Novosti u *current* -u
Post Napisano: 25 Jun 2012, 23:53
A xfce 4.10? :|
Post Napisano: 27 Jun 2012, 07:41
Tue Jun 26 18:35:11 UTC 2012
Slackware-current
d/cmake-2.8.8-i486-2.txz:  Rebuilt.
l/PyQt-4.9.1-i486-3.txz:  Rebuilt.
n/nmap-6.01-i486-1.txz:  Upgraded.
xap/imagemagick-6.7.7_9-i486-1.txz:  Upgraded.
xap/rdesktop-1.7.1-i486-1.txz:  Upgraded.
Slackware64-current
d/cmake-2.8.8-x86_64-2.txz:  Rebuilt.
l/PyQt-4.9.1-x86_64-3.txz:  Rebuilt.
n/nmap-6.01-x86_64-1.txz:  Upgraded.
xap/imagemagick-6.7.7_9-x86_64-1.txz:  Upgraded.
xap/rdesktop-1.7.1-x86_64-1.txz:  Upgraded.
Tue Jun 26 22:35:09 UTC 2012
Slackware-current
a/aaa_base-14.0-i486-2.txz:  Rebuilt.
a/grep-2.12-i486-1.txz:  Upgraded.
a/xz-5.0.4-i486-1.tgz:  Upgraded.
l/pycurl-7.19.0-i486-1.txz:  Upgraded.
n/curl-7.26.0-i486-1.txz:  Upgraded.
Slackware64-current
a/aaa_base-14.0-x86_64-2.txz:  Rebuilt.
a/grep-2.12-x86_64-1.txz:  Upgraded.
a/xz-5.0.4-x86_64-1.tgz:  Upgraded.
l/pycurl-7.19.0-x86_64-1.txz:  Added.
n/curl-7.26.0-x86_64-1.txz:  Upgraded.
Wed Jun 27 04:38:25 UTC 2012
Najinteresantnija mi je promjena koja se odnosi na shadow:
Default to SHA256 encryption for /etc/shadow on new installations.
HINT: You might want to make this change in an existing /etc/login.defs:
ENCRYPT_METHOD SHA256
or even this, if the increased CPU time is not an issue:
ENCRYPT_METHOD SHA512
Ukratko, podrazumjevana enkripcija za /etc/shadow je SHA256, ali to možete promjeniti.
Slackware-current
a/shadow-4.1.4.3-i486-3.txz:  Rebuilt.
n/lynx-2.8.7-i486-2.txz:  Rebuilt.
xap/blueman-r708-i486-2.txz:  Rebuilt.
Slackware64-current
a/shadow-4.1.4.3-x86_64-3.txz:  Rebuilt.
n/lynx-2.8.7-x86_64-2.txz:  Rebuilt.
xap/blueman-r708-x86_64-2.txz:  Reverted.
Post Napisano: 29 Jun 2012, 12:49
Thu Jun 28 21:40:00 UTC 2012
Slackware-current
a/acl-2.2.51-i486-1.txz:  Upgraded.
a/attr-2.4.46-i486-1.txz:  Upgraded.
a/coreutils-8.17-i486-1.txz:  Upgraded.
a/dcron-4.5-i486-1.txz:  Upgraded.
a/file-5.11-i486-1.txz:  Upgraded.
a/kbd-1.15.3-i486-1.txz:  Upgraded.
a/kmod-9-i486-1.txz:  Added.
a/less-444-i486-1.txz:  Upgraded.
a/logrotate-3.8.1-i486-1.txz:  Upgraded.
a/module-init-tools-3.16-i486-1.txz:  Removed.
a/ntfs-3g-2012.1.15-i486-1.txz:  Upgraded.
a/sdparm-1.07-i486-1.txz:  Upgraded.
a/xfsprogs-3.1.8-i486-1.txz:  Upgraded.
ap/diffutils-3.2-i486-1.txz:  Upgraded.
ap/ghostscript-9.05-i486-2.txz:  Rebuilt.
ap/lsscsi-0.26-i486-1.txz:  Upgraded.
ap/ntfsprogs-2.0.0-i486-2.txz:  Removed.
ap/sudo-1.8.5p2-i486-1.txz:  Upgraded.
d/bison-2.5.1-i486-1.txz:  Upgraded.
d/intltool-0.50.2-i486-1.txz:  Upgraded.
l/libusb-1.0.9-i486-1.txz:  Upgraded.
l/libusb-compat-0.1.4-i486-1.txz:  Added.
n/cyrus-sasl-2.1.23-i486-2.txz:  Reverted.
xap/imagemagick-6.7.7_10-i486-1.txz
xap/rdesktop-1.7.1-i486-2.txz:  Rebuilt.
Slackware64-current
a/acl-2.2.51-x86_64-1.txz:  Upgraded.
a/attr-2.4.46-x86_64-1.txz:  Upgraded.
a/coreutils-8.17-x86_64-1.txz:  Upgraded.
a/dcron-4.5-x86_64-1.txz:  Upgraded.
a/file-5.11-x86_64-1.txz:  Upgraded.
a/kbd-1.15.3-x86_64-1.txz:  Upgraded.
a/kmod-9-x86_64-1.txz:  Added.
a/less-444-x86_64-1.txz:  Upgraded.
a/logrotate-3.8.1-x86_64-1.txz:  Upgraded.
a/module-init-tools-3.16-x86_64-1.txz:  Removed.
a/ntfs-3g-2012.1.15-x86_64-1.txz:  Upgraded.
a/sdparm-1.07-x86_64-1.txz:  Upgraded.
a/xfsprogs-3.1.8-x86_64-1.txz:  Upgraded.
ap/diffutils-3.2-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.05-x86_64-2.txz:  Rebuilt.
ap/lsscsi-0.26-x86_64-1.txz:  Upgraded.
ap/ntfsprogs-2.0.0-x86_64-2.txz:  Removed.
ap/sudo-1.8.5p2-x86_64-1.txz:  Upgraded.
d/bison-2.5.1-x86_64-1.txz:  Upgraded.
d/intltool-0.50.2-x86_64-1.txz:  Upgraded.
l/libusb-1.0.9-x86_64-1.txz:  Upgraded.
l/libusb-compat-0.1.4-x86_64-1.txz:  Added.
n/cyrus-sasl-2.1.23-x86_64-2.txz:  Reverted.
xap/imagemagick-6.7.7_10-x86_64-1.txz:  Upgraded.
xap/rdesktop-1.7.1-x86_64-2.txz:  Rebuilt.
Fri Jun 29 04:49:26 UTC 2012
Slackware-current
a/kmod-9-i486-2.txz:  Rebuilt.
Slackware64-current
a/kmod-9-x86_64-2.txz:  Rebuilt.
Post Napisano: 30 Jun 2012, 00:52
Fri Jun 29 17:17:16 UTC 2012
Slackware-current
ap/linuxdoc-tools-0.9.67-i486-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.23-i486-3.txz:  Rebuilt.
Slackware64-current
ap/linuxdoc-tools-0.9.67-x86_64-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.23-x86_64-3.txz:  Rebuilt.
Post Napisano: 30 Jun 2012, 13:06
Sat Jun 30 04:48:12 UTC 2012
Slackware-current
a/shadow-4.1.4.3-i486-4.txz:  Rebuilt.
xap/sane-1.0.22-i486-3.txz:  Rebuilt.
Slackware64-current
a/shadow-4.1.4.3-x86_64-4.txz:  Rebuilt.
xap/sane-1.0.22-x86_64-3.txz:  Rebuilt.
Post Napisano: 14 Jul 2012, 13:29
Fri Jul 13 23:14:15 UTC 2012
It's Friday the 13th, and Mercury is going into retrograde... seems like the perfect time to break things! A few notes are in order here... first, we've switched to using openssl-1.0.1c, which changes the major number for the crypto and ssl libraries from .0 to .1, meaning everything linked with the previous version of openssl will need to be recompiled. The lib{crypto,ssl}.so.0 libraries were backed up into aaa_elflibs, but this only means that binaries linked with those libraries will start, not that SSL will continue to work for them. The hashing format in /etc/ssl/certs/ has changed, so any programs linking to the old libraries will not be able to use them. Next, Java has gone away due to licensing restrictions... Finally, these changes have broken Xfce as it exists in -current at the moment, but I'll try to do something about that soon. Thanks to Robby Workman and Eric Hameleers for lots of help on these updates!
Kratak pregled:
* prelazak na openssl-1.0.1c (potrebno rekompajlirati sve što zavisi od ove biblioteke)
* Java paketi su uklonjeni
* XFCE je trenutno nefunkcionalan
Slackware-current
a/aaa_elflibs-14.0-i486-1.txz:  Upgraded.
a/cryptsetup-1.4.3-i486-1.txz:  Upgraded.
a/cups-1.5.3-i486-2.txz:  Rebuilt.
a/cxxlibs-6.0.17-i486-1.txz:  Upgraded.
a/dbus-1.4.20-i486-1.txz:  Upgraded.
a/grep-2.13-i486-1.txz:  Upgraded.
a/gzip-1.5-i486-1.txz:  Upgraded.
a/kernel-generic-3.2.23-i486-1.txz
a/kernel-generic-smp-3.2.23_smp-i686-1.txz
a/kernel-huge-3.2.23-i486-1.txz
a/kernel-huge-smp-3.2.23_smp-i686-1.txz
a/kernel-modules-3.2.23-i486-1.txz
a/kernel-modules-smp-3.2.23_smp-i686-1.txz
a/lvm2-2.02.96-i486-1.txz:  Upgraded.
a/mdadm-3.2.5-i486-1.txz:  Upgraded.
a/mkinitrd-1.4.7-i486-1.txz:  Upgraded.
a/openssl-solibs-1.0.1c-i486-1.txz:  Upgraded.
a/pciutils-3.1.9-i486-1.txz:  Upgraded.
a/sysvinit-2.88dsf-i486-1.txz:  Upgraded.
a/sysvinit-scripts-2.0-noarch-1.txz:  Upgraded.
a/udev-175-i486-1.txz:  Upgraded.
a/upower-0.9.17-i486-1.txz:  Upgraded.
a/usbutils-006-i486-1.txz:  Upgraded.
a/util-linux-2.21.2-i486-1.txz:  Upgraded.
ap/cdrdao-1.2.3-i486-2.txz:  Rebuilt.
ap/cdrtools-3.01a07-i486-1.txz:  Upgraded.
ap/ghostscript-9.05-i486-3.txz:  Rebuilt.
ap/gphoto2-2.4.14-i486-1.txz:  Upgraded.
ap/gutenprint-5.2.8-i486-2.txz:  Rebuilt.
ap/hplip-3.12.6-i486-2.txz:  Rebuilt.
ap/man-pages-3.41-noarch-1.txz:  Upgraded.
ap/mc-4.8.1.3-i486-1.txz:  Upgraded.
ap/moc-2.5.0_alpha4-i486-2.txz:  Rebuilt.
ap/mysql-5.5.25a-i486-1.txz:  Upgraded.
d/doxygen-1.8.1.1-i486-1.txz:  Upgraded.
d/git-1.7.11.1-i486-1.txz:  Upgraded.
d/kernel-headers-3.2.23_smp-x86-1.txz
d/llvm-3.0-i486-2.txz:  Rebuilt.
d/perl-5.16.0-i486-2.txz:  Rebuilt.
d/python-2.7.3-i486-2.txz:  Rebuilt.
d/ruby-1.9.3_p194-i486-2.txz:  Rebuilt.
d/subversion-1.7.5-i486-3.txz:  Rebuilt.
e/emacs-24.1-i486-2.txz:  Rebuilt.
k/kernel-source-3.2.23_smp-noarch-1.txz
kde/amarok-2.5.0-i486-5.txz:  Rebuilt.
kde/calligra-2.4.3-i486-1.txz:  Upgraded.
kde/kdelibs-4.8.4-i486-2.txz:  Rebuilt.
kde/kdemultimedia-4.8.4-i486-2.txz:  Rebuilt.
kde/kdepim-4.8.4-i486-2.txz:  Rebuilt.
kdei/calligra-l10n-ca-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ca\@valencia-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-cs-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-da-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-de-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-el-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-en_GB-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-es-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-et-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fi-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-fr-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-hu-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-it-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-kk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nb-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nds-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-nl-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pl-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-pt_BR-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-ru-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-sv-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-uk-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_CN-2.4.3-noarch-1.txz:  Upgraded.
kdei/calligra-l10n-zh_TW-2.4.3-noarch-1.txz:  Upgraded.
l/ConsoleKit-0.4.5-i486-1.txz:  Upgraded.
l/M2Crypto-0.21.1-i486-2.txz:  Rebuilt.
l/apr-util-1.4.1-i486-3.txz:  Rebuilt.
l/atk-2.4.0-i486-1.txz:  Upgraded.
l/babl-0.1.10-i486-1.txz:  Upgraded.
l/dbus-glib-0.98-i486-1.txz:  Upgraded.
l/dbus-python-1.1.0-i486-1.txz:  Upgraded.
l/desktop-file-utils-0.20-i486-1.txz:  Upgraded.
l/gdk-pixbuf2-2.26.1-i486-1.txz:  Upgraded.
l/gegl-0.2.0-i486-1.txz:  Upgraded.
l/glib2-2.32.3-i486-1.txz:  Upgraded.
l/gnome-icon-theme-3.4.0-i486-1.txz:  Upgraded.
l/gobject-introspection-1.32.1-i486-1.txz:  Added.
l/gst-plugins-base-0.10.36-i486-1.txz:  Upgraded.
l/gst-plugins-good-0.10.31-i486-1.txz:  Upgraded.
l/gstreamer-0.10.36-i486-1.txz:  Upgraded.
l/gtk+2-2.24.10-i486-1.txz:  Upgraded.
l/gtk+3-3.4.3-i486-1.txz:  Added.
l/jre-6u27-i586-1.txz:  Removed.
l/libarchive-2.8.5-i486-1.txz:  Upgraded.
l/libcddb-1.3.2-i486-2.txz:  Rebuilt.
l/libcdio-0.83-i486-1.txz:  Upgraded.
l/libcroco-0.6.5-i486-1.txz:  Added.
l/libgphoto2-2.4.14-i486-1.txz:  Upgraded.
l/libmsn-4.2.1-i486-2.txz:  Rebuilt.
l/libmtp-1.1.3-i486-1.txz:  Upgraded.
l/libnl3-3.2.11-i486-1.txz:  Added.
l/libnotify-0.7.5-i486-1.txz:  Upgraded.
l/libogg-1.3.0-i486-1.txz:  Upgraded.
l/libpcap-1.3.0-i486-1.txz:  Upgraded.
l/librsvg-2.36.1-i486-1.txz:  Upgraded.
l/libvncserver-0.9.9-i486-2.txz:  Rebuilt.
l/libvorbis-1.3.3-i486-1.txz:  Upgraded.
l/libwnck-2.30.7-i486-2.txz:  Rebuilt.
l/libxklavier-5.2.1-i486-1.txz:  Upgraded.
l/libyaml-0.1.4-i486-1.txz:  Added.
l/loudmouth-1.4.3-i486-2.txz:  Rebuilt.
l/mozilla-nss-3.13.5-i486-1.txz:  Added.
l/neon-0.29.6-i486-2.txz:  Rebuilt.
l/notify-python-0.1.1-i486-3.txz:  Rebuilt.
l/pango-1.30.1-i486-1.txz:  Upgraded.
l/polkit-0.105-i486-1.txz:  Upgraded.
l/polkit-gnome-0.102-i486-1.txz:  Upgraded.
l/poppler-0.18.4-i486-1.txz:  Upgraded.
l/poppler-data-0.4.5-noarch-1.txz:  Upgraded.
l/pycurl-7.19.0-i486-2.txz:  Rebuilt.
l/pygobject-2.28.6-i486-1.txz:  Upgraded.
l/pygtk-2.24.0-i486-1.txz:  Upgraded.
l/qca-ossl-2.0.0_beta3-i486-2.txz:  Rebuilt.
l/qt-4.8.2-i486-1.txz:  Upgraded.
l/raptor-1.4.21-i486-1.txz:  Removed.
l/redland-1.0.15-i486-4.txz:  Rebuilt.
l/seamonkey-solibs-2.10.1-i486-2.txz:  Rebuilt.
l/shared-mime-info-1.0-i486-1.txz:  Upgraded.
l/v4l-utils-0.8.8-i486-2.txz:  Rebuilt.
l/virtuoso-ose-6.1.3-i486-3.txz:  Rebuilt.
n/NetworkManager-0.9.4.0-i486-1.txz:  Upgraded.
n/alpine-2.02-i486-1.txz:  Upgraded.
n/bind-9.9.1_P1-i486-2.txz:  Rebuilt.
n/bluez-4.99-i486-1.txz:  Upgraded.
n/bluez-hcidump-2.4-i486-1.txz:  Upgraded.
n/ca-certificates-20120623-noarch-1.txz:  Upgraded.
n/curl-7.26.0-i486-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.23-i486-4.txz:  Rebuilt.
n/dhcp-4.2.4-i486-1.txz:  Upgraded.
n/dhcpcd-5.5.6-i486-1.txz:  Upgraded.
n/epic5-1.1.3-i486-1.txz:  Upgraded.
n/fetchmail-6.3.21-i486-2.txz:  Rebuilt.
n/gnupg-1.4.12-i486-1.txz:  Upgraded.
n/gnupg2-2.0.19-i486-1.txz:  Upgraded.
n/gnutls-3.0.21-i486-1.txz:  Upgraded.
n/gpgme-1.3.2-i486-1.txz:  Upgraded.
n/htdig-3.2.0b6-i486-4.txz:  Rebuilt.
n/httpd-2.4.2-i486-3.txz:  Rebuilt.
n/imapd-2.02-i486-1.txz:  Upgraded.
n/iproute2-3.4.0-i486-1.txz:  Upgraded.
n/iptables-1.4.14-i486-1.txz:  Upgraded.
n/irssi-0.8.15-i486-6.txz:  Rebuilt.
n/iw-3.5-i486-1.txz:  Upgraded.
n/lftp-4.3.8-i486-1.txz:  Upgraded.
n/libassuan-2.0.3-i486-1.txz:  Upgraded.
n/libgcrypt-1.5.0-i486-1.txz:  Upgraded.
n/libgpg-error-1.10-i486-1.txz:  Upgraded.
n/links-2.7-i486-1.txz:  Upgraded.
n/lynx-2.8.7-i486-3.txz:  Rebuilt.
n/mailx-12.5-i486-1.txz:  Upgraded.
n/mutt-1.5.21-i486-2.txz:  Rebuilt.
n/net-snmp-5.6.1-i486-4.txz:  Rebuilt.
n/netatalk-2.0.5-i486-2.txz:  Rebuilt.
n/nettle-2.5-i486-1.txz:  Added.
n/nmap-6.01-i486-2.txz:  Rebuilt.
n/ntp-4.2.6p5-i486-2.txz:  Rebuilt.
n/openldap-client-2.4.31-i486-2.txz:  Rebuilt.
n/openssh-6.0p1-i486-2.txz:  Rebuilt.
n/openssl-1.0.1c-i486-1.txz:  Upgraded.
n/openvpn-2.2.2-i486-1.txz:  Upgraded.
n/p11-kit-0.12-i486-1.txz:  Added.
n/php-5.4.4-i486-1.txz:  Upgraded.
n/pidentd-3.0.19-i486-2.txz:  Rebuilt.
n/popa3d-1.0.2-i486-3.txz:  Rebuilt.
n/proftpd-1.3.4a-i486-2.txz:  Rebuilt.
n/samba-3.6.6-i486-1.txz:  Upgraded.
n/sendmail-8.14.5-i486-3.txz:  Rebuilt.
n/sendmail-cf-8.14.5-noarch-3.txz:  Rebuilt.
n/slrn-0.9.9p1-i486-4.txz:  Rebuilt.
n/snownews-1.5.12-i486-2.txz:  Rebuilt.
n/stunnel-4.53-i486-1.txz:  Upgraded.
n/tcpdump-4.3.0-i486-1.txz:  Upgraded.
n/vsftpd-3.0.0-i486-2.txz:  Rebuilt.
n/wget-1.13.4-i486-1.txz:  Upgraded.
n/wpa_supplicant-1.0-i486-1.txz:  Upgraded.
x/fontconfig-2.9.0-i486-1.txz:  Upgraded.
x/mesa-8.0.4-i486-1.txz:  Upgraded.
x/pixman-0.26.2-i486-1.txz:  Upgraded.
x/xdg-user-dirs-0.14-i486-1.txz:  Upgraded.
x/xorg-server-1.12.3-i486-1.txz:  Upgraded.
x/xorg-server-xephyr-1.12.3-i486-1.txz:  Upgraded.
x/xorg-server-xnest-1.12.3-i486-1.txz:  Upgraded.
x/xorg-server-xvfb-1.12.3-i486-1.txz:  Upgraded.
xap/MPlayer-1.1_20120701-i486-1.txz:  Upgraded.
xap/audacious-3.2.4-i486-1.txz:  Upgraded.
xap/audacious-plugins-3.2.4-i486-1.txz:  Upgraded.
xap/fluxbox-1.3.2-i486-1.txz:  Upgraded.
xap/fvwm-2.6.5-i486-1.txz:  Upgraded.
xap/gftp-2.0.19-i486-3.txz:  Rebuilt.
xap/gimp-2.8.0-i486-1.txz:  Upgraded.
xap/gkrellm-2.3.5-i486-2.txz:  Rebuilt.
xap/gucharmap-3.4.1-i486-1.txz:  Upgraded.
xap/mozilla-firefox-13.0.1-i486-2.txz:  Rebuilt.
xap/mozilla-thunderbird-13.0.1-i486-2.txz:  Rebuilt.
xap/pan-0.139-i486-1.txz:  Upgraded.
xap/pidgin-2.10.6-i486-1.txz:  Upgraded.
xap/rdesktop-1.7.1-i486-3.txz:  Rebuilt.
xap/sane-1.0.22-i486-4.txz:  Rebuilt.
xap/seamonkey-2.10.1-i486-2.txz:  Rebuilt.
xap/windowmaker-0.95.3-i486-1.txz:  Upgraded.
xap/x3270-3.3.12ga7-i486-2.txz:  Rebuilt.
xap/xchat-2.8.8-i486-6.txz:  Rebuilt.
xap/xsane-0.998-i486-2.txz:  Rebuilt.
extra/jdk-6/jdk-6u27-i586-1.txz:  Removed.
Slackware64-current
a/aaa_elflibs-14.0-x86_64-1.txz:  Upgraded.
a/cryptsetup-1.4.3-x86_64-1.txz:  Upgraded.
a/cups-1.5.3-x86_64-2.txz:  Rebuilt.
a/cxxlibs-6.0.17-x86_64-1.txz:  Upgraded.
a/dbus-1.4.20-x86_64-1.txz:  Upgraded.
a/grep-2.13-x86_64-1.txz:  Upgraded.
a/gzip-1.5-x86_64-1.txz:  Upgraded.
a/kernel-generic-3.2.23-x86_64-1.txz:  Upgraded.
a/kernel-huge-3.2.23-x86_64-1.txz:  Upgraded.
a/kernel-modules-3.2.23-x86_64-1.txz:  Upgraded.
a/lvm2-2.02.96-x86_64-1.txz:  Upgraded.
a/mdadm-3.2.5-x86_64-1.txz:  Upgraded.
a/mkinitrd-1.4.7-x86_64-1.txz:  Upgraded.
a/openssl-solibs-1.0.1c-x86_64-1.txz:  Upgraded.
a/pciutils-3.1.9-x86_64-1.txz:  Upgraded.
a/sysvinit-2.88dsf-x86_64-1.txz:  Upgraded.
a/udev-175-x86_64-1.txz:  Upgraded.
a/upower-0.9.17-x86_64-1.txz:  Upgraded.
a/usbutils-006-x86_64-1.txz:  Upgraded.
a/util-linux-2.21.2-x86_64-1.txz:  Upgraded.
ap/cdrdao-1.2.3-x86_64-2.txz:  Rebuilt.
ap/cdrtools-3.01a07-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.05-x86_64-3.txz:  Rebuilt.
ap/gphoto2-2.4.14-x86_64-1.txz:  Upgraded.
ap/gutenprint-5.2.8-x86_64-2.txz:  Rebuilt.
ap/hplip-3.12.6-x86_64-2.txz:  Rebuilt.
ap/mc-4.8.1.3-x86_64-1.txz:  Upgraded.
ap/moc-2.5.0_alpha4-x86_64-2.txz:  Rebuilt.
ap/mysql-5.5.25a-x86_64-1.txz:  Upgraded.
d/doxygen-1.8.1.1-x86_64-1.txz:  Upgraded.
d/git-1.7.11.1-x86_64-1.txz:  Upgraded.
d/kernel-headers-3.2.23-x86-1.txz:  Upgraded.
d/llvm-3.0-x86_64-2.txz:  Rebuilt.
d/perl-5.16.0-x86_64-2.txz:  Rebuilt.
d/python-2.7.3-x86_64-2.txz:  Rebuilt.
d/ruby-1.9.3_p194-x86_64-2.txz:  Rebuilt.
d/subversion-1.7.5-x86_64-3.txz:  Rebuilt.
e/emacs-24.1-x86_64-2.txz:  Rebuilt.
k/kernel-source-3.2.23-noarch-1.txz:  Upgraded.
kde/amarok-2.5.0-x86_64-5.txz:  Rebuilt.
kde/calligra-2.4.3-x86_64-1.txz:  Upgraded.
kde/kdelibs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdemultimedia-4.8.4-x86_64-2.txz:  Rebuilt.
kde/kdepim-4.8.4-x86_64-2.txz:  Rebuilt.
l/ConsoleKit-0.4.5-x86_64-1.txz:  Upgraded.
l/M2Crypto-0.21.1-x86_64-2.txz:  Rebuilt.
l/apr-util-1.4.1-x86_64-3.txz:  Rebuilt.
l/atk-2.4.0-x86_64-1.txz:  Upgraded.
l/babl-0.1.10-x86_64-1.txz:  Upgraded.
l/dbus-glib-0.98-x86_64-1.txz:  Upgraded.
l/dbus-python-1.1.0-x86_64-1.txz:  Upgraded.
l/desktop-file-utils-0.20-x86_64-1.txz:  Upgraded.
l/gdk-pixbuf2-2.26.1-x86_64-1.txz:  Upgraded.
l/gegl-0.2.0-x86_64-1.txz:  Upgraded.
l/glib2-2.32.3-x86_64-1.txz:  Upgraded.
l/gnome-icon-theme-3.4.0-x86_64-1.txz:  Upgraded.
l/gobject-introspection-1.32.1-x86_64-1.txz:  Added.
l/gst-plugins-base-0.10.36-x86_64-1.txz:  Upgraded.
l/gst-plugins-good-0.10.31-x86_64-1.txz:  Upgraded.
l/gstreamer-0.10.36-x86_64-1.txz:  Upgraded.
l/gtk+2-2.24.10-x86_64-1.txz:  Upgraded.
l/gtk+3-3.4.3-x86_64-1.txz:  Added.
l/jre-6u27-x86_64-1.txz:  Removed.
l/libarchive-2.8.5-x86_64-1.txz:  Upgraded.
l/libcddb-1.3.2-x86_64-2.txz:  Rebuilt.
l/libcdio-0.83-x86_64-1.txz:  Upgraded.
l/libcroco-0.6.5-x86_64-1.txz:  Added.
l/libgphoto2-2.4.14-x86_64-1.txz:  Upgraded.
l/libmsn-4.2.1-x86_64-2.txz:  Rebuilt.
l/libmtp-1.1.3-x86_64-1.txz:  Upgraded.
l/libnl3-3.2.11-x86_64-1.txz:  Added.
l/libnotify-0.7.5-x86_64-1.txz:  Upgraded.
l/libogg-1.3.0-x86_64-1.txz:  Upgraded.
l/libpcap-1.3.0-x86_64-1.txz:  Upgraded.
l/librsvg-2.36.1-x86_64-1.txz:  Upgraded.
l/libvncserver-0.9.9-x86_64-2.txz:  Rebuilt.
l/libvorbis-1.3.3-x86_64-1.txz:  Upgraded.
l/libwnck-2.30.7-x86_64-2.txz:  Rebuilt.
l/libxklavier-5.2.1-x86_64-1.txz:  Upgraded.
l/libyaml-0.1.4-x86_64-1.txz:  Added.
l/loudmouth-1.4.3-x86_64-2.txz:  Rebuilt.
l/mozilla-nss-3.13.5-x86_64-1.txz:  Added.
l/neon-0.29.6-x86_64-2.txz:  Rebuilt.
l/notify-python-0.1.1-x86_64-3.txz:  Rebuilt.
l/pango-1.30.1-x86_64-1.txz:  Upgraded.
l/polkit-0.105-x86_64-1.txz:  Upgraded.
l/polkit-gnome-0.102-x86_64-1.txz:  Upgraded.
l/poppler-0.18.4-x86_64-1.txz:  Upgraded.
l/pycurl-7.19.0-x86_64-2.txz:  Rebuilt.
l/pygobject-2.28.6-x86_64-1.txz:  Upgraded.
l/pygtk-2.24.0-x86_64-1.txz:  Upgraded.
l/qca-ossl-2.0.0_beta3-x86_64-2.txz:  Rebuilt.
l/qt-4.8.2-x86_64-1.txz:  Upgraded.
l/raptor-1.4.21-x86_64-1.txz:  Removed.
l/redland-1.0.15-x86_64-4.txz:  Rebuilt.
l/seamonkey-solibs-2.10.1-x86_64-2.txz:  Rebuilt.
l/shared-mime-info-1.0-x86_64-1.txz:  Upgraded.
l/v4l-utils-0.8.8-x86_64-2.txz:  Upgraded.
l/virtuoso-ose-6.1.3-x86_64-3.txz:  Rebuilt.
n/NetworkManager-0.9.4.0-x86_64-1.txz:  Upgraded.
n/alpine-2.02-x86_64-1.txz:  Upgraded.
n/bind-9.9.1_P1-x86_64-2.txz:  Rebuilt.
n/bluez-4.99-x86_64-1.txz:  Upgraded.
n/bluez-hcidump-2.4-x86_64-1.txz:  Upgraded.
n/curl-7.26.0-x86_64-2.txz:  Rebuilt.
n/cyrus-sasl-2.1.23-x86_64-4.txz:  Rebuilt.
n/dhcp-4.2.4-x86_64-1.txz:  Upgraded.
n/dhcpcd-5.5.6-x86_64-1.txz:  Upgraded.
n/epic5-1.1.3-x86_64-1.txz:  Upgraded.
n/fetchmail-6.3.21-x86_64-2.txz:  Rebuilt.
n/gnupg-1.4.12-x86_64-1.txz:  Upgraded.
n/gnupg2-2.0.19-x86_64-1.txz:  Upgraded.
n/gnutls-3.0.21-x86_64-1.txz:  Upgraded.
n/gpgme-1.3.2-x86_64-1.txz:  Upgraded.
n/htdig-3.2.0b6-x86_64-4.txz:  Rebuilt.
n/httpd-2.4.2-x86_64-3.txz:  Rebuilt.
n/imapd-2.02-x86_64-1.txz:  Upgraded.
n/iproute2-3.4.0-x86_64-1.txz:  Upgraded.
n/iptables-1.4.14-x86_64-1.txz:  Upgraded.
n/irssi-0.8.15-x86_64-6.txz:  Rebuilt.
n/iw-3.5-x86_64-1.txz:  Upgraded.
n/lftp-4.3.8-x86_64-1.txz:  Upgraded.
n/libassuan-2.0.3-x86_64-1.txz:  Upgraded.
n/libgcrypt-1.5.0-x86_64-1.txz:  Upgraded.
n/libgpg-error-1.10-x86_64-1.txz:  Upgraded.
n/links-2.7-x86_64-1.txz:  Upgraded.
n/lynx-2.8.7-x86_64-3.txz:  Rebuilt.
n/mailx-12.5-x86_64-1.txz:  Upgraded.
n/mutt-1.5.21-x86_64-2.txz:  Rebuilt.
n/net-snmp-5.6.1-x86_64-4.txz:  Rebuilt.
n/netatalk-2.0.5-x86_64-2.txz:  Rebuilt.
n/nettle-2.5-x86_64-1.txz:  Added.
n/nmap-6.01-x86_64-2.txz:  Rebuilt.
n/ntp-4.2.6p5-x86_64-2.txz:  Rebuilt.
n/openldap-client-2.4.31-x86_64-2.txz:  Rebuilt.
n/openssh-6.0p1-x86_64-2.txz:  Rebuilt.
n/openssl-1.0.1c-x86_64-1.txz:  Upgraded.
n/openvpn-2.2.2-x86_64-1.txz:  Upgraded.
n/p11-kit-0.12-x86_64-1.txz:  Added.
n/php-5.4.4-x86_64-1.txz:  Upgraded.
n/pidentd-3.0.19-x86_64-2.txz:  Rebuilt.
n/popa3d-1.0.2-x86_64-3.txz:  Rebuilt.
n/proftpd-1.3.4a-x86_64-2.txz:  Rebuilt.
n/samba-3.6.6-x86_64-1.txz:  Upgraded.
n/sendmail-8.14.5-x86_64-3.txz:  Rebuilt.
n/slrn-0.9.9p1-x86_64-4.txz:  Rebuilt.
n/snownews-1.5.12-x86_64-2.txz:  Rebuilt.
n/stunnel-4.53-x86_64-1.txz:  Rebuilt.
n/tcpdump-4.3.0-x86_64-1.txz:  Upgraded.
n/vsftpd-3.0.0-x86_64-2.txz:  Rebuilt.
n/wget-1.13.4-x86_64-1.txz:  Upgraded.
n/wpa_supplicant-1.0-x86_64-1.txz:  Upgraded.
x/fontconfig-2.9.0-x86_64-1.txz:  Upgraded.
x/mesa-8.0.4-x86_64-1.txz:  Upgraded.
x/pixman-0.26.2-x86_64-1.txz:  Upgraded.
x/xdg-user-dirs-0.14-x86_64-1.txz:  Upgraded.
x/xorg-server-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xephyr-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xnest-1.12.3-x86_64-1.txz:  Upgraded.
x/xorg-server-xvfb-1.12.3-x86_64-1.txz:  Upgraded.
xap/MPlayer-1.1_20120701-x86_64-1.txz:  Upgraded.
xap/audacious-3.2.4-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-3.2.4-x86_64-1.txz:  Upgraded.
xap/fluxbox-1.3.2-x86_64-1.txz:  Upgraded.
xap/fvwm-2.6.5-x86_64-1.txz:  Upgraded.
xap/gftp-2.0.19-x86_64-3.txz:  Rebuilt.
xap/gimp-2.8.0-x86_64-1.txz:  Upgraded.
xap/gkrellm-2.3.5-x86_64-2.txz:  Rebuilt.
xap/gucharmap-3.4.1-x86_64-1.txz:  Upgraded.
xap/mozilla-firefox-13.0.1-x86_64-2.txz:  Rebuilt.
xap/mozilla-thunderbird-13.0.1-x86_64-2.txz:  Rebuilt.
xap/pan-0.139-x86_64-1.txz:  Upgraded.
xap/pidgin-2.10.6-x86_64-1.txz:  Upgraded.
xap/rdesktop-1.7.1-x86_64-3.txz:  Rebuilt.
xap/sane-1.0.22-x86_64-4.txz:  Rebuilt.
xap/windowmaker-0.95.3-x86_64-1.txz:  Upgraded.
xap/x3270-3.3.12ga7-x86_64-2.txz:  Rebuilt.
xap/xchat-2.8.8-x86_64-6.txz:  Rebuilt.
xap/xsane-0.998-x86_64-2.txz:  Rebuilt.
extra/jdk-6/jdk-6u27-x86_64-1.txz:  Removed.
Post Napisano: 15 Jul 2012, 16:27
Sat Jul 14 15:42:28 UTC 2012
Slackware-current
Sun Jul 15 01:40:08 UTC 2012
Slackware-current
a/aaa_elflibs-14.0-i486-2.txz:  Rebuilt.
a/openssl-solibs-1.0.1c-i486-2.txz:  Rebuilt.
n/openssl-1.0.1c-i486-2.txz:  Rebuilt.
n/wget-1.13.4-i486-2.txz:  Rebuilt.
Slackware64-current
a/aaa_elflibs-14.0-x86_64-2.txz:  Rebuilt.
a/openssl-solibs-1.0.1c-x86_64-2.txz:  Rebuilt.
n/openssl-1.0.1c-x86_64-2.txz:  Rebuilt.
n/wget-1.13.4-x86_64-2.txz:  Rebuilt.
Post Napisano: 16 Jul 2012, 07:33
Sun Jul 15 17:10:38 UTC 2012
Slackware-current
a/lvm2-2.02.96-i486-2.txz:  Rebuilt.
a/mkinitrd-1.4.7-i486-2.txz:  Rebuilt.
ap/sox-14.4.0-i486-1.txz:  Upgraded.
l/libspectre-0.2.6-i486-1.txz:  Upgraded.
Slackware64-current
a/lvm2-2.02.96-x86_64-2.txz:  Rebuilt.
a/mkinitrd-1.4.7-x86_64-2.txz:  Rebuilt.
ap/sox-14.4.0-x86_64-1.txz:  Upgraded.
l/libspectre-0.2.6-x86_64-1.txz:  Upgraded.
Mon Jul 16 02:46:21 UTC 2012
Slackware-current
a/lvm2-2.02.96-i486-3.txz:  Rebuilt.
Slackware64-current
a/lvm2-2.02.96-x86_64-3.txz:  Rebuilt.
Post Napisano: 17 Jul 2012, 09:21
Mon Jul 16 19:00:08 UTC 2012
Slackware-current
a/ntfs-3g-2012.1.15-i486-2.txz:  Rebuilt.
a/sysvinit-scripts-2.0-noarch-2.txz:  Rebuilt.
a/util-linux-2.21.2-i486-2.txz:  Rebuilt.
Slackware64-current
a/ntfs-3g-2012.1.15-x86_64-2.txz:  Rebuilt.
a/util-linux-2.21.2-x86_64-2.txz:  Rebuilt.
Tue Jul 17 00:21:46 UTC 2012
Slackware-current
a/mkinitrd-1.4.7-i486-3.txz:  Rebuilt.
Slackware64-current
a/mkinitrd-1.4.7-x86_64-3.txz:  Rebuilt.
Post Napisano: 19 Jul 2012, 00:03
Wed Jul 18 05:35:26 UTC 2012
Slackware-current
a/mkinitrd-1.4.7-i486-4.txz:  Rebuilt.
kde/kdepimlibs-4.8.4-i486-2.txz:  Rebuilt.
kde/perlqt-4.8.4-i486-2.txz:  Rebuilt.
kde/qtruby-4.8.4-i486-2.txz:  Rebuilt.
kde/rocs-4.8.4-i486-2.txz:  Rebuilt.
kde/smokeqt-4.8.4-i486-2.txz:  Rebuilt.
l/fribidi-0.19.2-i486-2.txz:  Rebuilt.
l/gst-plugins-good-0.10.31-i486-2.txz:  Rebuilt.
l/hal-0.5.14-i486-3.txz:  Removed.
l/hal-info-20091130-noarch-1.txz:  Removed.
l/libexif-0.6.21-i486-1.txz:  Upgraded.
l/libgphoto2-2.4.14-i486-2.txz:  Rebuilt.
l/libvisual-0.4.0-i486-3.txz:  Rebuilt.
l/seamonkey-solibs-2.11-i486-1.txz:  Upgraded.
l/wv2-0.4.2-i486-1.txz:  Removed.
n/net-snmp-5.6.1-i486-5.txz:  Rebuilt.
xap/mozilla-firefox-14.0.1-i486-1.txz:  Upgraded.
xap/mozilla-thunderbird-14.0-i486-1.txz:  Upgraded.
xap/seamonkey-2.11-i486-1.txz:  Upgraded.
Slackware64-current
a/mkinitrd-1.4.7-x86_64-4.txz:  Rebuilt.
kde/kdepimlibs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/perlqt-4.8.4-x86_64-2.txz:  Rebuilt.
kde/qtruby-4.8.4-x86_64-2.txz:  Rebuilt.
kde/rocs-4.8.4-x86_64-2.txz:  Rebuilt.
kde/smokeqt-4.8.4-x86_64-2.txz:  Rebuilt.
l/fribidi-0.19.2-x86_64-2.txz:  Rebuilt.
l/gst-plugins-good-0.10.31-x86_64-2.txz:  Rebuilt.
l/hal-0.5.14-x86_64-3.txz:  Removed.
l/libexif-0.6.21-x86_64-1.txz:  Upgraded.
l/libgphoto2-2.4.14-x86_64-2.txz:  Rebuilt.
l/libvisual-0.4.0-x86_64-3.txz:  Rebuilt.
l/seamonkey-solibs-2.11-x86_64-1.txz:  Upgraded.
l/wv2-0.4.2-x86_64-1.txz:  Removed.
n/net-snmp-5.6.1-x86_64-5.txz:  Rebuilt.
xap/mozilla-firefox-14.0.1-x86_64-1.txz:  Upgraded.
xap/mozilla-thunderbird-14.0-x86_64-1.txz:  Upgraded.
xap/seamonkey-2.11-x86_64-1.txz:  Upgraded.
Wed Jul 18 20:21:15 UTC 2012
Slackware-current
l/hicolor-icon-theme-0.12-noarch-2.txz:  Rebuilt.
n/gpa-0.9.2-i486-1.txz:  Upgraded.
n/iputils-s20101006-i486-2.txz:  Rebuilt.
xap/MPlayer-1.1_20120701-i486-2.txz:  Rebuilt.
Slackware64-current
n/gpa-0.9.2-x86_64-1.txz:  Upgraded.
n/iputils-s20101006-x86_64-2.txz:  Rebuilt.
xap/MPlayer-1.1_20120701-x86_64-2.txz:  Rebuilt.
