Problem sa igricama
Post Napisano: 24 Jan 2013, 12:58
Bocke evo izlaza
root@stereo:/lib/udev# /lib/udev/findkeyboards
USB keyboard: input/event3
USB keyboard: input/event4
USB keyboard: input/js0
Ne, još nije stigao kablovski internet, još se jurim sa mts-ovim usb modemom.
Post Napisano: 25 Jan 2013, 03:48
Šta imaš u /etc/udev/rules.d/ (ls -l)?
Post Napisano: 25 Jan 2013, 10:49
zeljko@stereo:~$ ls -l /etc/udev/rules.d/
total 8
-rw-r--r-- 1 root root 2250 Jan 17 23:00 70-persistent-cd.rules
-rw-r--r-- 1 root root  413 Sep 12 22:16 70-persistent-net.rules
zeljko@stereo:~$
Post Napisano: 27 Jan 2013, 11:05
Stigao sam da bacim pogled, pa da nastavimo. Otkucaj kao root:
udevadm info --query=all --name=input/event3
udevadm info --query=all --name=input/event4
udevadm info --query=all --name=input/js0
Ako može odvojen izlaz to bi bilo najbolje.
Post Napisano: 27 Jan 2013, 11:49
Odvojeni izlazi stižu :)
root@stereo:/home/zeljko# udevadm info --query=all --name=input/event3
P: /devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.1/input/input3/event3
N: input/event3
S: input/by-id/usb-Microsoft_Wired_Keyboard_600-event-kbd
S: input/by-id/usb-Microsoft_Wired_Keyboard_600-if01-event-kbd
S: input/by-path/pci-0000:00:02.0-usb-0:2:1.1-event-kbd
E: DEVLINKS=/dev/input/by-id/usb-Microsoft_Wired_Keyboard_600-event-kbd /dev/input/by-id/usb-Microsoft_Wired_Keyboard_600-if01-event-kbd /dev/input/by-path/pci-0000:00:02.0-usb-0:2:1.1-event-kbd
E: DEVNAME=/dev/input/event3
E: DEVPATH=/devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.1/input/input3/event3
E: ID_BUS=usb
E: ID_INPUT=1
E: ID_INPUT_KEY=1
E: ID_INPUT_KEYBOARD=1
E: ID_MODEL=Wired_Keyboard_600
E: ID_MODEL_ENC=Wired\x20Keyboard\x20600
E: ID_MODEL_ID=0750
E: ID_PATH=pci-0000:00:02.0-usb-0:2:1.1
E: ID_PATH_TAG=pci-0000_00_02_0-usb-0_2_1_1
E: ID_REVISION=0110
E: ID_SERIAL=Microsoft_Wired_Keyboard_600
E: ID_TYPE=hid
E: ID_USB_DRIVER=usbhid
E: ID_USB_INTERFACES=:030101:030000:
E: ID_USB_INTERFACE_NUM=01
E: ID_VENDOR=Microsoft
E: ID_VENDOR_ENC=Microsoft
E: ID_VENDOR_ID=045e
E: MAJOR=13
E: MINOR=67
E: SUBSYSTEM=input
E: UDEV_LOG=3
E: USEC_INITIALIZED=7953223
root@stereo:/home/zeljko# udevadm info --query=all --name=input/event4
P: /devices/pci0000:00/0000:00:02.0/usb2/2-5/2-5:1.0/input/input4/event4
N: input/event4
S: input/by-id/usb-Logitech_USB-PS_2_Optical_Mouse-event-mouse
S: input/by-path/pci-0000:00:02.0-usb-0:5:1.0-event-mouse
E: DEVLINKS=/dev/input/by-id/usb-Logitech_USB-PS_2_Optical_Mouse-event-mouse /dev/input/by-path/pci-0000:00:02.0-usb-0:5:1.0-event-mouse
E: DEVNAME=/dev/input/event4
E: DEVPATH=/devices/pci0000:00/0000:00:02.0/usb2/2-5/2-5:1.0/input/input4/event4
E: ID_BUS=usb
E: ID_INPUT=1
E: ID_INPUT_MOUSE=1
E: ID_MODEL=USB-PS_2_Optical_Mouse
E: ID_MODEL_ENC=USB-PS\x2f2\x20Optical\x20Mouse
E: ID_MODEL_ID=c03e
E: ID_PATH=pci-0000:00:02.0-usb-0:5:1.0
E: ID_PATH_TAG=pci-0000_00_02_0-usb-0_5_1_0
E: ID_REVISION=2000
E: ID_SERIAL=Logitech_USB-PS_2_Optical_Mouse
E: ID_TYPE=hid
E: ID_USB_INTERFACES=:030102:
E: ID_USB_INTERFACE_NUM=00
E: ID_VENDOR=Logitech
E: ID_VENDOR_ENC=Logitech
E: ID_VENDOR_ID=046d
E: MAJOR=13
E: MINOR=68
E: SUBSYSTEM=input
E: UDEV_LOG=3
E: USEC_INITIALIZED=7918261
root@stereo:/home/zeljko# udevadm info --query=all --name=input/js0
P: /devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.1/input/input3/js0
N: input/js0
S: input/by-id/usb-Microsoft_Wired_Keyboard_600-if01-kbd
S: input/by-id/usb-Microsoft_Wired_Keyboard_600-kbd
S: input/by-path/pci-0000:00:02.0-usb-0:2:1.1-kbd
E: DEVLINKS=/dev/input/by-id/usb-Microsoft_Wired_Keyboard_600-if01-kbd /dev/input/by-id/usb-Microsoft_Wired_Keyboard_600-kbd /dev/input/by-path/pci-0000:00:02.0-usb-0:2:1.1-kbd
E: DEVNAME=/dev/input/js0
E: DEVPATH=/devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.1/input/input3/js0
E: ID_BUS=usb
E: ID_INPUT=1
E: ID_INPUT_KEY=1
E: ID_MODEL_ID=0750
E: ID_REVISION=0110
E: ID_TYPE=hid
E: MAJOR=13
E: MINOR=0
E: SUBSYSTEM=input
E: UDEV_LOG=3
E: USEC_INITIALIZED=7952660
Post Napisano: 27 Jan 2013, 12:42
E sad je malo jasnija situacija. :)
Preuzmi sledeću datoteku:
60-persistent-input.rules.gz
(703 Bytes) Downloaded 166 times
Otvori terminal u istom direktorijumu i copy-paste:
mv /lib/udev/rules.d/60-persistent-input.rules /lib/udev/rules.d/60-persistent-input.rules.orig
zcat 60-persistent-input.rules.gz > /lib/udev/rules.d/60-persistent-input.rules
/etc/rc.d/rc.udev restart
Isključi tastaturu iz kompa i zatim je ponovo uključi.
Ima li promena?
Edit
Btw, referenca za predložene izmene:
https://bugs.launchpad.net/ubuntu/quant ... ug/1057824" onclick="window.open(this.href);return false;
Post Napisano: 27 Jan 2013, 14:04
Uradio, ništa se ne menja. TuxRacer i dalje ide na levo. Xonotic sad ne mogu da pokrenem. Vraćam originalni fajl.
Post Napisano: 27 Jan 2013, 14:41
Ček, ček. Polako. Probaj prvo restart. Overi da li se prikazuje koja greška pri pokretanju.
Elem, to može, ali ne mora imati veze sa nepokretanjem Xonotica.
Post Napisano: 27 Jan 2013, 14:54
Uradio sam
/etc/rc.d/rc.udev force-restart
izvukao tastaturu i vratio je, probao igricu - ništa, restartovao komp, probao igricu opet i ništa. Prilikom boot-a nisam primetio neki problem.
Xonotic me zezao i pre toga ali ne često. Uklonio sam je i obrisao podešavanja. Instalirao sam Nexiuz, ista stvar kao Xonotic samo ne zeza.
Instalacija mi je među paketima, lako mogu da vratim.
Uradiću proceduru od gore opet, nije mi problem. Ostaviću tako za sada.
Post Napisano: 27 Jan 2013, 15:07
Hajde za svaki slučaj daj izlaz:
dmesg -T -l err,crit,alert,emerg
