DraftSight CAD aplikacija
Moderators: Slackmuz, Urednik
Post Napisano: 25 Jan 2012, 13:58
DraftSight je closed source freeware 2D CAD aplikacija. Vidim da ga na neu nazivaju klonom AutoCAD-a. Možda će nekome biti zanimljivo.
DraftSight is a free*, professional-grade 2D CAD product centered upon an open business model. Available for download at DraftSight.com, DraftSight provides users with a better way to create, edit and view DWG files. Based on an advanced architecture, DraftSight generally thakes a few minutes to download and runs o multiple operating systems. DraftSight is available for all users, including CAD professionals, students and educators.
DraftSight can be used to:
* Create 2D drawings
* Update and maintain dwg and dxf files
* Create PDF files
* Exchange files with companies who either provide or requite data saved in either dwg or dxf file formats
The standalone, single-user version of DraftSight is free* to download at DraftSight.
Zahtevi:
  • x86 1+ Ghz procesor
  • 1 Gb RAM (2 GB preporučeno)
  • 1 GB slobodnog prostora na disku
  • 1024x768 displej (1680x1050 ili veća rezolucija je preporučena), TrueColor grafika i miš
Inače testiran je na slacku. Možete konvertovati rpm paket korišćenjem rpm2tgz.
Website
http://www.3ds.com/products/draftsight/overview/
Download
http://www.3ds.com/products/draftsight/ ... raftsight/
Reference
DraftCad FAQ
Post Napisano: 25 Jan 2012, 22:37
Veliko hvala za ovo, bocke. :beer:
Post Napisano: 25 Jan 2012, 23:48
Nema na čemu. Nadam se da će koristiti. ;)
Post Napisano: 26 Jan 2012, 00:13
Odlično parče softvera. Bez problema otvara dwg fajlove. Da bi se uspešno instalirao na Slackware sistemu (bez obzira da li je u pitanju 32 ili 64bit) neophodno je da postoji i libaudio.so.2 biblioteka. Ona je sastavni deo paketa nas-libs koji se nalazi u repozitorijumima Fedore 13. Potrebno je skinuti 32bit (i686) verziju, bez obzira da li nam je sistem 32bit ili 64bit (u slučaju korišćenja libaudio.so.2 biblioteke iz 64bit paketa nas-libs program se neće pokrenuti).
Preuzmite paket nas-libs-1.9.2-1.fc13.i686.rpm (recimo sa ovog linka) a zatim u terminalu pokrenite sledeću komandu (kao običan korisnik):
$ rpm2cpio nas-libs-1.9.2-1.fc13.i686.rpm | cpio -idmv
Nakon ovoga, u direktorijumu u kome se trenutno nalazite biće kreiran skriveni /usr direktorijum (./usr) i u njemu share folder sa dva fajla - libaudio.so.2 i libaudio.so.2.4.. Bez premeštanja u bilo koji od navedenih direktorijuma unesite u terminal sledeću komandu (kao root):
# cp ./usr/lib/libaudio.so.2 /opt/dassault-systemes/draftsight/lib/
Nakon ovoga, program možete pokrenuti na sledeći način (kao običan korisnik):
$ /opt/dassault-systemes/draftsight/bin/DraftSight
Link na kome sam pronašao rešenje => http://ecoslackware.wordpress.com/2011/ ... are-linux/
Post Napisano: 26 Jan 2012, 05:33
A može i ovako:
Bocketov build script za DraftSight
  • Rešen problem sa libaudio, bez instalacije binarnih datoteka sa drugih distroa.
  • Dodat unos u meniju (/usr/share/applications)
  • Dodate ikone za DraftSight
  • Pri instalaciji DraftSight postaje podrazumevana aplikacija za otwaranje dxf, dwt i dwg.
Sadržaj:
-rw-r--r-- bocke/users     228 2012-01-26 04:39 DraftSight/doinst.sh.gz
-rw-r--r-- bocke/users    2335 2012-01-26 05:11 DraftSight/build.sh
-rw-r--r-- bocke/users     621 2012-01-26 05:01 DraftSight/slack-desc
Slika - jedan od primera sa AutoCAD sajta otvoren u DraftSight-u:
DraftSight.tar.xz
(1.62 KiB) Downloaded 334 times
Ostalo je da se isprave ikonice za mime tipove.
Btw, nije mi se svidelo to preuzimanje stvari iz Fedore i kucanje cele putanje, pa sam morao da reagujem.  :)
Screenshot - 01262012 - 05:15:49 AM.png
Post Napisano: 26 Jan 2012, 10:08
Dobro je da si reagovao jer to pokazuje snagu zajednice i kvalitet članova :). Ono što sam ja juče napisao je bilo jedino rešenje dok ti nisi odlučio da pomogneš i napravio skriptu. Svaka čast :)
Users browsing this forum: No registered users and 17 guests
