Locked
Post Napisano: 06 May 2017, 10:14
13.04.2017.
Sveži bind paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current
patches/packages/bind-9.10.4_P8-i586-1_slack14.2.txz:  Upgraded.
  Fixed denial of service security issues.
    https://kb.isc.org/article/AA-01465
    https://kb.isc.org/article/AA-01466
    https://kb.isc.org/article/AA-01471
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3136
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3137
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3138
Post Napisano: 06 May 2017, 10:15
18.04.2017.
Sveži minicom paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current
patches/packages/minicom-2.7.1-i586-1_slack14.2.txz:  Upgraded.
  Fix an out of bounds data access that can lead to remote code execution.
  This issue was found by Solar Designer of Openwall during a security audit
  of the Virtuozzo 7 product, which contains derived downstream code in its
  prl-vzvncserver component.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7467
Post Napisano: 06 May 2017, 10:18
22.04.2017.
Sveži firefox paketi za Slackware 14.1
patches/packages/mozilla-firefox-45.9.0esr-i486-1_slack14.1.txz:  Upgraded.
  Also, switching back to the 45.x ESR branch due to instabilty of the
  52.x ESR branch on Slackware 14.1.
Sveži ntp paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current
patches/packages/ntp-4.2.8p10-i586-1_slack14.2.txz:  Upgraded.
  In addition to bug fixes and enhancements, this release fixes security
  issues of medium and low severity:
  Denial of Service via Malformed Config (Medium)
  Authenticated DoS via Malicious Config Option (Medium)
  Potential Overflows in ctl_put() functions (Medium)
  Buffer Overflow in ntpq when fetching reslist from a malicious ntpd (Medium)
  0rigin DoS (Medium)
  Buffer Overflow in DPTS Clock (Low)
  Improper use of snprintf() in mx4200_send() (Low)
  The following issues do not apply to Linux systems:
  Privileged execution of User Library code (WINDOWS PPSAPI ONLY) (Low)
  Stack Buffer Overflow from Command Line (WINDOWS installer ONLY) (Low)
  Data Structure terminated insufficiently (WINDOWS installer ONLY) (Low)
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6464
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6463
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6458
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6460
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9042
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6462
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6451
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6455
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6452
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6459
Sveži proftpd paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current
patches/packages/proftpd-1.3.5e-i586-1_slack14.2.txz:  Upgraded.
  This release fixes a security issue:
  AllowChrootSymlinks off does not check entire DefaultRoot path for symlinks.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7418
Post Napisano: 06 May 2017, 10:19
24.04.2017.
Sveži firefox paketi za Slackware 14.2 i -current
patches/packages/mozilla-firefox-52.1.0esr-i586-1_slack14.2.txz:  Upgraded.
Post Napisano: 06 May 2017, 10:20
01.05.2017.
Sveži rxvt paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current
patches/packages/rxvt-2.7.10-i586-5_slack14.2.txz:  Rebuilt.
  Patched an integer overflow that can crash rxvt with an escape sequence,
  or possibly have unspecified other impact.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7483
Post Napisano: 21 May 2017, 10:05
16.05.2017.
Sveži freetype paketi za Slackware 13.0, 13.37, 14.0, 14.1, 14.2, i -current
patches/packages/freetype-2.6.3-i586-2_slack14.2.txz:  Rebuilt.
  This update fixes an out-of-bounds write caused by a heap-based buffer
  overflow related to the t1_builder_close_contour function in psaux/psobjs.c.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8287
Sveži kdelibs paketi za Slackware 13.37, 14.0, 14.1, 14.2, i -current
patches/packages/kdelibs-4.14.32-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a security issue with KAuth that can lead to gaining
  root from an unprivileged account.
    http://www.openwall.com/lists/oss-security/2017/05/10/3
    https://www.kde.org/info/security/advisory-20170510-1.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8422
Post Napisano: 18 Jun 2017, 19:13
24.05.2017.
Sveži samba paketi za Slackware 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/samba-4.4.14-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a remote code execution vulnerability, allowing a
  malicious client to upload a shared library to a writable share, and
  then cause the server to load and execute it.
    https://www.samba.org/samba/security/CVE-2017-7494.html
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7494
Post Napisano: 18 Jun 2017, 19:14
30.05.2017.
Sveži sudo paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/sudo-1.8.20p1-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a potential overwrite of arbitrary system files.
  This bug was discovered and analyzed by Qualys, Inc.
    https://www.sudo.ws/alerts/linux_tty.html
    http://www.openwall.com/lists/oss-security/2017/05/30/16
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-1000367
Post Napisano: 18 Jun 2017, 19:15
07.06.2017.
Sveži irssi paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/irssi-1.0.3-i586-1_slack14.2.txz:  Upgraded.
  Fixed security issues that may result in a denial of service.
    https://irssi.org/security/irssi_sa_2017_06.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9468
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9469
Post Napisano: 18 Jun 2017, 19:17
14.06.2017.
Sveži bind paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/bind-9.10.5_P1-i586-1_slack14.2.txz:  Upgraded.
  Fixed denial of service security issue:
  Some RPZ configurations could go into an infinite query loop when
  encountering responses with TTL=0.
    https://kb.isc.org/article/AA-01495
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3140
Sveži mozilla-firefox paketi za Slackware 14.2:
patches/packages/mozilla-firefox-52.2.0esr-i586-1_slack14.2.txz:  Upgraded.
Locked
Users browsing this forum: No registered users and 43 guests
