sbotools
Moderators: Slackmuz, Urednik
Post Napisano: 06 Oct 2012, 10:13
Još jedan alat za instalaciju softvera iz SlackBuilds.org, ovaj put inspirisan FreeBSD portovima i napisan u Perlu. Ovaj alat izvodi zavisnosti iz polja requires u *.info datotekama.
sbotools provides a ports-like interface to slackbuilds.org. It consists of several commands, and a configuration file. As sbotools is highly influenced by FreeBSD’s ports system and its pkgtools, the interface will be more or less familiar to anyone familiar with ports, portupgrade, etc.
The first thing which needs to be done after installing sbotools is to pull a local copy of the slackbuilds.org tree, minus the excess bits; this is optionally done automagickally at first run of sbofind(1), sboupgrade(1), or sboinstall(1), or manually via the sbosnap(1) command.
Napomene
sbotools koristi dva Perl modula koji ne dolaze uz Slackware:
  • Sort::Versions
  • Text::Tabulate
Matična strana
http://dawnrazor.net/sbotools/" onclick="window.open(this.href);return false;
Post Napisano: 06 Oct 2012, 10:49
Sviđa mi se ideja ali ću ipak da sačekam malo da vidim iskustva drugih.
Users browsing this forum: No registered users and 17 guests
