Locked
Post Napisano: 17 Jul 2013, 10:10
16.07.2013.
Novi php paketi su dostupni za Slackware 12.1, 12.2, 13.0, 13.1, 13.37,
14.0 i -current.
patches/packages/php-5.4.17-i486-1_slack14.0.txz:  Upgraded.
  This update fixes an issue where XML in PHP does not properly consider
  parsing depth, which allows remote attackers to cause a denial of service
  (heap memory corruption) or possibly have unspecified other impact via a
  crafted document that is processed by the xml_parse_into_struct function.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4113
Post Napisano: 04 Aug 2013, 00:32
03.08.2013.
Nadogradnja za gnupg i libgcrypt za Slackware 12.1, 12.2, 13.0, 13.1, 13.37, 14.0 i -current
patches/packages/gnupg-1.4.14-i486-1_slack14.0.txz:  Upgraded.
  Mitigate the Yarom/Falkner flush+reload side-channel attack on RSA
  secret keys.
    http://eprint.iacr.org/2013/448
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4242
patches/packages/libgcrypt-1.5.3-i486-1_slack14.0.txz:  Upgraded.
  secret keys.
Post Napisano: 06 Aug 2013, 20:34
06.08.2013.
Novi bind paketi za 12.1, 12.2, 13.0, 13.1, 13.37, 14.0 i -current
patches/packages/bind-9.9.3_P2-i486-1_slack14.0.txz:  Upgraded.
  This update fixes a security issue where a specially crafted query can cause
  BIND to terminate abnormally, resulting in a denial of service.
    https://kb.isc.org/article/AA-01015
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4854
Novi httpd paketi za 12.1, 12.2, 13.0, 13.1, 13.37, 14.0 i -current
patches/packages/httpd-2.4.6-i486-1_slack14.0.txz:  Upgraded.
  This update addresses two security issues:
  * SECURITY: CVE-2013-1896 (cve.mitre.org) Sending a MERGE request against
    a URI handled by mod_dav_svn with the source href (sent as part of the
    request body as XML) pointing to a URI that is not configured for DAV
    will trigger a segfault.
  * SECURITY: CVE-2013-2249 (cve.mitre.org) mod_session_dbd: Make sure that
    dirty flag is respected when saving sessions, and ensure the session ID
    is changed each time the session changes.  This changes the format of the
    updatesession SQL statement.  Existing configurations must be changed.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1896
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-2249
Novi Samba paketi za 13.1, 13.37, 14.0 i -current
patches/packages/samba-3.6.17-i486-1_slack14.0.txz:  Upgraded.
  This update fixes missing integer wrap protection in an EA list reading
  that can allow authenticated or guest connections to cause the server to
  loop, resulting in a denial of service.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4124
Post Napisano: 09 Aug 2013, 13:41
07.08.2013.
Nadogradnja Seamonkey za Slak 14 i -current, Firefox i Thunderbird za Slak 13.37, 14 i -current.
patches/packages/seamonkey-2.20-i486-1_slack14.0.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.20-i486-1_slack14.0.txz:  Upgraded.
patches/packages/mozilla-firefox-17.0.8esr-i486-1_slack14.0.txz:  Upgraded.
patches/packages/mozilla-thunderbird-17.0.8-i486-1_slack14.0.txz:  Upgraded.
Post Napisano: 25 Aug 2013, 10:13
Bilo je nadogradnji i to pre 4 dana ali mi nije stiglo obaveštenje pa i ja kasnim sa novostima.
21.08.2013.
Hplip i xpdf nadogradnje za Slackware 12.1, 12.2, 13.0, 13.1, 13.37,
14.0 i -current
Poppler nadogradnja za Slackware 14 i -current
patches/packages/hplip-3.12.9-i486-2_slack14.0.txz:  Rebuilt.
  This update fixes a stack-based buffer overflow in the hpmud_get_pml
  function that can allow remote attackers to cause a denial of service
  (crash) and possibly execute arbitrary code via a crafted SNMP response
  with a large length value.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2010-4267
patches/packages/xpdf-3.03-i486-1_slack14.0.txz:  Upgraded.
  Sanitize error messages to remove escape sequences that could be used to
  exploit vulnerable terminal emulators.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2142
  Thanks to mancha.
patches/packages/poppler-0.20.2-i486-2_slack14.0.txz:  Rebuilt.
Post Napisano: 01 Sep 2013, 01:31
30.08.2013.
Gnutls i php za Slackware 14 i -current.
patches/packages/php-5.4.19-i486-1_slack14.0.txz:  Upgraded.
  Fixed handling null bytes in subjectAltName (CVE-2013-4248).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4248
patches/packages/gnutls-3.0.26-i486-1_slack14.0.txz:  Upgraded.
  This update prevents a side-channel attack which may allow remote attackers
  to conduct distinguishing attacks and plaintext recovery attacks using
  statistical analysis of timing data for crafted packets.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1619
A onda izvinjenje i novija verzija gnutls:
Sorry about having to reissue this one -- I pulled it from ftp.gnu.org not
realizing that the latest version there was actually months out of date.
patches/packages/gnutls-3.0.31-i486-1_slack14.0.txz:  Upgraded.
  [Updated to the correct version to fix fetching the "latest" from gnu.org]
Post Napisano: 09 Sep 2013, 10:50
09.09.2013.
Subversion za Slackware 14 i -current.
patches/packages/subversion-1.7.13-i486-1_slack14.0.txz:  Upgraded.
  This update fixes a local privilege escalation vulnerability via
  symlink attack.
    http://subversion.apache.org/security/CVE-2013-4277-advisory.txt
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4277
Post Napisano: 18 Sep 2013, 11:50
17.09.2013.
Mozzila Firefox, Thunderbird za Slackware 13.37, 14.0 i -current.
Nova glibc nagodradnja paketa za Slackware 13.0, 13.1, 13.37, 14.0 i -current.
patches/packages/mozilla-thunderbird-17.0.9esr-i486-1_slack14.0.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbirdESR.html
patches/packages/mozilla-firefox-17.0.9esr-i486-1_slack14.0.txz:  Upgraded.
patches/packages/glibc-2.15-i486-8_slack14.0.txz:  Rebuilt.
  Patched to fix integer overflows in pvalloc, valloc, and
  posix_memalign/memalign/aligned_alloc.
  Thanks to mancha for the backported patch.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-2013-4332
  Also, as long as these packages were being respun anyway, I added a patch
  to fix the check for AVX opcodes.  This was causing crashes on Xen.
  Thanks to Dale Gallagher.
patches/packages/glibc-i18n-2.15-i486-8_slack14.0.txz:  Rebuilt.
patches/packages/glibc-profile-2.15-i486-8_slack14.0.txz:  Rebuilt.
patches/packages/glibc-solibs-2.15-i486-8_slack14.0.txz:  Rebuilt.
patches/packages/glibc-zoneinfo-2013d_2013d-noarch-8_slack14.0.txz:  Rebuilt.
Post Napisano: 29 Sep 2013, 12:56
28.09.2013.
Seamonkey nadogradnja - 2.21
patches/packages/seamonkey-2.21-i486-1_slack14.0.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.21-i486-1_slack14.0.txz:  Upgraded.
Post Napisano: 15 Oct 2013, 12:35
14.10.2013.
Gnupg nadogradnja za Slackware 12.1, 12.2, 13.0, 13.1, 13.37, 14 i current
patches/packages/gnupg-1.4.15-i486-1_slack14.0.txz:  Upgraded.
  Fixed possible infinite recursion in the compressed packet
  parser. [CVE-2013-4402]
  Protect against rogue keyservers sending secret keys.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4402
Gnutls nagodradnja za Slackware 12.1, 12.2, 13.0, 13.1, 13.37, 14 i current:
patches/packages/gnutls-2.10.5-i486-2_slack13.37.txz:  Rebuilt.
  Other minor security issues are patched as well.
  Thanks to mancha for backporting these patches.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2011-4128
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-1569
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-1573
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-2116
Xorg-server nadogradnja za Slackware 12.1, 12.2, 13.0, 13.1, 13.37, 14 i current:
patches/packages/xorg-server-1.12.4-i486-2_slack14.0.txz:  Rebuilt.
  Patched a use-after-free bug that can cause an X server crash or
  memory corruption.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4396
patches/packages/xorg-server-xephyr-1.12.4-i486-2_slack14.0.txz:  Rebuilt.
patches/packages/xorg-server-xnest-1.12.4-i486-2_slack14.0.txz:  Rebuilt.
patches/packages/xorg-server-xvfb-1.12.4-i486-2_slack14.0.txz:  Rebuilt.
Gnupg2 nadogradnja za Slackware 13.37, 14 i current:
patches/packages/gnupg2-2.0.22-i486-1_slack14.0.txz:  Upgraded.
Libgpg-error nadogradnja za Slackware 13.37, 14 i current
patches/packages/libgpg-error-1.11-i486-1_slack14.0.txz:  Upgraded.
  This package upgrade was needed by the new version of gnupg2.
Locked
Users browsing this forum: No registered users and 74 guests
