Napisano: 20 Aug 2017, 18:22
21.06.2017.
Sveži openvpn paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/openvpn-2.3.17-i586-1_slack14.2.txz: Upgraded.
This update fixes several denial of service issues discovered
by Guido Vranken.
https://community.openvpn.net/openvpn/wiki/VulnerabilitiesFixedInOpenVPN243
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7508
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7520
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7521
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7512
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7522
Napisano: 20 Aug 2017, 18:24
26.06.2017.
Sveži kernel paketi za Slackware 14.2 i current:
patches/packages/linux-4.4.74/*: Upgraded.
This kernel fixes two "Stack Clash" vulnerabilities reported by Qualys.
The first issue may allow attackers to execute arbitrary code with elevated
privileges. Failed attack attempts will likely result in denial-of-service
conditions. The second issue can be exploited to bypass certain security
restrictions and perform unauthorized actions.
https://www.qualys.com/2017/06/19/stack-clash/stack-clash.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000364
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000365
Napisano: 20 Aug 2017, 18:30
29.06.2017.
Sveži kernel paketi za Slackware 14.1:
patches/packages/linux-3.10.107/*: Upgraded.
In addition, a patch is included and preapplied to guard against other == sk
in unix_dgram_sendmsg. This bug has been known to cause Samba related stalls.
Thanks to Ben Stern for the bug report.
Napisano: 20 Aug 2017, 18:37
29.06.2017.
Sveži bind i httpd paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/bind-9.10.5_P2-i586-1_slack14.2.txz: Upgraded.
This update fixes a high severity security issue:
An error in TSIG handling could permit unauthorized zone transfers
or zone updates.
https://kb.isc.org/article/AA-01503/0
https://kb.isc.org/article/AA-01504/0
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3142
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3143
patches/packages/httpd-2.4.26-i586-1_slack14.2.txz: Upgraded.
This update fixes security issues which may lead to an authentication bypass
or a denial of service:
important: ap_get_basic_auth_pw() Authentication Bypass CVE-2017-3167
important: mod_ssl Null Pointer Dereference CVE-2017-3169
important: mod_http2 Null Pointer Dereference CVE-2017-7659
important: ap_find_token() Buffer Overread CVE-2017-7668
important: mod_mime Buffer Overread CVE-2017-7679
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3167
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3169
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7659
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7668
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7679
Sveži libgcrypt paketi za Slackware 14.2 i -current:
patches/packages/libgcrypt-1.7.8-i586-1_slack14.2.txz: Upgraded.
Mitigate a local flush+reload side-channel attack on RSA secret keys
dubbed "Sliding right into disaster".
https://eprint.iacr.org/2017/627
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7526
30.06.2017.
Sveži glibc i kernel paketi za Slackware 14.2 i -current:
patches/packages/glibc-2.23-i586-2_slack14.2.txz: Rebuilt.
Applied upstream security hardening patches from git.
https://sourceware.org/git/?p=glibc.git;a=commit;h=3c7cd21290cabdadd72984fb69bc51e64ff1002d
https://sourceware.org/git/?p=glibc.git;a=commit;h=46703a3995aa3ca2b816814aa4ad05ed524194dd
https://sourceware.org/git/?p=glibc.git;a=commit;h=c69d4a0f680a24fdbe323764a50382ad324041e9
https://sourceware.org/git/?p=glibc.git;a=commit;h=3776f38fcd267c127ba5eb222e2c614c191744aa
https://sourceware.org/git/?p=glibc.git;a=commit;h=adc7e06fb412a2a1ee52f8cb788caf436335b9f3
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000366
patches/packages/glibc-i18n-2.23-i586-2_slack14.2.txz: Rebuilt.
patches/packages/glibc-profile-2.23-i586-2_slack14.2.txz: Rebuilt.
patches/packages/glibc-solibs-2.23-i586-2_slack14.2.txz: Rebuilt.
patches/packages/linux-4.4.75/*: Upgraded.
This kernel fixes security issues that include possible stack exhaustion,
memory corruption, and arbitrary code execution.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7482
Napisano: 20 Aug 2017, 18:39
03.07.2017.
Sveži kernel paketi za Slackware 14.0:
patches/packages/linux-3.2.90/*: Upgraded.
This kernel fixes security issues (including "Stack Clash"). The issues
may result in denial-of-service conditions or may allow attackers to
execute arbitrary code with elevated privileges.
Napisano: 20 Aug 2017, 18:41
07.07.2017.
Sveži php paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/php-5.6.31-i586-1_slack14.2.txz: Upgraded.
https://php.net/ChangeLog-5.php#5.6.31
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9224
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9226
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9227
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9228
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9229
Napisano: 20 Aug 2017, 18:42
09.07.2017.
Sveži irssi paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/irssi-1.0.4-i586-1_slack14.2.txz: Upgraded.
This release fixes two remote crash issues as well as a few bugs.
https://irssi.org/security/irssi_sa_2017_07.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-10965
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-10966
Napisano: 20 Aug 2017, 18:43
10.07.2017.
Sveži libtirpc i rpcbind paketi za Slackware 14.2 i -current:
patches/packages/libtirpc-1.0.1-i586-3_slack14.2.txz: Rebuilt.
Patched a bug which can cause a denial of service through memory exhaustion.
Thanks to Robby Workman.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8779
patches/packages/rpcbind-0.2.4-i586-1_slack14.2.txz: Upgraded.
Napisano: 20 Aug 2017, 18:44
13.07.2017.
Sveži httpd paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/httpd-2.4.27-i586-1_slack14.2.txz: Upgraded.
Read after free in mod_http2 (CVE-2017-9789)
Uninitialized memory reflection in mod_auth_digest (CVE-2017-9788)
Thanks to Robert Swiecki for reporting these issues.
https://httpd.apache.org/security/vulnerabilities_24.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9789
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9788
Users browsing this forum: No registered users and 24 guests
