Napisano: 23 Jun 2018, 07:48
19.06.2018.
Sveži gnupg paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/gnupg-1.4.23-i586-1_slack14.2.txz: Upgraded.
Sanitize the diagnostic output of the original file name in verbose mode.
By using a made up file name in the message it was possible to fake status
messages. Using this technique it was for example possible to fake the
verification status of a signed mail.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12020
Napisano: 01 Jul 2018, 15:28
25.06.2018.
Sveži mozilla-firefox (ESR) paketi za Slackware 14.2 i -current:
patches/packages/mozilla-firefox-52.9.0esr-i586-1_slack14.2.txz: Upgraded.
Napisano: 14 Aug 2018, 17:24
05.07.2018.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-52.9.0-i586-1_slack14.2.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/52.9.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2018-18/
Napisano: 14 Aug 2018, 17:25
10.07.2018.
patches/packages/mozilla-thunderbird-52.9.1-i586-1_slack14.2.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/52.9.1/releasenotes/
https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
Napisano: 14 Aug 2018, 17:28
12.07.2018.
Sveži bind i curl paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/bind-9.10.8-i586-1_slack14.2.txz: Upgraded.
Fixed a bug where extraordinarily large zone transfers caused several
problems, with possible outcomes including corrupted journal files or
server exit due to assertion failure.
Don't permit recursive query service to unauthorized clients.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5738
patches/packages/curl-7.61.0-i586-1_slack14.2.txz: Upgraded.
This update fixes a buffer overflow in SMTP send.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0500
Napisano: 14 Aug 2018, 17:29
17.07.2018.
Sveži mutt paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/mutt-1.10.1-i586-1_slack14.2.txz: Upgraded.
This update fixes bugs and security issues. Upstream strongly recommends
that all IMAP and POP users upgrade as soon as possible.
Napisano: 14 Aug 2018, 17:30
18.07.2018.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/httpd-2.4.34-i586-1_slack14.2.txz: Upgraded.
This update fixes two denial of service issues:
mod_md: DoS via Coredumps on specially crafted requests
mod_http2: DoS for HTTP/2 connections by specially crafted requests
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8011
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1333
Napisano: 14 Aug 2018, 17:31
20.07.2018.
Sveži php paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/php-5.6.37-i586-1_slack14.2.txz: Upgraded.
Several security bugs have been fixed in this release, including:
Int Overflow lead to Heap OverFlow in exif_thumbnail_extract of exif.c
heap-buffer-overflow (READ of size 48) while reading exif data
Napisano: 14 Aug 2018, 17:41
27.07.2018.
patches/packages/linux-4.4.144/*: Upgraded.
This kernel update enables additional mitigations for spectre_v2 (IBPB and
IBRS_FW). It also enables reporting on the Speculative Store Bypass
vulnerability (aka GPZ Variant 4) which affects Intel processors and must
be patched with a microcode update.
To see the status of CPU vulnerability mitigations on your system, look at
the files in: /sys/devices/system/cpu/vulnerabilities
In addition, these kernels enable SMB2. Here's the complete list of kernel
config changes from the previous 4.4.132:
-X86_DEBUG_STATIC_CPU_HAS n
CIFS_SMB2 n -> y
+CC_OPTIMIZE_FOR_PERFORMANCE y
+CIFS_SMB311 n
+X86_FAST_FEATURE_TESTS y
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3639
Napisano: 14 Aug 2018, 17:43
31.07.2018.
Sveži file paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/file-5.34-i586-1_slack14.2.txz: Upgraded.
Fixed a denial of service crash when processing a crafted ELF file.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10360
(* Security fix *
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.49.4-i586-1_slack14.2.txz: Upgraded.
http://www.seamonkey-project.org/releases/seamonkey2.49.4
patches/packages/seamonkey-solibs-2.49.4-i586-1_slack14.2.txz: Upgraded.
Users browsing this forum: No registered users and 68 guests
