Problem sa igricama
Post Napisano: 27 Jan 2013, 15:12
Uradio sam ponovo i restartovao mašinu. Evo izlaza
root@stereo:/home/zeljko# dmesg -T -l err,crit,alert,emerg
[Sun Jan 27 15:02:39 2013] EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[Sun Jan 27 15:02:39 2013] EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[Sun Jan 27 15:02:43 2013] sd 6:0:0:0: [sdc] No Caching mode page present
[Sun Jan 27 15:02:43 2013] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[Sun Jan 27 15:02:44 2013] sd 6:0:0:0: [sdc] No Caching mode page present
[Sun Jan 27 15:02:44 2013] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[Sun Jan 27 15:03:50 2013] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[Sun Jan 27 15:03:50 2013] ata4.00: cmd a0/00:00:00:64:01/00:00:00:00:00/a0 tag 0 pio 16740 in
[Sun Jan 27 15:03:50 2013]          res 58/00:02:00:64:01/00:00:00:00:00/a0 Emask 0x6 (timeout)
[Sun Jan 27 15:03:50 2013] ata4.00: status: { DRDY DRQ }
Post Napisano: 27 Jan 2013, 15:44
Daj i output:
dmesg -T -l warn,notice
Post Napisano: 27 Jan 2013, 16:37
Evo
[Sun Jan 27 15:02:35 2013] Linux version 3.6.6 (root@stereo) (gcc version 4.7.1 (GCC) ) #2 SMP Fri Nov 23 16:08:38 CET 2012
[Sun Jan 27 15:02:35 2013] ACPI: RSDP 00000000000faed0 00014 (v00 ACPIAM)
[Sun Jan 27 15:02:35 2013] ACPI: RSDT 00000000bffa0000 00044 (v01 7597MS A7597200 20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: FACP 00000000bffa0200 00084 (v01 7597MS A7597200 20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: DSDT 00000000bffa0630 05134 (v01  A7597 A7597200 00000200 INTL 20051117)
[Sun Jan 27 15:02:35 2013] ACPI: FACS 00000000bffae000 00040
[Sun Jan 27 15:02:35 2013] ACPI: APIC 00000000bffa0390 00090 (v01 7597MS A7597200 20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: MCFG 00000000bffa0420 0003C (v01 7597MS OEMMCFG  20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: WDRT 00000000bffa05e0 00047 (v01 7597MS NV-WDRT  20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: OEMB 00000000bffae040 00072 (v01 7597MS A7597200 20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: SRAT 00000000bffaa630 000C8 (v03 AMD    FAM_F_10 00000002 AMD  00000001)
[Sun Jan 27 15:02:35 2013] ACPI: HPET 00000000bffaa700 00038 (v01 7597MS OEMHPET0 20110223 MSFT 00000097)
[Sun Jan 27 15:02:35 2013] ACPI: SSDT 00000000bffaa740 00458 (v01 A M I  POWERNOW 00000001 AMD  00000001)
[Sun Jan 27 15:02:35 2013] Zone ranges:
[Sun Jan 27 15:02:35 2013]   DMA      [mem 0x00010000-0x00ffffff]
[Sun Jan 27 15:02:35 2013]   DMA32    [mem 0x01000000-0xffffffff]
[Sun Jan 27 15:02:35 2013]   Normal   [mem 0x100000000-0x1bfffffff]
[Sun Jan 27 15:02:35 2013] Movable zone start for each node
[Sun Jan 27 15:02:35 2013] Early memory node ranges
[Sun Jan 27 15:02:35 2013]   node   0: [mem 0x00010000-0x0009efff]
[Sun Jan 27 15:02:35 2013]   node   0: [mem 0x00100000-0xbff9ffff]
[Sun Jan 27 15:02:35 2013]   node   0: [mem 0x100000000-0x1bfffffff]
[Sun Jan 27 15:02:35 2013] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1543977
[Sun Jan 27 15:02:35 2013] Kernel command line: auto BOOT_IMAGE=S14-Test ro root=801 resume=/dev/sda2
[Sun Jan 27 15:02:35 2013] __ex_table already sorted, skipping sort
[Sun Jan 27 15:02:35 2013] raid6: sse2x1    3675 MB/s
[Sun Jan 27 15:02:35 2013] raid6: sse2x2    6191 MB/s
[Sun Jan 27 15:02:35 2013] raid6: sse2x4    7359 MB/s
[Sun Jan 27 15:02:35 2013] raid6: using algorithm sse2x4 (7359 MB/s)
[Sun Jan 27 15:02:35 2013] raid6: using intx1 recovery algorithm
[Sun Jan 27 15:02:35 2013] ACPI: Executed 1 blocks of module-level executable AML code
[Sun Jan 27 15:02:35 2013] SCSI subsystem initialized
[Sun Jan 27 15:02:35 2013] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 23
[Sun Jan 27 15:02:35 2013] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 22
[Sun Jan 27 15:02:35 2013] type=2000 audit(1359298956.230:1): initialized
[Sun Jan 27 15:02:35 2013] VFS: Disk quotas dquot_6.5.2
[Sun Jan 27 15:02:35 2013] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[Sun Jan 27 15:02:35 2013] NFS: Registering the id_resolver key type
[Sun Jan 27 15:02:35 2013] Key type id_resolver registered
[Sun Jan 27 15:02:35 2013] Key type id_legacy registered
[Sun Jan 27 15:02:35 2013] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 21
[Sun Jan 27 15:02:35 2013] ACPI: PCI Interrupt Link [LSA1] enabled at IRQ 20
[Sun Jan 27 15:02:35 2013] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1
[Sun Jan 27 15:02:36 2013] Key type dns_resolver registered
[Sun Jan 27 15:02:38 2013] scsi 0:0:0:0: Direct-Access     ATA      WDC WD5000AAKX-0 15.0 PQ: 0 ANSI: 5
[Sun Jan 27 15:02:38 2013] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[Sun Jan 27 15:02:38 2013] sd 0:0:0:0: [sda] Write Protect is off
[Sun Jan 27 15:02:38 2013] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Sun Jan 27 15:02:38 2013] sd 0:0:0:0: [sda] Attached SCSI disk
[Sun Jan 27 15:02:39 2013] scsi 3:0:0:0: CD-ROM            TSSTcorp CDDVDW SH-S223C  SB06 PQ: 0 ANSI: 5
[Sun Jan 27 15:02:39 2013] sr0: scsi3-mmc drive: 52x/52x writer dvd-ram cd/rw xa/form2 cdda tray
[Sun Jan 27 15:02:39 2013] sd 4:0:0:0: [sdb] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[Sun Jan 27 15:02:39 2013] sd 4:0:0:0: [sdb] Write Protect is off
[Sun Jan 27 15:02:39 2013] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Sun Jan 27 15:02:39 2013] sd 4:0:0:0: [sdb] Attached SCSI disk
[Sun Jan 27 15:02:42 2013] ACPI: PCI Interrupt Link [LNEA] enabled at IRQ 19
[Sun Jan 27 15:02:42 2013] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[Sun Jan 27 15:02:42 2013] Disabling lock debugging due to kernel taint
[Sun Jan 27 15:02:42 2013] <6>[fglrx] Maximum main memory to use for locked dma buffers: 5765 MBytes.
[Sun Jan 27 15:02:42 2013] <6>[fglrx]   vendor: 1002 device: 68bf count: 1
[Sun Jan 27 15:02:42 2013] <6>[fglrx] ioport: bar 4, base 0xd000, size: 0x100
[Sun Jan 27 15:02:42 2013] ACPI: PCI Interrupt Link [LNED] enabled at IRQ 18
[Sun Jan 27 15:02:42 2013] <6>[fglrx] Kernel PAT support is enabled
[Sun Jan 27 15:02:42 2013] <6>[fglrx] module loaded - fglrx 9.0.2 [Sep 28 2012] with 1 minors
[Sun Jan 27 15:02:42 2013] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 17
[Sun Jan 27 15:02:43 2013] scsi 6:0:0:0: Direct-Access     JetFlash Transcend 8GB    8.07 PQ: 0 ANSI: 2
[Sun Jan 27 15:02:43 2013] sd 6:0:0:0: [sdc] 15679488 512-byte logical blocks: (8.02 GB/7.47 GiB)
[Sun Jan 27 15:02:43 2013] sd 6:0:0:0: [sdc] Write Protect is off
[Sun Jan 27 15:02:44 2013] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[Sun Jan 27 15:03:50 2013] cdb[0]=0x46: 46 00 00 00 00 00 00 01 64 00
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Firegl kernel thread PID: 1579
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Firegl kernel thread PID: 1580
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Firegl kernel thread PID: 1581
[Sun Jan 27 15:03:56 2013] <6>[fglrx] IRQ 44 Enabled
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Gart USWC size:1280 M.
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Gart cacheable size:508 M.
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Reserved FB block: Shared offset:0, size:1000000
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Reserved FB block: Unshared offset:f8fc000, size:404000
[Sun Jan 27 15:03:56 2013] <6>[fglrx] Reserved FB block: Unshared offset:3fff4000, size:c000
[Sun Jan 27 15:04:41 2013] Assertion failed in ../../../../../../../../drivers/2d/lnx/fgl/drm/kernel/hal_evergreen.c at line: 64
[Sun Jan 27 16:35:51 2013] scsi 7:0:0:0: Direct-Access     JetFlash Transcend 8GB    8.07 PQ: 0 ANSI: 2
[Sun Jan 27 16:35:51 2013] sd 7:0:0:0: [sdc] 15679488 512-byte logical blocks: (8.02 GB/7.47 GiB)
[Sun Jan 27 16:35:51 2013] sd 7:0:0:0: [sdc] Write Protect is off
[Sun Jan 27 16:35:51 2013] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[Sun Jan 27 16:35:58 2013] Assertion failed in ../../../../../../../../drivers/2d/lnx/fgl/drm/kernel/hal_evergreen.c at line: 64
Post Napisano: 28 Jan 2013, 14:33
Ne vidim ništa problematično. Tastatura se izgleda prepoznaje normalno. Jedino što me buni što je prepoznata dva puta. Dostupna je kao /input/input1 i /input/js0. Na slikama ne vidim da postoji nekakav točkić, dugme ili trackball... Buni me taj joystick (js0).
Elem, potencijalni krivci su udev ili sdl. Mada je moguće da i ovaj umišljeni "joystick" pravi problem. Pogotovo bi to mogao biti slučaj sa igrama.
Inače, javljam se u ovoj temi kad stignem. To ovih dana nije baš toliko često. Ali to ne znači da nisam spreman da pomognem. Samo moraš imati razumevanja za malo sporiji ritam. ;)
Post Napisano: 28 Jan 2013, 18:13
Bocke nikakav problem, ni meni nije stigao internet još, dovijam se kako mogu....
Nije žurba imam i pametnija posla :)
Hvala ti svakako na volji i trudu.
:beer: je od mene kad budem došao sledeći put.
Post Napisano: 28 Jan 2013, 19:27
Sad sam se setio. Dok sam gledao podešavanja za kontrole u igrici SuperTuxKart, prikazivao mi je joystick kao tastaturu a tastaturu kao neki gaming device. Kad stignem postaviću ti tačnu informaciju.
