[REŠENO] Cubosphere
Post Napisano: 07 Oct 2012, 23:45
Хтео сам да инсталирам ову одличну игру коју играм већ на Арчу. Али желим је и на Слекверу :)
Преузео сам извор одавде - http://sourceforge.net/projects/cubosphere/files/
Решио зависности, али ми упорно баца ову грешку при компиловању:
bash-4.2$ make
Compiling Cubosphere - this may take a while... Please stay patient!
g++  -I/usr/include/lua5.1 -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -o cubosphere -O3 -DDATADIR=\"/usr/local/share/cubosphere\" -llua5.1 -L/usr/lib64 -Wl,-rpath,/usr/lib64 -lSDL -lpthread -lGL -lGLEW -lGLU -lSDL_mixer -ljpeg -lSDL_ttf src/*.cpp
src/filesystem.cpp: In member function ‘virtual long unsigned int cls_FileDirMountedForReading::GetSize(int) const’:
src/filesystem.cpp:184:112: warning: converting to non-pointer type ‘long unsigned int’ from NULL [-Wconversion-null]
src/filesystem.cpp: In member function ‘virtual cls_FileWriteable* cls_FileSubSystemDirMount::virtGetFileForWriting(const std::vector<std::basic_string<char> >&, bool) const’:
src/filesystem.cpp:459:34: warning: converting ‘false’ to pointer type ‘cls_FileWriteable*’ [-Wconversion-null]
src/filesystem.cpp:462:22: warning: converting ‘false’ to pointer type ‘cls_FileWriteable*’ [-Wconversion-null]
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: cannot find -llua5.1
collect2: error: ld returned 1 exit status
make: *** [cubo] Error 1
Ево шта стоји у INSTALL фајлу:
1. Get the needed libraries
Cubosphere uses the following libraries:
OpenGL //Make sure, you have installed a valid 3d accelerated driver
Lua 5.1 (liblua5.1)
GLEW 1.5 (libglew1.5)
SDL 1.2 (libsdl1.2)
SDL_ttf 2.0 (libsdl-ttf2.0)
SDL_mixer 1.2 (libsdl_mixer1.2)
JPEG 6.2 (libjpeg6.2) //Version 8 should also work
А ево шта каже Конзола:
bash-4.2$ ls /var/log/packages | grep -i lua
lua-5.1.5-x86_64-1_SBo
bash-4.2$ ls /var/log/packages | grep -i glew
glew-1.5.7-x86_64-1
bash-4.2$ ls /var/log/packages | grep -i sdl
SDL_sound-1.0.3-x86_64-1_SBo
sdl-1.2.14-x86_64-5
bash-4.2$ locate SDL_ttf
/usr/doc/SDL_ttf-2.0.10
/usr/doc/SDL_ttf-2.0.10/COPYING
/usr/doc/SDL_ttf-2.0.10/CHANGES
/usr/doc/SDL_ttf-2.0.10/README
/usr/share/cmake-2.8/Modules/FindSDL_ttf.cmake
/usr/lib64/libSDL_ttf.la
/usr/lib64/libSDL_ttf-2.0.so.0.10.0
/usr/lib64/pkgconfig/SDL_ttf.pc
/usr/lib64/libSDL_ttf.so
/usr/include/SDL/SDL_ttf.h
bash-4.2$ ls /var/log/packages | grep -i jpeg
libjpeg-v8a-x86_64-1
openjpeg-1.5.1-x86_64-1_SBo
seejpeg-1.10-x86_64-1
bash-4.2$ locate liblua
/usr/lib64/liblua.so.5.1
/usr/lib64/liblua.so.5.1.5
/usr/lib64/vlc/plugins/lua/liblua_plugin.la
/usr/lib64/vlc/plugins/lua/liblua_plugin.so
/usr/lib64/liblua.a
Колико ја видим, јавља ми да немам liblua библиотеку. А опет, ја је имам... Осим ако се нисам прешао негде у тумачењу.
П.С.
SDL_sound сам ручно компиловао, предпоставио сам да је то еквивалент пакету SDL_mixer.
Прешао сам се, није у питању еквивалент. Сад преузимам SDL_mixer, али опет остаје ова liblua :)
Да, опет јавља исту грешку... Помоћ?
Post Napisano: 08 Oct 2012, 02:18
SDL Mixer je već uključen u glavni SDL paket:
http://mirror.etf.rs/slackware/slackwar ... rce/l/sdl/" onclick="window.open(this.href);return false;
Probaj da li je lua ok instalirana.
lua -v
Takođe možeš proveriti i da li je u pitanju 32-bitna ili 64-bitna binarna datoteka.
file $(which lua)
Post Napisano: 08 Oct 2012, 10:12
Све му дође у реду колико ја видим :)
petar@Slacktar:~$ lua -v
Lua 5.1.5  Copyright (C) 1994-2012 Lua.org, PUC-Rio
petar@Slacktar:~$ file $(which lua)
/usr/bin/lua: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), stripped
Је л' има то везе што је 64-битна?
Post Napisano: 08 Oct 2012, 19:45
Nema veze ako furaš 64-bitni Slack. :)
Nešto se mislim da bi problem mogao biti samo na Slackware64. Elem, skinuo sam igru juče, pa ću probati kod sebe (Slackware 32-bit)..
A kako si pokušao da izgradiš? Neki SlackBuild ili ručno?
Post Napisano: 08 Oct 2012, 19:53
Ако мислиш на игру - ручно. Пратио сам упутство из фајла. Када покренем
$ make
стане тамо где сам навео...
Post Napisano: 08 Oct 2012, 20:06
Kod tebe je Slackware64?
да
Post Napisano: 08 Oct 2012, 20:13
Ok. Imao sam u planu da jedan dan instaliram Slackware64 i kod sebe. Mislim da ću sad morati da požurim s time. :)
Elem, ne mogu ništa da napišem dok ne testiram, ali možda zahteva da se podese LDFLAGS. Možda se lua traži u /usr/lib umesto u /usr/lib64. To mi je odmah palo na pamet, ali nisam stigao i da testiram (nemam Slackware64 u ovom trenutku).
Prvo ću testirati na 32-bitnom Slacku i napisati jedan brzi SlackBuild, pa ako i onda bude zezalo, instaliram Slackware64.
Post Napisano: 08 Oct 2012, 20:15
Оооокееет... Није хитно, кад имаш време ти ради... ;)
Birthday
Post Napisano: 09 Oct 2012, 00:55
bocke wrote:ali možda zahteva da se podese LDFLAGS. Možda se lua traži u /usr/lib umesto u /usr/lib64
Na osnovu ovoga samo da kažem, kad sam kompajlirao conky sa LUA podrškom za Slack64 morao sam da unesem sledeću komandu da bi to radilo kako treba
export LDFLAGS="$LDFLAGS -ldl" && LUA=yes ./conky.SlackBuild
Hteo sam i ranije da kažem ali nisam bio siguran :)
@slackmuz probaj pa vidi, meni je tako proradila LUA onako kako sam očekivao. Ne treba ti za conky ali prvi deo verovatno može da pomogne.
