.
Slackware 64bit
a/e2fsprogs-1.42.6-x86_64-1.txz: Upgraded.
l/gamin-0.1.10-x86_64-5.txz: Rebuilt.
l/mozilla-nss-3.13.5-x86_64-3.txz: Rebuilt.
testing/packages/xf86-video-intel-2.20.8-x86_64-1.txz: Added.
testing/packages/xf86-video-ati-6.14.6-x86_64-1.txz: Added.
Napisano: 26 Sep 2012, 10:31
25.09.2012.
Slackware - noarch
a/sysvinit-scripts-2.0-noarch-13.txz: Rebuilt.
Changed the path in rc.M for wicd from relative to absolute. It works
either way, but it should be an absolute path just to be consistent with
the rest of the script.
Napisano: 29 Sep 2012, 02:01
Kao što je većina već videla, poslednja vest je da je Slackware 14 zvanično predstavljen! Iaoko je datum na
changelogu 26.09., nova verzija se pojavila zvanično tek pre par sati. Možda su vremenske zone u pitanju
Wed Sep 26 01:10:42 UTC 2012
Slackware 14.0 x86_64 stable is released!
We're perfectionists here at Slackware, so this release has been a long
time a-brewing. But we think you'll agree that it was worth the wait.
Slackware 14.0 combines modern components, ease of use, and flexible
configuration... our "KISS" philosophy demands it.
The ISOs are off to be replicated, a 6 CD-ROM 32-bit set and a dual-sided
32-bit/64-bit x86/x86_64 DVD. Please consider supporting the Slackware
project by picking up a copy from store.slackware.com. We're taking
pre-orders now, and offer a discount if you sign up for a subscription.
Thanks to everyone who helped make this happen. The Slackware team, the
upstream developers, and (of course) the awesome Slackware user community.
Have fun! :-)
Napisano: 10 Oct 2012, 12:45
=> 09. 10. 2012.
Slackware -current package:
xap/mozilla-firefox-16.0-i486-1.txz
Slackware x86_64 -current package:
xap/mozilla-firefox-16.0-x86_64-1.txz
Napisano: 11 Oct 2012, 22:47
11.10.2012.
Slackware 32bit
n/bind-9.9.2-i486-1.txz: Upgraded.
Fixes these security issues:
A certain combination of records in the RBT could cause named to hang
while populating the additional section of a response. [RT #31090]
Named could die on specially crafted record. [RT #30416]
n/iptables-1.4.14-i486-2.txz: Rebuilt.
Patched to fix a compiler related bug in iptables-restore.
Thanks to linuxxer for the report and David Somero for a link to the patch.
n/rp-pppoe-3.11-i486-1.txz: Upgraded.
Moved from /testing.
Slackware 64bit
n/bind-9.9.2-x86_64-1.txz: Upgraded.
n/iptables-1.4.14-x86_64-2.txz: Rebuilt.
n/rp-pppoe-3.11-x86_64-1.txz: Upgraded.
Napisano: 13 Oct 2012, 16:31
=> 11. 10. 2012.
xap/mozilla-firefox-16.0.1-i486-1.txz
xap/mozilla-thunderbird-16.0.1-i486-1.txz
xap/mozilla-firefox-16.0.1-x86_64-1.txz
xap/mozilla-thunderbird-16.0.1-x86_64-1.txz
Napisano: 15 Oct 2012, 15:53
15.10.2012
Slackware 32bit
l/seamonkey-solibs-2.13.1-i486-1.txz: Upgraded.
xap/seamonkey-2.13.1-i486-1.txz: Upgraded.
Slackware 64bit
l/seamonkey-solibs-2.13.1-x86_64-1.txz: Upgraded.
xap/seamonkey-2.13.1-x86_64-1.txz: Upgraded.
Napisano: 27 Oct 2012, 10:51
27.10.2012.
Slackware 64bit
xap/mozilla-firefox-16.0.2-x86_64-1.txz: Upgraded.
Slackware 32bit
xap/mozilla-firefox-16.0.2-i486-1.txz: Upgraded.
Napisano: 31 Oct 2012, 12:22
31.10.2012.
Slackware 64bit
l/lcms2-2.4-x86_64-1.txz: Upgraded.
l/seamonkey-solibs-2.13.2-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-16.0.2-x86_64-1.txz: Upgraded.
xap/seamonkey-2.13.2-x86_64-1.txz: Upgraded.
Slackware 32bit
l/lcms2-2.4-i486-1.txz: Upgraded.
l/seamonkey-solibs-2.13.2-i486-1.txz: Upgraded.
xap/mozilla-thunderbird-16.0.2-i486-1.txz: Upgraded.
xap/seamonkey-2.13.2-i486-1.txz: Upgraded.
Users browsing this forum: No registered users and 70 guests
