Locked
Post Napisano: 22 Aug 2021, 09:36
11.03.20021.
Sveži git paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/git-2.17.6-i586-1_slack14.2.txz:  Upgraded.
  On case-insensitive file systems with support for symbolic links, if Git is
  configured globally to apply delay-capable clean/smudge filters (such as Git
  LFS), Git could be fooled into running remote code during a clone. Credit for
  finding and fixing this vulnerability goes to Matheus Tavares, helped by
  Johannes Schindelin.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-21300
13.03.2021.
patches/packages/linux-4.4.261/*:  Upgraded.
  These updates fix various bugs and security issues, including the recently
  announced iSCSI vulnerabilities allowing local privilege escalation.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27363
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27364
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27365
27.03.2021.
Sveži xterm paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/xterm-367-i586-1_slack14.2.txz:  Upgraded.
  xterm before Patch #366 allows remote attackers to execute arbitrary code or
  cause a denial of service (segmentation fault) via a crafted UTF-8 combining
  character sequence.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27135
31.03.2021.
patches/packages/curl-7.76.0-i586-1_slack14.2.txz:  Upgraded.
  Authentication Bypass by Spoofing.
  Exposure of Private Personal Information to an Unauthorized Actor.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22890
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22876
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.53.7-i686-1_slack14.2.txz:  Upgraded.
    https://www.seamonkey-project.org/releases/seamonkey2.53.7
Post Napisano: 22 Aug 2021, 09:40
12.04.2021.
Sveži dnsmasq i irssi paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/dnsmasq-2.85-i586-1_slack14.2.txz:  Upgraded.
  Use random source ports where possible if source addresses/interfaces in use.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3448
patches/packages/irssi-1.2.3-i586-1_slack14.2.txz:  Upgraded.
  See the NEWS file for details.
20.04.2021.
patches/packages/seamonkey-2.53.7.1-i686-1_slack14.2.txz:  Upgraded.
    https://www.seamonkey-project.org/releases/seamonkey2.53.7.1
28.04.2021.
patches/packages/bind-9.11.31-i586-1_slack14.2.txz:  Upgraded.
  This update fixes bugs and the following security issues:
  A specially crafted GSS-TSIG query could cause a buffer overflow in the
  ISC implementation of SPNEGO.
  named crashed when a DNAME record placed in the ANSWER section during DNAME
  chasing turned out to be the final answer to a client query.
  Insufficient IXFR checks could result in named serving a zone without an SOA
  record at the apex, leading to a RUNTIME_CHECK assertion failure when the
  zone was subsequently refreshed. This has been fixed by adding an owner name
  check for all SOA records which are included in a zone transfer.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25216
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25215
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25214
Post Napisano: 22 Aug 2021, 09:45
15.05.2021.
Sveži libxml2 paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/libxml2-2.9.12-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a denial-of-service security issue.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3541
19.05.2021.
Sveži libX11 paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/libX11-1.7.1-i586-1_slack14.2.txz:  Upgraded.
  This update fixes missing request length checks in libX11 that can lead to
  the emission of extra X protocol requests to the X server.
    https://lists.x.org/archives/xorg-announce/2021-May/003088.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-31535
23.05.2021.
Sveži expat paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/expat-2.4.1-i586-1_slack14.2.txz:  Upgraded.
  This update provides new mitigations against the "billion laughs" denial
  of service attack.
    https://github.com/libexpat/libexpat/blob/R_2_4_1/expat/Changes
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-0340
25.05.2021.
Sveži gnutls paketi za Slackware 14.2 i -current:
patches/packages/gnutls-3.6.16-i586-1_slack14.2.txz:  Upgraded.
  Fixed potential miscalculation of ECDSA/EdDSA code backported from Nettle.
  In GnuTLS, as long as it is built and linked against the fixed version of
  Nettle, this only affects GOST curves.  [CVE-2021-20305]
  Fixed potential use-after-free in sending "key_share" and "pre_shared_key"
  extensions. When sending those extensions, the client may dereference a
  pointer no longer valid after realloc. This happens only when the client
  sends a large Client Hello message, e.g., when HRR is sent in a resumed
  session previously negotiated large FFDHE parameters, because the initial
  allocation of the buffer is large enough without having to call realloc
  (#1151).  [GNUTLS-SA-2021-03-10, CVSS: low]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-20305
26.05.2021.
patches/packages/curl-7.77.0-i586-1_slack14.2.txz:  Upgraded.
  schannel cipher selection surprise
  TELNET stack contents disclosure
  TLS session caching disaster
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22297
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22298
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22901
29.05.2021.
Sveži dhcp paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/dhcp-4.4.2_P1-i586-1_slack14.2.txz:  Upgraded.
  Corrected a buffer overwrite possible when parsing hexadecimal
  literals with more than 1024 octets. Reported by Jon Franklin from Dell,
  and also by Pawel Wieczorkiewicz from Amazon Web Services. [Gitlab #182]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25217
Post Napisano: 22 Aug 2021, 09:48
07.06.2021.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/httpd-2.4.48-i586-1_slack14.2.txz:  Upgraded.
  mod_http2: Fix a potential NULL pointer dereference.
  Unexpected <Location> section matching with 'MergeSlashes OFF'.
  mod_auth_digest: possible stack overflow by one nul byte while validating
  the Digest nonce.
  mod_session: Fix possible crash due to NULL pointer dereference, which
  could be used to cause a Denial of Service with a malicious backend
  server and SessionHeader.
  could be used to cause a Denial of Service.
  mod_proxy_http: Fix possible crash due to NULL pointer dereference, which
  mod_proxy_wstunnel, mod_proxy_http: Handle Upgradable protocols end-to-end
  negotiation.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-31618
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-30641
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-35452
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-26691
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-26690
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-13950
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17567
Sveži polkit paketi za Slackware 14.2 i -current:
patches/packages/polkit-0.113-i586-3_slack14.2.txz:  Rebuilt.
  This update includes a mitigation for local privilege escalation using
  polkit_system_bus_name_get_creds_sync().
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3560
Post Napisano: 22 Aug 2021, 09:50
20.07.2021.
Wed Jul 21 05:30:44 UTC 2021
patches/packages/linux-4.4.276/*:  Upgraded.
  announced local privilege escalation vulnerability in the filesystem layer
  (CVE-2021-33909).
    https://www.qualys.com/2021/07/20/cve-2021-33909/sequoia-local-privilege-escalation-linux.txt
    Fixed in 4.4.262:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19060
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19061
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-28660
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-20261
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29265
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-16232
    Fixed in 4.4.263:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-28964
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-28972
    Fixed in 4.4.264:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-28688
    Fixed in 4.4.265:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3483
    Fixed in 4.4.266:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29154
    Fixed in 4.4.267:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22555
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25672
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25673
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25670
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25671
    Fixed in 4.4.269:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33034
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-0605
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-31916
    Fixed in 4.4.270:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26558
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0129
    Fixed in 4.4.271:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-24587
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-24586
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-24588
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26139
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26147
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-29650
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-32399
    Fixed in 4.4.272:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3564
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3573
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3587
    Fixed in 4.4.274:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-34693
    Fixed in 4.4.276:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33909
21.07.2021.
patches/packages/curl-7.78.0-i586-1_slack14.2.txz:  Upgraded.
  CURLOPT_SSLCERT mixup with Secure Transport
  TELNET stack contents disclosure again
  Bad connection reuse due to flawed path name checks
  Metalink download sends credentials
  Wrong content via metalink not discarded
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22926
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22925
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22924
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22923
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22922
Post Napisano: 03 Sep 2021, 19:30
31.08.2021.
Sveži ntfs-3g paketi za Slackware 14.2 i -current:
patches/packages/ntfs-3g-2021.8.22-i586-1_slack14.2.txz:  Upgraded.
  Fixed vulnerabilities that may allow an attacker using a maliciously
  crafted NTFS-formatted image file or external storage to potentially
  execute arbitrary privileged code.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33285
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-35269
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-35268
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33289
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33286
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-35266
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33287
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-35267
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39251
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39252
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39253
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39254
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39255
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39256
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39257
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39258
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39259
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39260
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39261
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39262
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39263
Post Napisano: 20 Sep 2021, 16:48
15.09.2021.
patches/packages/curl-7.79.0-i586-1_slack14.2.txz:  Upgraded.
  clear the leftovers pointer when sending succeeds.
  do not ignore --ssl-reqd.
  reject STARTTLS server response pipelining.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22945
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22946
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22947
Post Napisano: 20 Sep 2021, 16:49
16.09.2021.
patches/packages/httpd-2.4.49-i586-1_slack14.2.txz:  Upgraded.
  mod_proxy: Server Side Request Forgery (SSRF) vulnerabilty [Yann Ylavic]
  core: ap_escape_quotes buffer overflow
  mod_proxy_uwsgi: Out of bound read vulnerability [Yann Ylavic]
  core: null pointer dereference on malformed request
  mod_http2: Request splitting vulnerability with mod_proxy [Stefan Eissing]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-40438
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39275
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-36160
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-34798
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33193
Post Napisano: 22 Sep 2021, 09:00
21.09.2021.
Sveži alpine paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/alpine-2.25-i586-1_slack14.2.txz:  Upgraded.
  Fixed a denial-of-service security issue where untagged responses from an
  IMAP server are accepted before STARTTLS.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38370
Post Napisano: 10 Feb 2022, 23:22
05.10.2021.
patches/packages/httpd-2.4.50-i586-1_slack14.2.txz:  Upgraded.
  Fixed null pointer dereference in h2 fuzzing.
  Fixed path traversal and file disclosure vulnerability.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-41524
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-41773
07.10.2021.
patches/packages/httpd-2.4.51-i586-1_slack14.2.txz:  Upgraded.
  SECURITY: CVE-2021-42013: Path Traversal and Remote Code
  Execution in Apache HTTP Server 2.4.49 and 2.4.50 (incomplete
  fix of CVE-2021-41773) (cve.mitre.org)
  It was found that the fix for CVE-2021-41773 in Apache HTTP
  Server 2.4.50 was insufficient.  An attacker could use a path
  traversal attack to map URLs to files outside the directories
  configured by Alias-like directives.
  If files outside of these directories are not protected by the
  usual default configuration "require all denied", these requests
  can succeed. If CGI scripts are also enabled for these aliased
  pathes, this could allow for remote code execution.
  This issue only affects Apache 2.4.49 and Apache 2.4.50 and not
  earlier versions.
  Credits: Reported by Juan Escobar from Dreamlab Technologies,
  Fernando MuA+-oz from NULL Life CTF Team, and Shungo Kumasaka
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-42013
27.10.2021.
patches/packages/bind-9.11.36-i586-1_slack14.2.txz:  Upgraded.
  This update fixes bugs and the following security issue:
  The "lame-ttl" option is now forcibly set to 0. This effectively disables
  the lame server cache, as it could previously be abused by an attacker to
  significantly degrade resolver performance.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25219
Locked
Users browsing this forum: Baidu [Spider] and 42 guests
