Locked
Post Napisano: 02 Oct 2018, 17:28
21.09.2018.
patches/packages/linux-4.4.157/*:  Upgraded.
  This kernel removes the unnecessary vmacache_flush_all code which could have
  led to a use-after-free situation and potentially local privilege escalation.
  In addition, it fixes some regressions which may have led to diminished X
  performance.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-17182
Post Napisano: 02 Oct 2018, 17:29
22.09.2018.
patches/packages/mozilla-firefox-60.2.1esr-i686-1_slack14.2.txz:  Upgraded.
   A potentially exploitable crash in TransportSecurityInfo used for SSL
   can be triggered by data stored in the local cache in the user profile
   directory. This issue is only exploitable in combination with another
   vulnerability allowing an attacker to write data into the local cache
   or from locally installed malware. This issue also triggers a
   non-exploitable startup crash for users switching between the Nightly
   and Release versions of Firefox if the same profile is used.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-23/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12383
Post Napisano: 13 Oct 2018, 19:12
02.10.2018.
Novi mozilla-firefox paketi za Slackware 14.2 i -current:
patches/packages/mozilla-firefox-60.2.2esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-24/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12387
Post Napisano: 13 Oct 2018, 19:14
10.10.2018.
Novi git paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/git-2.14.5-i586-1_slack14.2.txz:  Upgraded.
  Submodules' "URL"s come from the untrusted .gitmodules file, but we
  blindly gave it to "git clone" to clone submodules when "git clone
  --recurse-submodules" was used to clone a project that has such a
  submodule. The code has been hardened to reject such malformed URLs
  (e.g. one that begins with a dash). Credit for finding and fixing this
  vulnerability goes to joernchen and Jeff King, respectively.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-17456
Post Napisano: 25 Oct 2018, 21:24
16.10.2018.
Sveži libssh paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/libssh-0.7.6-i586-1_slack14.2.txz:  Upgraded.
  Fixed authentication bypass vulnerability.
    https://www.libssh.org/2018/10/16/libssh-0-8-4-and-0-7-6-security-and-bugfix-release/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10933
Post Napisano: 25 Oct 2018, 21:26
22.10.2018.
patches/packages/mozilla-firefox-60.3.0esr-i686-1_slack14.2.txz:  Upgraded.
Post Napisano: 03 Nov 2018, 17:47
31.10.2018.
patches/packages/curl-7.62.0-i586-1_slack14.2.txz:  Upgraded.
  This release fixes the following security issues:
  SASL password overflow via integer overflow.
  Use-after-free in handle close.
  Warning message out-of-buffer read.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16839
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16840
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16842
Post Napisano: 15 Nov 2018, 18:11
05.11.2018.
Sveži mariadb paketi za Slackware 14.1 i 14.2,
patches/packages/mariadb-10.0.37-i586-1_slack14.2.txz:  Upgraded.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3282
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9843
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3174
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3143
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3156
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3251
Post Napisano: 15 Nov 2018, 18:12
12.11.2018.
Sveži libtiff paketi za Slackware 14.2 i -current:
patches/packages/libtiff-4.0.10-i586-1_slack14.2.txz:  Upgraded.
  This update fixes some denial of service security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7456
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8905
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10779
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10963
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18661
Post Napisano: 24 Nov 2018, 20:34
21.11.2018.
Sveži openssl paketi za Slackware 14.2 i -current:
patches/packages/openssl-1.0.2q-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a timing side-channel flaw on processors which implement
  SMT/Hyper-Threading architectures, and a side channel attack on DSA
  signature generation that could allow an attacker to recover the private key.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5407
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0734
patches/packages/openssl-solibs-1.0.2q-i586-1_slack14.2.txz:  Upgraded.
Locked
