Napisano: 06 Sep 2015, 12:00
29.08.2015.
Slackware 64bit:
Sat Aug 29 05:27:29 UTC 2015
a/procps-ng-3.3.10-x86_64-4.txz: Rebuilt.
Recompiled without --enable-timeout-stat to fix fuser hang.
kde/oxygen-gtk3-1.4.1-x86_64-1.txz: Removed.
x/libXaw3dXft-1.6.2d-x86_64-2.txz: Rebuilt.
xap/mozilla-firefox-40.0.3-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/procps-ng-3.3.10-i586-4.txz: Rebuilt.
kde/oxygen-gtk3-1.4.1-i486-1.txz: Removed.
x/libXaw3dXft-1.6.2d-i586-2.txz: Rebuilt.
xap/mozilla-firefox-40.0.3-i586-1.txz: Upgraded.
Napisano: 06 Sep 2015, 12:01
30.08.2015.
Slackware 64bit:
Sun Aug 30 22:43:36 UTC 2015
l/adwaita-icon-theme-3.16.2-noarch-2.txz: Rebuilt.
Patched to remove bogus /usr/locale/ directory tree. Thanks to ponce.
l/gvfs-1.24.2-x86_64-2.txz: Rebuilt.
Rebuilt to fix missing CIFS filesystem support. Thanks to lems.
x/xorg-server-1.17.2-x86_64-2.txz: Rebuilt.
Recompiled with stability patches from upstream. Thanks to ponce.
x/xorg-server-xephyr-1.17.2-x86_64-2.txz: Rebuilt.
x/xorg-server-xnest-1.17.2-x86_64-2.txz: Rebuilt.
x/xorg-server-xvfb-1.17.2-x86_64-2.txz: Rebuilt.
Slackware 32bit:
l/gvfs-1.24.2-i586-2.txz: Rebuilt.
x/xorg-server-1.17.2-i586-2.txz: Rebuilt.
x/xorg-server-xephyr-1.17.2-i586-2.txz: Rebuilt.
x/xorg-server-xnest-1.17.2-i586-2.txz: Rebuilt.
x/xorg-server-xvfb-1.17.2-i586-2.txz: Rebuilt.
Napisano: 06 Sep 2015, 12:02
01.09.2015.
Slackware 64bit:
Tue Sep 1 23:29:22 UTC 2015
a/aaa_elflibs-14.2-x86_64-2.txz: Rebuilt.
a/cryptsetup-1.6.7-x86_64-1.txz: Upgraded.
a/lvm2-2.02.129-x86_64-1.txz: Upgraded.
ap/lxc-1.1.3-x86_64-1.txz: Upgraded.
d/git-2.5.1-x86_64-1.txz: Upgraded.
l/dconf-editor-3.16.1-x86_64-1.txz: Added.
l/gdk-pixbuf2-2.31.7-x86_64-1.txz: Upgraded.
Gustavo Grieco discovered a heap overflow in the processing of BMP images
which may result in the execution of arbitrary code if a malformed image
is opened.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4491
n/ModemManager-1.4.10-x86_64-1.txz: Upgraded.
n/NetworkManager-1.0.6-x86_64-1.txz: Upgraded.
n/openssh-7.1p1-x86_64-1.txz: Upgraded.
x/libvdpau-1.1.1-x86_64-1.txz: Upgraded.
libvdpau versions 1.1 and earlier, when used in setuid or setgid
applications, contain vulnerabilities related to environment variable
handling that could allow an attacker to execute arbitrary code or
overwrite arbitrary files. This release uses the secure_getenv()
function to fix these problems.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5198
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5199
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5200
x/mesa-10.6.5-x86_64-1.txz: Upgraded.
xap/network-manager-applet-1.0.6-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/aaa_elflibs-14.2-i586-2.txz: Rebuilt.
a/cryptsetup-1.6.7-i586-1.txz: Upgraded.
a/lvm2-2.02.129-i586-1.txz: Upgraded.
ap/lxc-1.1.3-i586-1.txz: Upgraded.
d/git-2.5.1-i586-1.txz: Upgraded.
l/dconf-editor-3.16.1-i586-1.txz: Added.
l/gdk-pixbuf2-2.31.7-i586-1.txz: Upgraded.
is opened.
n/ModemManager-1.4.10-i586-1.txz: Upgraded.
n/NetworkManager-1.0.6-i586-1.txz: Upgraded.
n/openssh-7.1p1-i586-1.txz: Upgraded.
x/libvdpau-1.1.1-i586-1.txz: Upgraded.
x/mesa-10.6.5-i586-1.txz: Upgraded.
xap/network-manager-applet-1.0.6-i586-1.txz: Upgraded.
Napisano: 06 Sep 2015, 12:03
02.09.2015.
Slackware 64bit:
Wed Sep 2 19:36:31 UTC 2015
n/bind-9.10.2_P4-x86_64-1.txz: Upgraded.
This update fixes two denial-of-service vulnerabilities:
+ CVE-2015-5722 is a denial-of-service vector which can be
exploited remotely against a BIND server that is performing
validation on DNSSEC-signed records. Validating recursive
resolvers are at the greatest risk from this defect, but it has not
been ruled out that it could be exploited against an
authoritative-only nameserver under limited conditions. Servers
that are not performing validation are not vulnerable. However,
ISC does not recommend disabling validation as a workaround to
this issue as it exposes the server to other types of attacks.
Upgrading to the patched versions is the recommended solution.
All versions of BIND since 9.0.0 are vulnerable to CVE-2015-5722.
+ CVE-2015-5986 is a denial-of-service vector which can be used
against a BIND server that is performing recursion. Validation
is not required. Recursive resolvers are at the greatest risk
from this defect, but it has not been ruled out that it could
be exploited against an authoritative-only nameserver under
limited conditions.
Only versions of BIND since 9.9.7 and 9.10.2 are vulnerable to
CVE-2015-5986.
https://kb.isc.org/article/AA-01287/0
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5722
https://kb.isc.org/article/AA-01291/0
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5986
Slackware 32bit:
n/bind-9.10.2_P4-i586-1.txz: Upgraded.
limited conditions.
CVE-2015-5986.
Napisano: 06 Sep 2015, 12:04
03.09.2015.
Slackware 64bit:
Thu Sep 3 22:02:39 UTC 2015
l/seamonkey-solibs-2.35-x86_64-1.txz: Upgraded.
n/mutt-1.5.24-x86_64-1.txz: Upgraded.
x/mesa-10.6.5-x86_64-2.txz: Rebuilt.
Recompiled with --enable-nine.
xap/seamonkey-2.35-x86_64-1.txz: Upgraded.
Slackware 32bit:
l/seamonkey-solibs-2.35-i586-1.txz: Upgraded.
n/mutt-1.5.24-i586-1.txz: Upgraded.
x/mesa-10.6.5-i586-2.txz: Rebuilt.
xap/seamonkey-2.35-i586-1.txz: Upgraded.
Napisano: 06 Sep 2015, 15:12
Nažalost, u nedostatku vremena, prelazim sa current grane na stabilnu.
Za current ipak treba malo više brige i ljubavi da bi sve ferceralo kako valja.
Zadnji veći i značajniji update, u kombinaciji sa Mesa drajverom, novom verzijom kerlena 4.1.6 i Xorg server-om je dovelo do pucanja Xorg-a, i jednostavno nemam vremena da se posvetim "čačkanju" i ako mi je to duševna hrana.
Napisano: 13 Sep 2015, 15:11
10.09.2015.
Slackware 64bit:
Thu Sep 10 14:12:07 UTC 2015
d/gdb-7.10-x86_64-1.txz: Upgraded.
l/gobject-introspection-1.44.0-x86_64-1.txz: Upgraded.
l/netpbm-10.66.02-x86_64-4.txz: Rebuilt.
Removed junk /usr/pkgconfig_template and /usr/bin/manweb files.
Thanks to j_v on LQ.
l/parted-3.2-x86_64-2.txz: Rebuilt.
n/sendmail-8.15.2-x86_64-1.txz: Upgraded.
n/sendmail-cf-8.15.2-noarch-1.txz: Upgraded.
x/mesa-10.6.6-x86_64-1.txz: Upgraded.
Slackware 32bit:
d/gdb-7.10-i586-1.txz: Upgraded.
l/gobject-introspection-1.44.0-i586-1.txz: Upgraded.
l/netpbm-10.66.02-i586-4.txz: Rebuilt.
l/parted-3.2-i586-2.txz: Rebuilt.
n/sendmail-8.15.2-i586-1.txz: Upgraded.
x/mesa-10.6.6-i586-1.txz: Upgraded.
Napisano: 19 Sep 2015, 07:58
15.09.2015.
Slackware 64bit:
Tue Sep 15 22:36:17 UTC 2015
ap/hplip-3.15.9-x86_64-1.txz: Upgraded.
ap/sqlite-3.8.11.1-x86_64-1.txz: Upgraded.
d/llvm-3.7.0-x86_64-1.txz: Upgraded.
n/ca-certificates-20150426-noarch-2.txz: Rebuilt.
Patched update-ca-certificates to remove incompatible command operators
used to call 'run-parts'. Thanks to Stuart Winter.
n/stunnel-5.23-x86_64-1.txz: Upgraded.
x/mesa-11.0.0-x86_64-1.txz: Upgraded.
x/xf86-video-intel-git_20150915_23986f0-x86_64-1.txz: Upgraded.
Set default acceleration method to DRI2/UXA.
x/xf86-video-vmware-13.1.0-x86_64-3.txz: Rebuilt.
Slackware 32bit:
ap/hplip-3.15.9-i586-1.txz: Upgraded.
ap/sqlite-3.8.11.1-i586-1.txz: Upgraded.
d/llvm-3.7.0-i586-1.txz: Upgraded.
n/stunnel-5.23-i586-1.txz: Upgraded.
x/mesa-11.0.0-i586-1.txz: Upgraded.
x/xf86-video-intel-git_20150915_23986f0-i586-1.txz: Upgraded.
x/xf86-video-vmware-13.1.0-i586-3.txz: Rebuilt.
Napisano: 24 Oct 2015, 14:16
23.09.2015.
Slackware 64bit:
Wed Sep 23 01:10:36 UTC 2015
a/smartmontools-6.4-x86_64-1.txz: Upgraded.
ap/cdrtools-3.01-x86_64-1.txz: Upgraded.
ap/ddrescue-1.20-x86_64-1.txz: Upgraded.
d/ccache-3.2.3-x86_64-1.txz: Upgraded.
l/gc-7.4.2-x86_64-3.txz: Rebuilt.
Build without --disable-static, but don't package the extra static libraries.
This ensures that all the symbols are exported in the shared libraries.
l/libjpeg-turbo-1.4.2-x86_64-1.txz: Upgraded.
l/libtasn1-4.7-x86_64-1.txz: Upgraded.
l/notify-python-0.1.1-x86_64-5.txz: Rebuilt.
Patched to fix hplip-tools. Thanks to gmgf.
n/stunnel-5.23-x86_64-2.txz: Rebuilt.
Server certificate config file name changed from stunnel.cnf to openssl.cnf.
Thanks to Iouri Kharon.
xap/mozilla-firefox-41.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/smartmontools-6.4-i586-1.txz: Upgraded.
ap/cdrtools-3.01-i586-1.txz: Upgraded.
ap/ddrescue-1.20-i586-1.txz: Upgraded.
d/ccache-3.2.3-i586-1.txz: Upgraded.
l/gc-7.4.2-i586-3.txz: Rebuilt.
l/libjpeg-turbo-1.4.2-i586-1.txz: Upgraded.
l/libtasn1-4.7-i586-1.txz: Upgraded.
l/notify-python-0.1.1-i586-5.txz: Rebuilt.
n/stunnel-5.23-i586-2.txz: Rebuilt.
xap/mozilla-firefox-41.0-i586-1.txz: Upgraded.
Napisano: 24 Oct 2015, 14:18
01.10.2015.
Slackware 64bit:
Thu Oct 1 21:21:36 UTC 2015
a/pkgtools-14.2-noarch-1.txz: Upgraded.
Patched makepkg and removepkg to support spaces in symlinks. Spaces in file
and directory names also work, so support should be complete.
Thanks to Erik Jan Tromp.
Patched makepkg to ensure that the root of a package is chmod 755.
Patched installpkg to speed up several parts of the script, especially when
symlinks are created by an install script. If bash is available, install
scripts will be translated to avoid spawning two subshells per link.
Also, reduced UUOC! :-)
Patched removepkg to speed up several parts of the script.
Thanks to Stuart Winter and Jim Hawkins.
Patched upgradepkg to speed up several parts of the script by using native
bash rather than calling out to sed. (Similar changes might be applied to
installpkg/removepkg in the future, but upgradepkg looping against the full
set of packages is where the most improvement is seen)
Thanks to Michal "mina86" Nazarewicz.
l/mozilla-nss-3.20-x86_64-1.txz: Upgraded.
Upgraded to nss-3.20 and nspr-4.10.9.
l/seamonkey-solibs-2.38-x86_64-1.txz: Upgraded.
n/php-5.6.13-x86_64-1.txz: Upgraded.
This update fixes some bugs and security issues.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-6834
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-6835
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-6836
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-6837
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-6838
x/libXi-1.7.5-x86_64-1.txz: Upgraded.
x/libxcb-1.11.1-x86_64-1.txz: Upgraded.
x/mesa-11.0.2-x86_64-1.txz: Upgraded.
x/xf86-video-chips-1.2.6-x86_64-1.txz: Upgraded.
x/xf86-video-s3virge-1.10.7-x86_64-1.txz: Upgraded.
x/xf86-video-sis-0.10.8-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-41.0.1-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-38.3.0-x86_64-1.txz: Upgraded.
xap/seamonkey-2.38-x86_64-1.txz: Upgraded.
Slackware 32bit:
l/mozilla-nss-3.20-i586-1.txz: Upgraded.
l/seamonkey-solibs-2.38-i586-1.txz: Upgraded.
n/php-5.6.13-i586-1.txz: Upgraded.
x/libXi-1.7.5-i586-1.txz: Upgraded.
x/libxcb-1.11.1-i586-1.txz: Upgraded.
x/mesa-11.0.2-i586-1.txz: Upgraded.
x/xf86-video-chips-1.2.6-i586-1.txz: Upgraded.
x/xf86-video-s3virge-1.10.7-i586-1.txz: Upgraded.
x/xf86-video-sis-0.10.8-i586-1.txz: Upgraded.
xap/mozilla-firefox-41.0.1-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-38.3.0-i586-1.txz: Upgraded.
xap/seamonkey-2.38-i586-1.txz: Upgraded.
Users browsing this forum: No registered users and 71 guests
