Postoje već 3 slackbuild-a (rworkman, alienbob i ponce su gotovo istovremeno napisali sb skriptove ) za Razor-qt, a uskoro će se jedan od njih naći i na SBo. Za više informacije je najbolje da pogledate sledeću temu na LQ:Razor-qt is an advanced, easy-to-use, and fast desktop environment based on Qt technologies. It has been tailored for users who value simplicity, speed, and an intuitive interface. Unlike most desktop environments, Razor-qt also works fine with weak machines.
While still a new project, Razor-qt already contains the key DE components:
Panel
Desktop
Application launcher
Settings center
Sessions
You can use either all of them or part of them. Razor-qt works with various WMs, most of Razor developers use Openbox. But it's no problem to take any modern WM from fwwm2 to kwin (yes, KDE without Plasma Desktop is possible too).
Razor-qt is a new open-source project and you can help us improve it. We welcome your bug reports and suggestions; you are free to translate all into your own language, create more attractive graphics, anything.
http://www.linuxquestions.org/questions" onclick="window.open(this.href);return false; ... qt-919443/
S obzirom da nisam neki ljubitelj Qt4, recenziju i iskustva iz prakse ostavljam ljudima koji se odluče da ga testiraju.
Zvanična strana:
http://www.razor-qt.org/" onclick="window.open(this.href);return false;
